With XP 32 Bit SP2, I start up using 101MB of Ram (Via the task manager)Mickelonis said:I heard that if you run 64bit, you need a substantial more amount of memory because it handles everything in 64bit mode, even 32 bit applications, if it's a 32 bit application, it still transfers it in 64 bit.
*shrug*
I'm no expert, but thats what I heard.
My question is what is the actual performance enhancements if any?
fuelvolts said:Had windows 64 for about 3 weeks - I had 2 printers and a tv capture card that their respective companies (via email) stated that there were no plans to develope 64 bit drivers. So I reinstalled 32 bit bc I needs me some printin' and watchin'.
Stupid Brother and Hauppauge...jerks.
Not to mention Diablo 2 would install (I've always wanted to beat that game). No worry, it was only 5 bucks from school.
It has improved memory management and an Improved Processor sceduler.n64man120 said:No one gave a good answer to this, aside from the WMP comment...
What do you gain by using 64bit edition instead?
Jasonx82 said:Yes, Using Windows XP Pro X64..
Why dunno, it works fine for me. Improvements I see are in Windows Media Player (well as far as i can see) loads faster..![]()
It seems like everything is snappier with XP64, however I did go from a P4C 2.8, 1GB DDR400, XP32 Bit To a X2 4400 OC, 2GB DDR400 and XP64....DarkBahamut said:You know that WMP on X64 is....32bit?![]()
Here's another big check for staying with XP-ProKevlarman said:My Hauppauge PVR-150 however, no dice. Hauppauge says they won't be able to relase a 64-bit driver until Conextant releases the tools for them to do it. So go yell at Conextant, not Hauppauge.![]()
USMC2Hard4U said:It has improved memory management and an Improved Processor sceduler.
Thats about all I can think ofbut its good enough for me
Well I say if you have a system with alot of ram, and more than one Processor, Yes. I greatly benifit because of my Dual Cores. The OS has the processor sceduler from Server 2003 and can handle multiple threads of data better. Also the Memory management is alot better. IT uses more of your system memory if you have it, less paging, more effecent addressing etc...n64man120 said:So this translates into more speed and better performance?
Marine Corps Wide, Back here in the rear, and when i was forward deployed we us Windows 2000 SP4 Because our machines are older. However the newer machines we are gettings that are Dells P4E 3.2 Machines, and Mobile Pentium M 1.7GHz IBM thinkpads come with XP SP2 But we are still in the transition, and really wont be getting the new computers USMC wide until the beginning of next yearGlow said:Just curious, what OS you guys are running in the field?
No its just like Corporate. A Mass licence copy or whatever. However that works. But its the same thingGlow said:Really, well shit I thought you guys would have something a little more hardcore than a thinkpad. When it comes down to it on a battlefield knowing lives depend on XP that kinda scares me. Or is the version you use somewhat better?
