That blue 1u firewall looks neat!
Please feel free to send me that 6 core/12gb desktop if you don't have a use for itI'll even pay shipping. You could say it's being donated to help people with severe dyslexia since it'd be given to my brother anyway
hehe.
Man things are really coming together on that project it seems. I may have an opportunity to do something similar for a small game developer here in Dallas. Waiting to hear back on the latest email.
It is a Barracuda 430. 6 WAN and 1 LAN. As far as I can tell, it is just a ITX board with addon card for the WAN nics. I have one at each site, they were purchased before I started for like $6k... Akkk.
We are moving in 6m-1.5yrs and our current building is a National Historic Landmark. I would have to get comity approval and pay for the condensers to be craned on to the roof.
Makes sense. I guess I am lucky, my building already has a chilled water system. All I had to do was tell the union pipe fitters where to run the lines.
I hope you are planning on getting a bigger alternator for that van, those power inverters can pull some serious juice. I would run everything with 0-gauge car audio power wire if it was me.
00 and 270amp custom wound alt, 200amps at idle. :-D
I also have a 300amp isolator, 3 more batteries, gauges, fuses, cut off switches, ect.
Sounds like you have it under control lol. I worked in a car audio shop in high school and helped build a spl competition van so i figured i would throw in my 2 cents.
Are you going to build a battery bank and use a battery isolator so the server system runs off a different power source than the main engine battery? that would be the way i would do it.
What are the models of those HP switches?
Spyder I hope this is something you can answer or give a give a idea to...but what is the deal with the van? I've never heard of somebody doing something like this in a van? I'm a bit confused as to the purpose.
If you can't answer, don't sweat it![]()
Easy answer, durability test rig for our plane mounted camera systems. Vibration/Mounts/GPS signal, ect. That and other cool stuff I cant talk about![]()
