poach said:It is garbeled on the startup screen, so much so that I cant install windows, the vid card is not using any drivers because they cant be loaded.
What is the deal with RMA-ing parts? I've never needed to do it before.
The only 4 pin connector on the card is yellow and I have no plug to fit it.
Sorry to do this in two posts, but what motherboard BIOS are you using?
Reason I asked is I just looked at the list of fixes that the current 1003 Final has, one of them is "fix PEG for X850 series cards" or some such. It could be flashing to 1003 Final will fix everything for you.
One warning, if you're using NCQ based harddrives, especially Maxtor NCQ's, you may lose the ability to use them if you flash to anything newer then 1002.
