I must be doing something wrong if my sli 570's are giving me 2000 score less. I can only hope its due to 3d mark not recognizing the cards lol.
P5235 with my single GTX570 / i7 860 @ 3.8. That seem decent? (no OCing on the card yet)
http://3dmark.com/3dm11/115592
Seems decent to me since I can't break 5600 with 2 570's & 950@4.0
You sure about that?Generation/platform of CPU seems to have a MASSIVE affect.
Seems 3DMark 11 doesn't really care much at all...Okay -so here's the test results for running my i7-920 + GTX460 rig at the slowest CPU clock speed I can. 1.6 Ghz. The video card is the Galaxy GTX460 Super O/C and I didn't mess with it to underclock or overclock for either test -- everything in the drivers default win7 x64 install.
I7-920 at 1.6Ghz with GTX460 and 12GB of RAM - BCC at 133mhz x 12 multiplier
http://3dmark.com/3dm11/85290 - resulting in 3547 score
I7-920 at 4.0Ghz with GTX460 and 12GB of RAM - BCC at 200mhz x20 multiplier
http://3dmark.com/3dm11/38694 - resulting in 3850 score
So at 2.4Ghz less I get within ~300 points of the same score on the same machine
about clock speed? or cpu generation/platform? You can't always equate the two![]()
You really think a Core i7 at 1.6GHz is faster than the 3GHz+ Core2Quads and Phenom II X4's flying around here? Really?
If it's rating name/generation over the actual performance of the chip, than this is a worthless benchmark even for comparing against its own scores.
Depending on whether cmay run his card at stock or oc'd for that bench would be helpful to know. If he run stock I'd stand by my initial statement.
Here's a compare between my OC'd 460 and his 5870, and considering my card is at a 20%+ overclock his 5870 performs well (if it's at stock).
Here's a direct compare over at Anandtech - http://www.anandtech.com/bench/Product/162?vs=180
Bearing in mind also that at higher resolutions cmays 5870 would pull ahead even more.
I'm impressed with the physics score his similarly clocked i7-950 puts out compared to my Q6600. Obviously his i7-950x is newer and cost more but it's still impressive.
You should be able to run the same benchmark on two systems and be able to tell which one scored better.First, benchmarks by definition are not 100% reliable. Why should this one be any different?
No, and I never said they would be the same. The 1.6GHz Core i7 would be slower than the 3GHz+ Core2Quad in pretty much everything except memory bandwidth.Secondly, you really think that Core i7 at 1.6ghz is the same at 3ghz+ C2Q? Really?![]()
can anyone give scores of an 58xx card with/without a dedicated PhysX card?
on my GTX470 score around P5600
Shouldn't make a blind bit of difference as it doesn't use PhysX, it uses bullet physics instead.
