A64 OC Database & Overclock Guide
Opteron 165
CCBWE UPMW
Week 0551
On Water
1.525v
290x9 (2609)
I don't have all the info to put into the spreadsheet yet, as I am not home to unmount my cooler to get the numbers, but I will post here to give you a heads up about my OC.
I am running a Sempron 3000+ Palermo on an Asus K8N-E Deluxe. The FSB max on this board is 300MHz, so that limited my OC to 2.7 GHz. I was able to accomplish this with a voltage setting of 1.675 in the bios, but it must be noted that there is something very screwy about the voltage on this board. Any setting from 1.55-1.65 (and possibly others) gives a voltage in Asus Probe of 1.536. 1.675 is the first to give anything higher, and it jumps to ~1.62, quite odd.
My temps on the stock cooler, with no case (just bare motherboard sitting on desk) are 31-33C (depending on ambient temp) idle and 52C at full load running Prime 95. The machine is stable with roughly 20 hours of Prime95 torture test.
Let's hope some more Sempron OCers post their findings here. I am thinking that it would be more likely to happen if a duplicate of this thread was created and dedicated to either only Semprons or s754 chips overall. We know the 754 guys sure have pride! :D
EDIT: Here are the numbers from my Sempron:
SDA3000AI02BX
LBBWE 0538CAA
X032747I52159
OSA165 AA6CD
CCBWE 0551 VPMW
Max Stable Overclock: 2704 MHZ
Voltage used: 1.49 volts
Air cooling
I have two prime95 setups (one for each CPU), prime95 stable for 24 hours. (I like rock solid stability,,,call me crazy!)
I'm thinking I can get this thing faster, so its an Unfinished overclock (I'm just having fun with it right now!).
CPU-Z Verifeid
OSA170DAA6CD
CCBWE 0551UPMW
2.6 @ 1.4V stable for 7 hours. Watercooled Idle 29-30C Load 45-48C
A little more info for the database:
A64 3800+ X2
ADA3800DAA5CD CCBWE 0544 XPMW
Max Suicide - 2860 at 1.72v
running 24/7 now at:
311 x 9 (2799) @ 1.35 x 123% (1.66v)
All watercooled - naked. (No IHS- ;) ) max load temp = 50c
Everest and PC Wizard both show this CPU as a Toledo-512 not a Manchester.
time to update, eclipse, i need it updated,
anyway, i got another for you
Do you require a screenshot before my stuff gets added?
SDA3000AI02BX
LBBWE 0538CAA
X032747I52159
Some amazing new 144 steppings lately it looks like.
I just received my monarch 144 order. I bought 3 oem cpus.
The stepping is CACJE 0602GPMW on all 3.
On my first try, the first cpu I tried does 2.7ghz ON STOCK VOLTS with the stock AMD copper heatpipe sink.
Amazing. Still priming, but no failures yet! Tempted to try 2.8ghz next on stock volts lol. This thing must be capable of 3ghz or so with more voltage.
Wow, I had no idea I could get this fast of an overclock, the memory is real slow right now, but the CPU of course is tearing ass like no tomorrow, probably not a good idea to leave it on at this speed with just water. Pushing 40C with a heavy load on the CPU.
URL=http://img156.imageshack.us/my.php?image=stable4mg.jpg]
[/URL]
Opteron
OSA175DAA6CD
CCBWE 0550UPMW
2.7GHz @1.55v Watercooled
Temp 34idle/42Load
Opteron
OSA175DAA6CD
CCBWE 0550UPMW
Temp 34idle/42Load[/QUOTE]
Opteron 170:
OSA170DAA6CD
CCBWE 0551UPMW
Toledo core
2500 mhz, 250 x 10 1.37 volts (stock)
MSI K8N NEO2 Platinum
Opteron 144:
OSA144DAA5BN
CACJE 0602GPMW
Venus core
2800 mhz, 311 x 9, 1.37 volts (stock)
MSI K8N NEO2-F
More voltage will not help the 170 due any better, probably the motherboard.
The 144 will load windows at 323 x 9 (2900) but I cant get it prime95 stable at any voltage above 2800 mhz, so they both stay at stock voltages.
T-3
Heres a fresh stepping for you Eclipse:
3700 San Diego
ADA3700DAA5BN
KABYE 0542 FPMW
2805 MHz
1.525 VCore
Air cooling
27 hours Prime 95,
19 Hours Memtest 86+ (required, as noname memory 3-3-3-8 --> 2-2-3-5 @ 200MHz, 166MHz memory divider, can easily run @ 255 3-3-3-8, however tight timings meant better performance than straight speed.
CPU-Z Validation: http://valid.x86-secret.com/show_oc?id=76680
Athlon 64 X2-3800
Manchester Core
ADA3800DAA5CD
CCBWE 0548RPMW
Max. stable overclock is 2.7ghz (Prime 24 hours) at 1.45 vcore (1.47 BIOS).
Cooled by XP90 with 57cfm fan.
Just got a Opteron 144 with the same stepping you have.
I am Priming @ 2.8ghz, stock voltage 1.4v (CPU-Z reports 1.392v) as I am typing this. It has been priming for two hours and going strong.
BTW, I use the stock 4-heatpipe HS with fan speed @ 2000 rmp. Temp is at 48c.
Look like I may have to sell my Opty 165. :D
Finally finished putting my computer back together. Here is what I got.
OSA146DAA5BN
CAB2E 0604EPAW
Max stable overclock so far is 2.85Ghz
Overclock is at stock volts (1.4v, 1.38 in MBM)
Cooled by Zalman CNPS9500
I was able to get it to 2.9 on stock, but weird stuff started happening and I backed it off. I may try raising the core voltage to get more, but I am pretty happy with what I have now.
After much researching and testing finally got my final OC. All statistics and benchmark results can be found here
Athlon 64 X2 3800
CPU Alias Manchester S939
CPU Stepping BH-E4
CPUID Revision 00020FB1h
Stable OC @ 2.8
Vcore 1.39
Water Cooled
Initial results of first OC attempt on new setup:
1st line: ADA4400DAA6CD)
2nd line: CCBWE 0574TPMW
overclock: 2625 (didn't test further)
voltage: 1.425
cooling type: water - KOOLANCE EXOS, CPU 300-H06
Asus-A8N SLI Premium BIOS 1009
FSB: 250
CPU Multi: 10.5
CPU/Ram: 1:1
2x512MB PQI DDR500@ 3-4-4-8
Saphire X1900XT
PCI SLOTS:
Sound Card
TV Tuner
DTV Tuner
Ran 2 instances of Prime95 for 30mins while web surfing, transferring a couple gigs of movies across hard drives and running RTHDRIBL.
CPU Temp was reported at 54c(max).
Processor - AMD Opteron 170
1st Line - OSA170DAA6CD
2nd Line - CCBWE 0530TPMW
Current Overclock - 2.8GHz (280x10)
Voltage - 1.40V
Maximum Overclock - 3.1GHz (310x10)
Voltage - 1.65V
Cooling - Scythe Ninja + 120mm Panaflo M1BX
Motherboard - DFI LANParty NF4 Ultra-D
RAM - G.Skill HZ 2x1GB
FSB:RAM - 1:1
RAM Timings - 3-4-4-8 1T
Stability - Dual Prime95 10 hours, SuperPI 32M, dual SP2004 8 hours, 3dMark2005
ok, I got a new opty 175 today.
CCBWE 0550UPMW
so far so good... except for the fact that the IHS was not flat.. I had to lap that sucker.. and I am seriously considering removing it soon.. it was really sticking up on all the edges... the middle of the core part didn't touch the sink bottom until I lapped it. Anyways...
after lapping, the chip idled at 27c 2.2ghz with 1.29 vcore! the new denmark cores are that lovely lower power version of the toledo. So I was able to hold 1.29v until 2.52ghz... I got a little impatient after that and pushed the vcore to 1.375v and am now dual priming there at 2.61ghz... FX60 speeds under 1.4 vcore.. not bad. Anyways.. the AS5 I put on was my new tube and it was pretty "wet" (as far as AS5 goes) so I want to let it set before I go too much further... load temps are around 39c. so I am going chill here for the night.. I'll snap off a screen shot in the AM and post it here. :)
SDA3100AI03ZBA
LBBIX 0534TPMW
2431.7 - not certain max oc (270.2 HT, 9x Multi no div)
2458.8 - not certain max oc (273.2 HT, 9x Multi, Mem 245.9 w/ div)
2501.0 - not certain max oc (277.9 HT, 9x Multi, Mem 250.1 w/ div)
2540.0 - not certain max oc (282.2 HT, 9x Multi, Mem 230.9 w/ div)
2554.8 - not certain max oc (283.8 HT, 9x Multi, Mem 232.2 w/ div)
2584.8 - not certain max oc (287.2 HT, 9x Multi, Mem 234.9 w/ div)
air cooling, stock (1.47v)
Motherboard - Asus K8N-VM Sempron 3100+
PQI Power Series 512 (2x256) PC3200 3,3,3,8
prime, memtest stable - 6h
pretty sure i'm maxed on this ram now. I am very very suprised at how well this ram held up. I might try putting in my ocz micron and see how well it does.
This paticular board has no vcore or vdimm adjustment that I see. Does have a decent memory timing section. go go sempron
EDITED:
Well tried my ocz micron and didnt make it anywhere near 2584 stable. Hopefully thats just an indication of how crappy this mb is. So lets stick with 2584 as max oc on this config.
SparkedFire said:
OSA165DAA6CD
CCBWE 0551VPMW
2505GHz
1.425v
Air cooling
Check my puters webpage for complete details.
I could not get it compleatly error free on Core 0 with anything higher than this speed and 1.525v.
I left it at this speed for stability and cooler temps. Core 0 is a poor OC'er on my chip.
Core 0 seems to be the one which takes most of the extra system level operations while dual priming, so it will be the one to fail on most systems.. or so I am thinking, after seeing all these posts with "core 0 bombs out at so and so mhz"... I am guessing that's wwindows XP not being a true SMP environment, so maybe it's going to core0 for most system level operations rather than round-robin'ing the tasks equally to core1 also... I noticed that core0 was behind in calculating prime in my 21 hour dual prime session, by like 20 seconds.. core1 was ahead by a fair margin when I stopped.. I ran nother one and core0 lagged again.. so it must get stuck with system level tasks, or tasks which have no cpu affinity, and default to core0 always.. maybe? it's a theory.. :)
Just got an Opteron 146.... is this stepping any good? It is not in the table:
EDIT: I don't have all the parts to my computer yet, so I can't even try it till later in the week when I finish my build.
Processor - AMD Opteron 146
1st Line - OSA146DAA58N
2nd Line - CABZE 0604EPAW
Current Overclock - 3.0ghz (300x10)
Voltage - 1.525V
Maximum tested Overclock - 3.15GHz (315x10)
Voltage - 1.55V
Cooling - Water (Swiftech Storm, Dtek Pro Core, D4 Pump)
RAM - G.Skill ZX 2x1GB
FSB:RAM - 166mhz divider
RAM Timings - 3-3-2-6 1T
Stability - Prime95 10 hours, SuperPI 32M, 3dMark2003,,05,06
I have a 144 CACJE 0602gpmw that does 2.83ghz @ stock 1.4v. I read it somewhere that the cacje has a cold bug at as high as 10c. That's only a problem if you do chill water or phase.
AMD Athlon 64 X2 3800 (Manchester)
ADA3800BVBOX
0601 LDBHEXPDW
Current stable OC: 2.90GHz @ 1.392V *Note Cool and Quiet enabled
Max stable OC: 2.95GHz @ 1.42V
Cooling: Thermaltake Big Typhoon w/ Panaflo 120mm
Motherboard: Asus A8N32-SLI
Memory: Patriot XBLK 512MB x 2 TCCDs 263MHz @ 2.5-3-4-7 Timing
*SP2004 30hours stable =>
DFI Lanparty UT SLI nf4 EXPERT
opteron 165 - ccbwe 0547tpmw currently 300x9 1.57 v 2700Mhz
Nvidia 7900gt
OCZ 2GB OCZ5002048ELGEGXT 3-4-3-8 5/06
PowerStream ATX 2.01/EPS SLI Ready 520W PS
Swifttech Apex Ultra+ water kit
Antec p180 case
maxtor 250g 7200 rpm SATA
x2 3800 manchester
OCZ4001024ELDCGE-K
1st line of OPN (ex: ADA3200DAA4BL)
2nd line of OPN (ex: CBBLE 0513DPAW)
2.5ghz
1.4
stock
its stable and i got 2-2-2-5 ram settings at 415mhz!!! i dunno if this is great but its defintely better than what i was able to get before
