More pics?
++1
More pics?
Pics are showing up here?
I have more! But no time. We bought a E350 van today. I get to put 3 nodes (72 cores/1TB ram/6TB SSD's), cameras, and a 3000w inverter/250amp alternator in it to power all of that. Should be a fun project!
it's weird, I think your host disabled your forum view and since you can see them it may be cached?
If I take the URL and paste it into IE, I can view it, but I can't do that for all the pictures haha![]()
It looks like I hit my viewing limit on IMGUR, which I do not see how is possible. Trying to decide if I want to host them myself or pay for the IMGUR pro access...
Tempted to toss it on a spare host at work, as this is work related and I could QOS it over one of my backup DSL lines.
might aswell. then you dont have to worry about paying for subscriptions![]()
Well google gives you 10 free gigs![]()
why do that when you could have terabytes for free?![]()
Photobucket.. Never had any issues to this day. I don't know if they still offer it, but I have unlimited storage for pictures with no cost
well in his case. it would be paid for by his workisn't free, because you still have to buyy the hardware back it up and provide a internet connection to it![]()
You have an awesome work enviroment+job it seems like.
Can't wait for more pictures
So how does the server perform with 196gb? is there a certain amount of VM's you guys are running with that amount of memory?
While I was installing the ram in the 2nd ZFS host, our AC kicked off. I decided to investigate... Darn it.
lookin good man! how much ram is in the ZFS boxes? those ssds should help for sure!
Go to a local HVAC ducting fabricator and have them spec you out a condensate pan in for the dimensions of your movincools footprint with the extra condensate pump. Have them weld the pan (welded is 10000x better), give it about 4" sides.
Then install a water alarm. Worst case scenario you just need to shop vac it up out of the pan.
The pan would be cheap too.
What are you doing with the thinkpads? T or W series?
How do you like them? I am thinking the W series will be my next laptop eventually.
