Modder man
- May 13, 2009
a 5770 would def be limited by an oc'ed pentium D would it not?
Yes. By a pretty good amount.a 5770 would def be limited by an oc'ed pentium D would it not?
You didn't read the chart.maybe. probably wouldnt be too bad as plenty of people ran pentium Ds with 8800GTs (myself included)which are roughly equivalent, but i would suggest upgrading as that is a brand new DX11 card with eyefinity blah blah blah and the pentium D is ancient and was never really a great architecture to begin with.
You didn't read the chart.It would take 2 8800gt cards to come close to a HD5770. Or roughtly one 9800GX2 (which I disagree upon, my 9800GX2 couldn't do much past 1600x900, while my HD5770 can still manage 1080p).
the kind of hyperthreading on the Pentium D is not going to help worth a poo in most gaming cases. in fact there is just as likely to be a negative effect in games. just to be clear the HT used on the cpus back then is not the same as on i7 cpus.mine has hyperthreadhing. its a 950. i kinda figure it will still be a bottleneck though. what is the test to see if it is cpu limited
lol, i thought that didnt seem right! actually i saw the 5770 mobility and the 8800gt next to each other. hahaha. yeah youre right, a pentium d will definitely bottleneck your 5770. wow epic fail.
The slightly faster Pentium D 955 (1066MHz FSB + 60MHz faster than D 950) holds back the old X1900XT.http://www.madshrimps.be/articles/a...Performance-Overclocking-Power-Usage-Review/4
I wouldn't bother with the HD 5770 on that system.
this is not an upgrade path i was planning lol, the rig in my sig died so i am trying to see what i can throw together with the parts i have layin around. i suppose i should try to find a newer processor.
i have a wtb thread and i have been looking for a q9xxx
The 1090T? All of that would still be under warranty I would have thought (And more to the point it'll be faster than a Q9xxx CPU to fit the old Pentium D system anyway). I'm confused as to what you're after here, a second gaming system?the rig in my sig died
did you even look at the review I linked to? the Pentium D 840 EE did not even provide 30 fps in modern games. and again cranking the settings in a game also impacts the cpu which be pretty clear as in many of those games the Pentium D could not even provide 20 fps even with a high end video card. trying to create a gpu bottleneck on purpose is silly when your cpu cannot even provide playable framerates. 20-25 fps with 8x AA at 1920 is no more enjoyable than 20-25 fps with no AA at 800x600 as neither is playable.Zarathustra[H];1036718142 said:Usually modern CPU's are not the bottleneck, video card are.
That being said, this is not a modern CPU.
My guess would be that if you turn all the graphics settings way up, you will not be CPU limited, but you might not like the frame rates if you do that
Even a modern low end Core i3 would be a significant upgrade over that Pentium D...
The only Pentium D that was worth it was the Pentium 955 and 965 which had Hyper Threading and was able to trade blows against the stock Core 2 Duo E6400 in everything
lol even the 3.73 965 EE with HT, the fastest Pentium D ever made, easily gets beat by the entry level 1.86 E6300 Core 2.![]()
I think everyone here doesn't understand that this CPU is 6 years old. It was meant to be paired with a 6800GT or an X800, not a HD5770.
yeah I was pointing out the shocking clock for clock improvements Core 2 made.
