- Jul 1, 2004
why is the Sony so thick? Even at 300W, it's still thicker than my current LED. Why can't these transparent OLED be available instead
Asus really taking their sweet time with PG42UQ availability world wide. If it just hit China add 2-3 months for North America.
I have a CRG9. Basically the same thing as your Neo G9 but with less curve, worse response times and crappy edge lit HDR. I went from that to the CX 48" mounted 1m distance away. After two years I'm back using the CRG9.Been tempted to get a C242 to replace my Neo G9, but then saw the Asus PG42UQ info. Really got me interested now, Premium cooling and custom heat sink for increassd peak brightness sounds enticing.
But is there any idea when they are coming out? Probably not anytime soon I guess, I am planning on getting a C242 in a few days if I do decide to replace my Neo G9 with it. Anyone else come the Neo G9 too can share their thoughts?
If you start missing ultrawide with the C242, just set it to 3840x1600. Boom, 21x9 ultrawide. Problem solved.I actually had a CX48 when I first bought my Neo G9. I agree CX48 was good, but I got rid of it because I still felt like 48" 16:9 display was a tad too large for gaming, plus I really love the immersive widescreen of the 32:9 Neo G9.
But after a year of use on the Neo G9, I am kind of missing the vertical space lost, hence looking at 16:9 again, and since C242 is actually available now, might be the switch I like. Not sure yet. But I am unsure though, because then I might start missing the 32:9 horizontal space lol I have to chose.
It's just that I feel the Neo G9 is too small vertically, every image ingame is just the same height as a 27" monitor. Too small for my liking.
True, suppose i could.If you start missing ultrawide with the C242, just set it to 3840x1600. Boom, 21x9 ultrawide. Problem solved.
21:9 is built-into the menu so no need to create custom resolutions etc. lolTrue, suppose i could.
VIewing distance is going to be very personal. Most likely you will want a deep desk or wall mount even for the 42" size. The size of these things is still pretty big so when combined it might be that you will find 125% scaling still more comfortable to see the whole screen without too small UI.Hi all,
Looks like I have a 42" OLED in my near(ish) future and just have a couple of quick questions. Apologies if this is not the correct place but didn't want to start a new thread..
What viewing distance would be the sweet spot for 100%? Have plenty of space but just need to size my desk accordingly.
Do TVs like the LG C2 have the same functionality as regular desktop monitors where they turn on once the desktop / laptop is woken up?
What's the best way to connect a USB-C laptop such that it's convenient to connect and disconnect (transition between WFH and WFO every other day) - do I need some sort of Thunderbolt dock or will USB-C dock work?
After prolonged use I'd be worried about leaving horizontal wear lines along the screen where the widescreen top/bottom are.If you start missing ultrawide with the C242, just set it to 3840x1600. Boom, 21x9 ultrawide. Problem solved.
I honestly don't think that's much of a problem.After prolonged use I'd be worried about leaving horizontal wear lines along the screen where the widescreen top/bottom are.
In the same way as vertical lines when regularly watching 4:3 TV.
Limit this problem by displaying a grey border of intensity similar to the brightness of the video source.
I'm not a fan though, I'd want the true black that OLED is famous for.
Or strictly limit the % of time the screen is used in this fashion.
This is how I used my plasma, it saw a lot of use for 16:9 TV, much less time for films or 4:3 TV and about the same for PC gaming.
Probably 6:1 TV vs other uses.
It didnt exhibit any problems.
If the display will get very little use other than partial display I wouldnt risk it.
This is what the pixel refreshing algorithms are for. It 'evens out' the wear (variance) between pixels.After prolonged use I'd be worried about leaving horizontal wear lines along the screen where the widescreen top/bottom are.
So there is no native support for it from the TV itself?you can try some of the utilities from this topic https://www.reddit.com/r/OLED_Gaming/comments/mbpiwy/lg_oled_gamingpc_monitor_recommended_settings/
specifically "LGTV Companion: Synchronize power state" https://github.com/JPersson77/LGTVCompanion "Power On and Off WebOS LG TVs together with your PC"
(I don't know if it works if you just put your pc into sleep vs fully shutting down)
here is the readme, I didn't read most of it https://github.com/JPersson77/LGTVCompanion#readme
its not like i want the feature anymore anyway - sometime recently in win 10 ms broke monitor sleep so that it also disconnects remote shares on the system with the sleeping monitor(nothing else enabled in power options)!So there is no native support for it from the TV itself?
how come? what's the reason for no refund / exchange?Oh man, I am so torn between the C242 or the Neo G8 for HDR Gaming!
I have been researching them both for days and still I really can't make my mind up lol it's driving me krazy.
And buying displays in Australia sux, because we can't return them once they are opened like you guys in the US can.![]()
In Australia, we cannot return electrical, computer etc goods once they are opened unless they are damaged/faulty.how come? what's the reason for no refund / exchange?
If HDR is a priority the C2 wins by a mile. The G8 looks lifeless in a lot of games compared to it. There really hasn't been a single game where I've thought the G8 has superior HDR compared to my C2 (more like it's close on rare occassion and other times no where near).
It's advantage is really only the 240hz and PPI + text quality. C2 text quality looks like but cheeks after you've gotten use to the G8.
A combination of both would be my ideal monitor but of course it doesn't exist so the choice is 1 or both.
Neo G9 HDR is "ok" but Neo G7/G8 is considerably more dim. Rtings measured the same highlight on both for their "real scene" and the Neo G7 was almost 400nits less bright. Not to mention 50% window which is probably the only relevant big window size is also 300nits lower. All I'm saying is to the eye, the G8 in its current state of HDR is not far off OLED brightness except without any of the benefits of OLED and far worse color and EOTF tracking. Rtings measured their 42 C2 in Game Optimizer which is a bit more dim than other picture modes. TFT measured Standard and Filmmaker for comparison.In Australia, we cannot return electrical, computer etc goods once they are opened unless they are damaged/faulty.
But I have Neo G9 and I think HDR is amazing on it. I am just getting tired of the narrow vertical height, hence want to go bigger that way.
And does the peak and sustained brightness on the C2 suck or is it still good enough?
Now this is what I put at the top of the list of mostly prefered for me. So I think I may yet pick the C242. Gonna think it over some more.The difference in game is not really noticeable to me between the two and I prefer the larger 42 size for IMMERSION but on desktop the G8 is definitely sharper and clearer.
I also just saw a review of the LG equivalent measuring over 1100 nitsI think I'm going to be obnoxious and stack my C2 above or set it to the side of the PG42UQ once it releases. 138hz, DP and relaxed ABL as well as potentially being as bright as the 48" is too enticing.
I checked out someone's 48" OLED monitor version from LG and the matte coating really didn't bother me. Only problem is a matte + glossy display together would be gross.
What display is this?I also just saw a review of the LG equivalent measuring over 1100 nits
I think Q4 / early 2023 at which point might as well see what LG is announcing for 2023 in Jan.it's now the end of July, I guess Asus is not going to get this out in North America in July
My neck grows 2 in. longer waiting for this, if they drag on 3 more mth., I'll be a giraffe
I have the 3420DW, not the 3423DW. Not HDR on the 3420DW.Going by rtings review, I assume you feel the C2 is slightly brighter in HDR than the AW3423DW?
