PowerDVD does something that looks similar to interpolating if you enable it.What if I wanted to watch TV/movies/videos on a 120Hz computer monitor? Is there any software or hardware that can do real-time 24fps-to-120fps and/or 60fps-to-120fps interpolation, and do it just as well as TVs that have this feature built in, but with modularity?
Why does the delay compared to crt hit 50ms... that is atrocious yet it also has a min of 0.. I was kinda hoping for it to be almost zero. Still using the gaming comparison it looks pretty good so who knows.
I will certainly look at buying one if the price is right.
The test pictures/results just showed up on the digitalversus faceoff page. The default colors seem to be much better than the samsung and a little ahead of the viewsonic. If the input lag and responsiveness check out we might have ourselves a winner. Still I think I'll hold out for LG's panel since I don't want to spend years looking at the 'gamer' bezel.
What I dont understand is why more companies arent making more 120hz lcd's? (real 120, not the lcd tv bs) I know A LOT of gamers who would pay well for a decent 120hz monitor if one were to exist. It's been a year and the only choices we have so far are the rz2233 (which I dont like), the vx2265 (which is broken), and the vx2268 (which is not available in NA). And now this hideous thing. At this rate OLEDs will be a viable purchase by the time they come out with anything good.
Is it really that hard to make these monitors? Or are the companies just retarded and dont want my monies?
I'm glad you liked it, was worried a bit about steering you in the wrong direction. I would really like a 120hz monitor in 1920x1080 or higher resolution that is 25" or larger, I prefer larger pixels so I can sit further away. I doubt it will happen any time soon though.Couldn't wait on this monitor because my old monitor was dieing.
Got the Samsung 2233rz. I can not tell you the love I have for it.
I was gaming on a 32" [cheap] LCD that was two years old, running 4:3 resolutions on a 16:9 TV.
Now everything is the right proportion ebcause the res is right. Everything looks better at the higeher res.
I forgot what it was like to game on a CRT because I was used to crappy LCD.
Buy in confidence the Samsung. I will probably get a 24 or 26 in 120hz within a year or two once they get even better.
Yes good call. I am very happy with my choice. I even overclocked my PC now to push more FPS out of my games. I want to run TF2 at 120FPS steady.
CS:S is awesome with fps_max 120 set. Obviously the games graphics are outdate, but the responsiveness is awesome [running everything on high].
Full HD monitor that will be compatible with GeForce 3D Vision
What's all the excitement for?
I see no evidence that this is a real 120 Hz monitor that accepts 120Hz signals.
It just looks like another interpolator.
Based on what evidence?It just looks like another interpolator.
Sooo you are saying that the samsung 2233RZ doesn't has a real 120hz?
did you even read the artical??
means true 120Hz
Yes, I read the "artical" (wow, you killed that one.)
Can someone explain how "compatible with GeForce 3D Vision " means, "can accept and display 120Hz inputs?" The connection doesn't seem clear to me.
r_3dsky 0 will help keep the fps high in CS:S and TF2. And you need to jack up your cpu as high as it will go, those game are really cpu-limited. TF2 is multithreaded now so it doesn't need as many mhz but in CS:S even with my old E8400 at 4.0 I still saw it drop below 100 fps some times, and with 100 tick and 100 rates that's a no noYes good call. I am very happy with my choice. I even overclocked my PC now to push more FPS out of my games. I want to run TF2 at 120FPS steady.
it's not an interpolator. 120hz lcd monitors are the real deal. seems like every time one of these threads pops up someone comes in to tell us how humans can't see more than 60 fps or that it's not really 120hz. let us put this to rest.What's all the excitement for?
I wouldn't use fps_max 120, just turn vsync off and let it ride. fps_max set to low values like 120 has been known to mess with mouse input. 300 should be the minimum you set it to.
not sure. Word is January will be release month.
Nah, scratch that, I'm still waiting for OLED, unless one of these comes out in good form (120 Hz, 1080p, SPVA or IPS, and CHEAP)
try it with vsync OFF and fps_max 300 and tell me if you see the oddness, because I don't.Well without vsync CSS looks odd when i strafe. Turned on vsync and looks way better, still running 120 fps anyway in CSS.
Yes, unless Asus or LG have a history of surprising us with new products out of the blue. The GD235HZ is starting to get reviews and (by our standards) should be out soon.
