King_Weaver
- Nov 26, 2006
how hard is it to mount a fan on the accelero S1? also does it include enough ramsinks? Should I buy more sinks to cool the power circuitry? If so what kind of sinks should I get?
Ok so I havent really been following this thread but could someone list the coolers known to fit the 8800gt? Do any cool all the necessary circuitry in a single unit? (like the nv silencers)
lazy_weaver said:Ok, I know you have all been talking about all the various coolers available but I'm too lazy to read the thread. will someone summarize it for me?
fixed
Accelero S1 installed on my XFX 8800 GT and idle temps are 38 degrees and load 45
SOOOO much better.. oh yah 120mm antec fan installed.
Yup
What did you use on the RAMsinks?
fixed
are there any vga coolers than blow the heat out of the case like with the standard dual slot coolers ? It seems that all third party cooler just blow then into the case too
yes because everyone has time to read through 12 pages? I dont understand your attitude
Apparently Gainward are working on a passively cooled GT, a behemoth indeed
http://geforce9.com/forum/viewtopic.php?t=36
KW, lets examine how things look from his perspective...
From his perspective it looks like you think that your question isn't important enough to you for you to spend your time answering it (by reading the thread). Then you ask for him to answer it for you.
Why would this cause someone to have an "attitude"? Well, you just implied that his time is so worthless that he should spend his time to answer a question that isn't important to you.
Now, asking questions isn't bad; in fact it'd be a pretty lame forum if noone ever did. However, look at the type of question you asked. What's different about it and a question like...
"Hey guys, I'm wanting to OC, but I don't want my computer to sound like a jet engine. I know that coolers X, Y and Z will all cool like I want, but I can't find anything about how loud they are. Anyone use them and can talk about how loud they are?"
Or maybe like...
"I'm building a system with components X, Y, Z, I've already got this 300W Rosewill power supply. Is it enough or should I get something else?"
Now, compare that with a question like yours...
"Hey guys, could someone go through the thread and make a list of all the coolers y'all have mentioned and note which ones cool everything and which I'd need to get additional cooling to supplement?"
I'm not trying to rant or attack you or anything; you just seemed confused about why people would get annoyed with the type of question you asked, and as you looked like you'd be willing to listen to an answer, I thought I'd try to explain.
would it not have been just as easy to answer my question then to post flame?
No kidding.
Mt temps went from 92C (stock) load to 52C (713/1728/999) load
$24 total, got it in two days from SVC.
your totally wrong and maybe you should think about that... I never asked anyone to go through 12 pages and tell me what they found I was hoping someone who had been part of this thread from the beginning (that already knew the answer without having to read anything) could give me a little summary, in the form a simple, small list...instead I get people with attitude problems...would it not have been just as easy to answer my question then to post flame? You know we cant all follow every thread, if I did my gpa would drop and I would lose my job.
Or maybe like...
It does, but it performs worse than the ND1.
how is it 'totally wrong'?
and aren't you, by asking someone that has been 'part of this thread from the beginning' to give you a 'little summary', isn't that the same as asking someone to go through 12 pages and tell you what they've found? that's the exact same thing IMO
it's not like I asked anyone to write an effing term paper on 8800gt coolers
Installed accelero s1 and, like everyone else, found the RAMsinks to have crappy adhesive (don't they all *cough* HR-03 PLUS *cough*). I used some AS Ceramique as "glue" on one sink that absolutely wouldn't stay put - meanwhile I'm looking at it aggravated as hell b/c I'm hardly moving it...
My temps are 37C idle and 48C load w/o a fan attached. I think it is the superior cooling of my Silverstone TJ-08 that is keeping it this low. Oh, I also OC'ed it to 725/2020 while playing Crysis. Now if only I could get my damn e4400 to 3.0 Ghz (or my e4300 past 2.9 Ghz as well )...
Got the vf900 installed. The card is now much cooler, but it didnt want to oc much before, and it still basiclly the same. I tried a few different gpu/shader/mem combos, but each crashed in crysis. Though i hear a lot of oc's work fine in everything BUT crysis.
Anyway my card idles at 40c and loaded seems to be around 54C. Almost 25c improvement under load. Though i may be stuck around stock superclocked speeds.
whas a good after market cooler that doesnt require memory sinks, is there any that the heatsink it self cools the memory along with the chip.
I've never used Rivatuner, so I can't answer directly.Hi,
I've just read all the pages, I hope I keep my job!
Anyway, my BFG is going great, but I would like to use Rivatuner to increase the fan speed over the 29% pre set amount. It this easy to do?
Also, do you have to reinstall Rivatuner when the drivers are updated.
Thanks
Hi,
Thanks
