Vega said:Does all the 74gb raptors support ncq? I have used all the bioses and never had a problem with them not seeing my raptor.
Tripp17 said:i really havent had too much problems with stability.....my problem comes with overclocking. Yes, i can overclock alittle(and i mean alittle), but anything over 210 and i get error messeges at post. The wierd part is, when i really overclock it, to say....250, i get the same message but instead of changing it, i leave it and save and exit and then it boots up great??!!! I can play games and everything, untill i power down that is. When i come back and power up, i get the error message again so i repeat the process. This is my second board to boot!! The first one wouldnt even post. I do hope that a bios comes out and fixes this. ALSO i hope that there are some decent WHQL nforce 4 chipset drivers. Lets go already boys....were dying over here.
Praxi said:Just wanted to share my experiences so far. Board worked great on the 03-0005 bios for about 3 days (no software or hardware changes after the 1st day). Locked up on 4th day, reset, then it was stuck in a boot loop. Couldn't enter safe mode or use recovery console off the CD, it would just reset itself. I can't even get it to format now. The original setup was the A8N, 3800+, Pioneer DVD burner, 2x80gb maxtor (raid 0), mushkin 2x512 running in dual channel, and a BFG 6800GT PCIe x 1.
Board started exhibiting those problems. Since then I have swapped out hard drives, power supplies, memory, video card. Tried disabling all on board devices that the bios would let me disable. I've tried bios versions from 1002 up to 1003-0006 all with the same affect. Got a call into asus yesterday still waiting for them to have a tech call me back.
So for 3 days it was a very kick ass system![]()
HydrasunGQ said:I recently received my A8N-SLI and am waiting on my GT's to come in so that I can order an FX-55. I have an Antec true control 550 PSU. I would like to know if I can just plug the 20 pin molex in or do I need the 20-24pin converter?
_Korruption_ said:Power-related question here. If I had an OCZ Modstream, which natively comes with a 24-pin power connector (20-pin + 4-pin to make 24-pin), would I still have to plug in the square 4-pin 12V connector into the dedicated 4-pin connector? Or do the extra 4-pins in the ATX power connector make up for that?
.006 & .008 I have not seen, if some one could post a link and/or test them against the diamondmax 10 sata on nvidia sata would be nice.Shogan191 said:Received my board last week. Had the ususal reboot problem with the 1002 bios. Changed to the 1003.005 and haven't had that problem. Using an Antec TrueControl 550 with 20 pin offset into 24. Using plain MSI 6800 cards in sli. Have a single 4pin molex to board in addition to the regular power connector and the 4pin auxillary. I haven't seen any problems or improvements with the .006 or .008 bios. No problems ocing other than I need more Vcore. Have run raid using 2 and 4 drives off the nVidia controller in raid 0. No problems finding the Raptors.
The main problem I have is needing more Vcore. Everything else seems to be working well.
vxspiritxv said:.006 & .008 I have not seen, if some one could post a link and/or test them against the diamondmax 10 sata on nvidia sata would be nice.
darkjedi said:I have the A8N-SLI Deluxe. I am running an FX-53 with a pair of BFG 6600GT's OC'd to 550/1100.
For power I am running the old PC Power & Cooling 510 with the 20 pin connector. I am plugged into the board offset, I have the 4 pin CPU connector plugged in and the 4 pin hard drive power connector in above the video cards.
No power issues to speak of. I tried an Antec NeoPower 480 with the 24 pin power connector, but I got an error when playing Doom3 saying that I was not getting enough power to the video cards and it would slow the GPU's WAY down... very bad. Put my PP&C back in and all was well.
So, it seems that it can work. However, I am running 6600GT's NOT 6800GT's
ajmiles said:I've still not lost my maxtor with 1003.008 and 4 hours of aggressive overclocking/crashing/hanging/rebooting. I think the maxtor detection problem may well be fixed, I'm not willing to test for NCQ though, leave that off.
vxspiritxv said:http://forums.anandtech.com/messageview.aspx?catid=29&threadid=1491690&enterthread=y
Sounds like they fixed the maxtor problem.
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=1449863&messageid=17230594
I don't have a account there to pm him, if he has had any problems since posting that yesterday.
From your specs, I assume you are running 4 x 512MB modules. From Xbits labs "When four memory modules are in use, the memory controller of the Athlon 64 can only support DDR400 SDRAM with the slower 2T timing. Moreover, if the four installed modules are two-sided, the speed of the memory subsystem will be dropped to DDR333 even with 2T timing." http://www.xbitlabs.com/articles/cpu/display/athlon64-3800_3.htmlVega said:I can't even get the machine to post running STOCK 2-2-2-5 1T timmings on 2GB of some decient ram: http://www.newegg.com/app/ViewProductDesc.asp?description=20-220-033&depa=1. Seems everything I do to get the damn Ram out of auto DDR 333 locks something up and I have to clear the CMOS. The other half of the time the machine refuses to send out a video signal. Machine locks up, power button doesn't work, only thing that gets it back is a CMOS clear. Only way I can get it to run with any stabilty is setting 2T with 400Mhz 2-2-2-5. This obviously is a performance hit.
If the only thing I adjust OFF of Auto is 1T, it will Post a rediculous DDR 200.
panhead said:From your specs, I assume you are running 4 x 512MB modules. From Xbits labs "When four memory modules are in use, the memory controller of the Athlon 64 can only support DDR400 SDRAM with the slower 2T timing. Moreover, if the four installed modules are two-sided, the speed of the memory subsystem will be dropped to DDR333 even with 2T timing." http://www.xbitlabs.com/articles/cpu/display/athlon64-3800_3.html
If you want to run 2GB of memory I would suggest you get 2 x 1GB memory modules.
Wait til the price gouging ends with the PCI-e video cards. The board is stable, there are issues, but that is to be expected for a new chipset.Lunasea112 said:I was just wondering do you guys think i should wait till ASUS works out all the bugs with the A8N SLI- Deluxe or should i just get it now? I am planning on getting one when i come up with the money but should i wait or get it as soon as i have the money?
That's the fastest I have been able to find. I have been try to decide whether to get Corsair's TWINX1024-3200XL at 2-2-2-5 or Crucial's Ballistixs at 2-2-2-6 and wait for faster 1GB modules or get 2 of the CMX1024-3200C2 at 2.5-3-3-6. The 1GBs are expensive though and I don't run anything now that would use the memory.Torquemada XP said:I haven't done much research yet, but I found some 1GB Corsair XMS modules with 2.5-3-3-6 on AMD. Those are the lowest stock latencies I've found on 1 GB modules.
panhead said:Wait til the price gouging ends with the PCI-e video cards. The board is stable, there are issues, but that is to be expected for a new chipset.
I have been watching PCI-e 6800GT for the last few weeks and have not seen any for MSRP of $399 in stock. I see some places plan on shipping the end of Febuary. I'll wait until the gouging stops and get an ultra for the price of a GT now or a GT for $399 or less. It might even be a good idea to wait until ATI's R520 is release and the 6800s will be old news then and all the venders will be gouging the R520s.Arvig said:If you're really willing to shop around, one can get PCI-E cards for at least retail, I think a bunch of people got BFG 6800 GT OC's for $399.00 each from some place called www.chumbo.com for instance. Don't know if they are in stock there right now though. Likewise, I've seen the prices a bit more reasonable.
panhead said:I have been watching PCI-e 6800GT for the last few weeks and have not seen any for MSRP of $399 in stock. I see some places plan on shipping the end of Febuary. I'll wait until the gouging stops and get an ultra for the price of a GT now or a GT for $399 or less. It might even be a good idea to wait until ATI's R520 is release and the 6800s will be old news then and all the venders will be gouging the R520s.
Arvig said:Did see a thread where someone had problems with SATA optical drives, but looked like that 1003.006 (if memory serves) solved that for him. Maybe I'm being optimistic, but that maybe indicates that they are slowly working on the NVidia SATA ports one bit at a time, and have solved some issues if one of the latter beta BIOSes allowed the guy to use his Plextor SATA optical drive. If I remember right, saw the thread on www.pcper.com, in their ASUS motherboard forum.
Xrave said:I have a SATA optical (in sig) that has no problems. I've ran it in bios verions 1002 and 1003.005.
Also, I got my BFG 6800GT PCI-E from Chumbo ($399 including overnight shipping).
Tripp17 said:I finnally got everything to work just great. Here is what i have:
AMD FX-55 w/ XP-120 heatsink
2x512 OCZ El Platinum Rev.2 @ 500 1:1 (2.5-3-3-10)
6800GT w/ NV silencer5 @ 435/1250
Asus A8N-SLI Deluxe @ 250 fsb
500 watt X-connect PSU
W.D. Rapter
I need to get another rapter, but alot of people are having problems with raid so ill hold off till the newest official bios is realeased. Its a great board, i had my problems at first, this is my second board. First wouldnt even post!! But, i just got 14,009 in 3dmark 2003, with a single GT. Not bad huh? Go for it, you wont regrete it.
