A64 OC Database & Overclock Guide
This actual SS was taken on air although i am now running water. My OC didnt change at all though...
Elysian said:
ok, so another entry in here by me, my opteron 170 0530TPMW CCBWE, 2.8ghz at 1.65v water cooled
you forgot to add mine to the chart, though i've since gone down to 2.75@1.52v
Reading all this stuff about RAM dividers and ratio simply gave me a headache... Is this guide universal for any Athlon 64 CPU (including my Opteron 170), in that I just follow the numbers given in the steps, or do I have to calculate my own RAM ratio?
Keeping in mind that I JUST want to do my CPU and not my memory (for now).
Duncan1234 said:
I knew i could, just would be easier out of the BIOS.
Thanks anyway.
Speaking of the BIOS for the Asus A8N-E motherboard, FYI (in case you aren't aware), Asus has recently released BIOS ver. 1010.
Yeh, i just built this at xmas (my first build) and i flashed ver 1010 last week :)
54YW4T said:
Why aren't I on the list yet?
cause i'm busy :p i'll try to find time tomorrow to update. i go back to school today and my normal computer that i have all the data on is packed up.
GUYS!
jeez. techhead even made this thread telling you not to post random discussion in here:
http://www.hardforum.com/showthread.php?t=999655
and it EXPLICITY states in the first post:
Now, the rules. FOLLOW these rules!
1) Try not to post if you do not have a new cpu or an update for a previous one. All comments/questions to me should be taken to PM's. If it's a general question regarding your cpu, post here!
i hate to be an ass, but just post in the discussion thread. if you want to ask someone a question about something they posted in here, simply quote and copy it to your reply in the discussion thread. it's not hard ;)
spot reserved for my opty 165
OSA165DAA6CD
CCBWE 0546MPMW
136728AL50152
2508.6, 1.4v, air
memory=179mhz (133 divider, generic mismatched RAM :( )
I know it's not 4 hours, but I needed to recode a divx file ;)
Ive been at this clockrate for 2 weeks now, perfectly stable
Will redo later if needed
ok guys. i get my cicuits homework done and the updated pics are going up.. maybe an hour? :D
(cf)Eclipse said:
for those of you who i missed, please simply repost the data for me.
sempron64 2800 RevE, unlidded, watercooled
max stable OC 2635MHz (8x329)@ Vcore 1.675
SDA2800AIO3BX
LBBWE0533VPDW
3200+ Venice
ADA3200DAA4BP
LBBLE 0524APMW
Max Stable @ 2750 Mhz
1.58 Vcore
Air Cooled
First post here.
Got a 3700+ SD and an Asrock 939 dual-sataII mobo for Xmas (because the first was on sale and the second has both AGP and PCI-E slots, which suits my keep-my-6600GT-and-upgrade-later strategy). Now the Asrock isn't noted for it's overclocking prowess, so I went into this with low expectations. So I'm fairly pleased to post this:
ADA3700DAA5BN
KAB2E 0546BPAW
Bios set to max vcore of 1.45v
Stable (20+ hours of Prime95) at
2816 - 256 x 11
Stock heatsink/fan.
Aspire X-pider case has four Antec 90mm casefans, one front, one side, two back.
Temps under load - 39/38C
At 260x11 Prime95 will run for an hour, 40 minutes before faulting (completes an Aquamark3 run without any problems, and will play an round or two of CStrike), 265x11 errors out on Prime95 within minutes.
If I ever lay my hands on a conductive paint pen, or get brave with a soldering iron, I might try the volt mod (there is a paint-the-resistor mod to get a max vcore of 1.55 on this mobo, but that's it), but this chip is returning Sisandra and Aquamark3s consistant with an FX-57, so I'm very happy.
Ok Eclipse, I have an update for my same processor LBBLE, Week 0516, Code GPBW, Air cooled again but currently running 2627 from 1800 at 1.44V Prime stable and looking loverly... Signifigant gain I would say. From 1.5 v for 2700 Hopefully I will get there soon but as school has just set back in it will be some time before I can sit down and be as thurough as I would like. Thanks man... keep up the great work, I have a wife and daughter and I go to school full time and work too. I know what its like to be busy. Dont let others give you crap. You are great!!! :D
Finally got something stable last night
Opteron CCBWE 0543TPMW @ 240x10, memory 5:6
Little disappointed, confused as to why I'm not getting stable at 2500 or 2600mhz even when the ram is stable and in my initial testing in prime, the CPU hit over 2800 before one of the cores crapped out on me. People with the same stepping seem to be hitting those speeds no problem, guess some more testing needs to be done.
whats the HTT x?
Heres my overclock on my new opteron 148
osa148daa5bn
cacje 0546bpmw
Heres about a days worth of memtest
Heres the config
Whoops, just realized my prime screenie was by itself with no cpu info. Will run that overnight and post it. *edit* here we go ~ Errors at 10 hours in "In place large FFT's" ~ I have always found this to be the hardest test to past with the a64's I have built. Doesnt crash in games nor caused one problem at this speed. I'll track down that 10 hour error tho :(
Voltage is set in bios as 1.55 * 107.2% ~ about 1.66vcore. It may run with less voltage, as I am still finetuning. *edit* vcore now @ 1.525 * 107.2% for 1.63vcore
OSA146DAA5BN
CAB2E 0546FPAW
2.6ghz Prime Stable, 1.42 vcore as reported in the BIOS.
Memory at 217mhz using 166 divider.
XP90 (aluminum) with 43 CFM Panaflo fan.
3800+ X2
ADA3800DAASBV
LDBHE 0543SPMW
-0018
2.7GHz Dual Small and Large FFT 12+ hours stable
1.42 vcore
270 HTT/FSB 1:1 3-4-4-8 2GB (2x1GB G.Skill UCCC)
Air cooled (big typhoon + good case cooling), full load - 40c CPU // 46c PWM // 42c Chipset
Opteron Retail 165 0546 SPMW
HTT:3x 285MHz FSB
333MHz (5/6) divider
2GB G.skill crap 3200
Asus A8N-SLI Deluxe 1015
2.567 GHz Stock cooler, Stock Voltage, 4h30m SP2004 stable. Still going.
My sister's chip. She won't let me watercool it.
OSA175DAA6CD
CCBWE 0543 TPMW
Currently stable at 2.6Ghz
1.475 Set in BIOS, 1.44 in Windows
Lapped XP90 with Panaflo M1A
My results (so far)...
[img=http://img361.imageshack.us/img361/6561/165ccbwe0547tpmw22bf.th.jpg]
OSA165DAA6CD
CCBWE 0547TPMW
Last 4 digits 3rd line: 0230
5:6 Mem divider, 3.05v to the sticks forget the LDT/NB volts...HD on SATA 2(i think, tried to switch to 3/4 but BSOD on Windows load wout reinstalling).
BIOS Volts: 1.5 - Initially had to do appx. 1.55v-(1.5vish+50mV-100mVish 7-shift), but after a couple days now of tweaking/testing and general usage, it's requirements seems to have settled a bit.
Screenshot:
I thought I'd throw in a few more examples onthe screenshot, ie: 44.4ns on Everest latency (also 6169M Read IIRC, don't remember if it was as these same speeds/volts though)..I know you guys do't like SPI/SPIMod shots w/out the end "caclulation done" messages, but I wanted to just throw it in anyway..Forgot to do the CPUZ validation for the screenie, will redo that later (may start own thread on this buildup elsewhere on the forums). Also, ran some other (tests), but also don't recall the acutal settings..
7147 3d Penis 05
8223 CPU Score
6360M/9570.5 Texels Single/Multi Fill Rates
178.5fps
63.6M/44.8M Vertices Vertex Shaders Simple/Complex
HDTach: Appx.: 173.5M burst, 13.1ms, 56.0 avg read.
Other system specs (need to update sig)
EVGA NF41 SLI Mobo // EVGA 7800gt (good to appx 498-502 core/1.18GHz mem)
XClio 480BL (CWT made - internals look awfully alot like Antec's True 480....)
2x512 OCZ ValueVX
Swiftech Apex Ultra
Pioneer DVR109 (got it working properly again in new setup..maybe the IDE controller is dead/dying on my NF7-S...)
The only thing that is annoying the crap out of me with this system atm is the fact that I don't know if my load temps are good or not..I get anywhere from 37-40c BIOS/IDLE to 50-52 LOAD (via SpeedFan/Jetway MyGuard) at the current volts/speeds..I read that this board overshoots by anywhere from 5-12c..I suppose it could be a bad mount, seeing as this is a) my first w/c setup, b) First bolt-to-board cooling, etc, but I've already mounted this a couple times (when I saw the original BIOS temps), and the spread looked fine - Although I use the old AXP style - put some thermal goop on (Ceramique in this case), and spread w/ my ATM card (or similar)..Temps/ambient temps shouldn't be an issue..I am literally 2 blocks from the beach..Go down tot he end look right and the big ass solar ferris wheel @ the SM pier is maybe 1/4 mile down (Up technically) the beach..I could surely count on my hands the number of days/year it gets over 80-85 here..Firefox weather plugin last night said something like 50F..Didn't feel too far off the mark there.
Oh - and of course I will get to the full 24 hr Prime testing *eventually* but my system is begging to be used now ;)..
ps Decided todo CUSTOM Prime test -- Blend "style" I guess (8k-4096k didn't change that), but set custom memory usage at appx 375M or 400M per core/instance, as letting it just run on it's own devices w blend lead to a super syrupy/slow responding system using nearly 2GB memory..Not too good since I only have the 2x512 OCZ sticks in atm (need to upgrade, either 1x512 thatll play well w 1x512 Corsair XMS 3500 *BH5* and my OCZ, 2x512 to play well with my OCZ, or simply go for some decent 2x1GB sticks (ie: the value G.Skill's seems to do pretty well).
I'll post pics [hopefully] tomorrow.
Opteron 170 Retail 0541RPMW
2.5Ghz @ 1.4v (1.3v + 8.3%)
RAM = 3-3-3-8-1T @ 2.7v // 5:6 Divider @ 208Mhz
So far:
Dual SuperPI 32M Stable
Aquamark3 Stable
3DMark05 Stable
Just set the OC tonight, so thats all I've gotten done . . . more tweaking will follow tomorrow. I'll edit this post for any changes.
Venice 3000+
LBBWE 0542EPMW
Chip has more left in it just got some more tweaking to do :)
If eclipse feels like updating, or adding another row since I switched to water cooling.......
My 3000+ has been @ 2901mhz 1.69vcore, 38c load.....and ~30c idle......I never see the idle temp as this rig is on 24/7 runnig folding@home.
LBBLE 0517 APJW
Last update was 2772mhz on air.
Pleased with my new proc :)
MSI Neo 2 Platinum
AMD 3800+ X2 Revision e4
xp-90 thermalright
2x512 Cheap samsung ram
Chaintech 6800gt @ 435/1160
1.425 volts
280mhz htt @ 3x
200.5mhz memory (150mhz divider)
2800mhz cpu speed prime stable for 8 hours
Idle Temp 37
Load Temp 49
Processor posts at 2.9 but is prime unstable. Havnt fed it anymore voltage for fear of high temps. All I can say is WOW, what a fantastic purchase! Exstatic over my OC results :)
Second post of my first post
ADA3700DAA5BN
KAB2E 0546BPAW
2816 - 256 x 11
Stock heatsink/fan.
Opteron 175
OSA175DAA6CD
CCBWE 0550UPMW
2.57 GHz at 1.55V (FSB 234, DDR333, HT 4x)
water cooling
Hey Eclipse!!! You Put me in the wrong section. Im supposed to be in 3200+ Venice not 3000+ Venice.
A643200
ADA3200BP??????
LBBLE 0545 XPMW
on air. 1.45v 250x10 39c. 2.51ghz prime stable 22 hrs. 5xHTT 2T.
Will get rest of # when I can.
w00t.
ADA4400DAA6CD
CCBWE 0529MPM
Max stable OC: 2.64 GHz (240x11)
Voltage used: 1.55v
Cooling type: air
Over 6 hours prime stable using small FFTs (using 1 instance on affinity 0 and 1 on affinity 1 since I'm on dual core), and over 2 hours stable with memtest86.
with my 3700 sandie topless I have 3.0ghz stable at 1.55 vcore... 24 hours prime stable, 41c load max temp with the room at 78f! removing the IHS made all the difference... wow. before my temps would shoot up to 55c!!!!! crazy... anyways. I am thinking I might be able to get 3.1 out of this chip with 1.6 vcore... we'll see. :)
EDIT: here's the obligitory screen capture with all the goods. :)
awww my 2.7 winnie on air never got put up :LOL: i cant try again now since my board hates me <_< and my cooler does too <_< ill see if i can dig up SS's
i think the stepping was CBBFD0442RPMW winchester 3000+ cant remember the first line and dont have any AS5 that i know of so bleh
maximum completely stable overclock i had was 2.6 @ 1.55 (in windows) and that didnt fail P95 after about 7:30 hours so... : D
--> http://valid.x86-secret.com/show_oc?id=32900 <-- 2.709 on AIR :D wasnt TOO hot either B)
Meh. thats all i can find right now, running at 2.2 stock volts because my cooler is acting wierd... i might shuter down and clean er up :p
well i got pissed cause at idle it hit 53 degrees. quick dust off and some tim movement later (can someone say ghetto? :D ) my temps are back down at 40 idle :) (stock volts though <_< i used ot idle at 40 on 1.5ish at 2.4 :( i need more as5
stepping
ADA3000D1K4B1
CBBFD0444RPAW
3700+ San Diego
KAB2E (sorry don't have the full code without taking machine apart :)
2.75 GHz at 1.45v
HTT 250 MHz, RAM 250 MHz
stock AMD fan/hs idles around 38-40C, full load 50C
