- Aug 5, 2013
Lightning would have been killer @ $700. :/
Mine drops by 15 MHz @ 72C (1469 to 1455) and then stays there.
Seems like an odd decision.
In my experience, I have had an H80 that worked for 4 years and is now sitting in a box. An H110i GT that died in 1 week but corsair did a very fast replacement. An H55 that I have on my classified right now that works perfect and an NZXT X31 that also is sitting in a box but worked perfect for 1-2 days that I used it. The NZXT X31 was getting to about 70-75 C due to poor case air flow and hence, I had to retire it.Well, got an NZXT X31... and it's defective
It's making horrible grinding noises at low speed, and LOUD buzzing at high speed. Basically 100% unusable.
Temps are better, but it looks like I need yet-another RMA... I've been through a pile of H55's and H75's for similar issues, so am I just really unlucky, or are all AIO coolers built poorly?
You must just have extremely bad luck or bad karma. Did you ever abuse computers in a previous life?Well, got an NZXT X31... and it's defective
Yeah... they all seem to have some kind of issue. Pumps that grind or buzz, pumps that die for no reason, coolant that never stops gurgling, air trapped in the line that never stops sloshing...You're the exact reason why I have yet to pull the trigger on AIO cooling for either CPU or GPU. Issues like this worry me and it always seems hit or miss on getting a decent one. Amount of issues you had in this thread alone is ridiculous.
Not a fan of the dual-fan coolers that OEMs have a habit of pre-installing on cards these days (AXC, TrwinFrozr, etc). They just blow hot air into my case and force me to run my other fans faster to compensate...When we still have nice air coolers, I still see no reason for the cpu barring fitment issues of course![]()
It says 750D in his sig.Is this a 750d or a 450d?
You can also easily tell by looking at the front of the case. The 750D has 3 external 5.25 slots where as the 450D only has 2. And the 750D has 4 USB in the front while the 450D only has 2.
Is there something that would prevent Adaptive Power mode from working?
In adaptive mode the clocks are supposed to scale down at low GPU usage. It was working when I first got the card, I switched to Max Performance for overclocking but I'd like to see what kind of impact Adaptive has. Now it's not working at all, both Adaptive & Max Performance are doing the exact same thing (permantly Max Performance mode).Just curious, what specifically are you showing with that screenshot? The low gpu usage or throttled clocks or both? My card was seeing lower gpu usage last night (77% ish) in some situations and I'm wondering what was causing it. I'll have to check and make sure Adaptive Power Management is set correctly in nv control panel.
I think he is asking why his gpu clock speed did not change even though the gpu was hardly being utilized at times.Just curious, what specifically are you showing with that screenshot? The low gpu usage or throttled clocks or both? My card was seeing lower gpu usage last night (77% ish) in some situations and I'm wondering what was causing it. I'll have to check and make sure Adaptive Power Management is set correctly in nv control panel.
I suspect it's something in MSIA / NVInspector forcing the clocks up. Reinstalling drivers would probably fix it but I don't really want to reset everything just to test it.
in every game and every scenario?
Really wanted a blue/green version... Just kidding.
I'm hoping more companies besides EVGA sell GPU's with worthwhile waterblocks in the future though.
Why 1405?I have now kept my cards stock clocked with only 25 MHz added to them so they boost to 1405 MHz at full load instead of 1380. Very happy with the performance of these puppies.
That is correct I can set either 1380, 1393 or 1405. I choose 1405 since that is where my cards start at default boost and then drop 2 buckets so the +25 covers this drop and cards start at 1430 but drop down to 1405 as temps stabilize.
I score 26K with classifieds at 1506/8200 and system in sig.
You should be hovering around 24K if your cards are overclocked to about 1350/1400.
