Or maybe just release a driver that doesn't have random flickering issues.
strange as I have yet to see that on my 120hz eyefinity set up.
The question for me at this point lies in whether AMD will be able to beat Titan X with a single GPU card, or will the 390x actually be a dual-chip card as the recent rumors suggest. If it's the latter, and they need dual chips to beat Titan X, AMD has failed in my view.
What we might be looking at is a situation similar to HD 3870. That card was significantly slower than nV's top-end card at the time (8800 GTX), so ATI came with a dual-chip 3870 X2 solution to take the crown - then nV responded with 8800 Ultra. In this situation, we might see the following performance hierarchy: GTX 980 < 390 (single GPU) = GTX 980 ti < Titan X < Titan Ultra =/< 390x (dual GPU) -- you can extrapolate potential retail price from there.
I guess AMD doesn't want our money. This quiet crap is really annoying. I almost think its a game now.
End of 2011 with GCN and it is arguably the best GPU architecture we have seen to date.Whens the last time amd released a card with brand new architecture? Anyone know off the top of their head?
Yeah the life span / relevancy of the 7970 is ridiculous. It's AMD's 8800 GT.
If AMD holds true the promise of more regular updates, and smaller performance jumps, it could get worse.
No.
Don't know.
It was pretty much the most solid info this thread has had in the past month.That was easier than going through 10 pages thanks
We are stuck on 28nm since 2011.
Good to see aftermarket coolers this early. Want to see the 390x's aftermarket coolers now -- or will it only have closed-loop WC?
Not sure how trusted this site is but:
http://www.kdramastars.com/articles/80987/20150408/radeon-r9-390x-release-date.htm
Are you seeing the same two pictures that the rest of us are seeing? Neither of them show the PCB.PCB looks very clean without the VRAM chips.
See the little white bits where RAM is normally located? Those are thermal pads, and if you look a bit more to the right, you can see where a heat spreader is attached to the PCBIn the top view, you'd be able to see edges of the chips (or their HS contacts) if they were there:
As it is, it looks like the memory chips are (expectedly) gone where they are on off-die memory/non-HDM cards.
thanks
define:a card that can't play any modern game above 3fps but can output 4k 60hz resolution via hdmi 2.0 port and play video files .
You really linked a Korean Drama Masters website........................
Are you sure thats a 390? That looks like an 8 to me...
Look closer...
Note: Due to images being of really low quality, it was hard to figure whether the card was actually a R9 390 series or R9 380 series cards. While we were led to believe it as the R9 390 at first sight, turns out to be that the graphics card is actually the Radeon R9 380 series from XFX. It was clear misunderstanding of the card due to the low quality label at the side and there are several details which suggest that the card is based on the Hawaii graphics processor as indicated by our Disqus community. The update doesn’t mean that this is not a Radeon R 300 series cards. It is an actual card from XFX and we will be looking at the same design going on retail in a few weeks for the Radeon R9 380 and 390 series cards. The graphics card shares the reference Radeon R9 290X PCB which suggests this is a rebranded Hawaii core which will be placed in a competitive price range since Hawaii has a lot of muscle left to stretch out on 4K gaming. We will obviously be getting a flagship R9 390 series card around the same time as the rest of the R300 series cards and we will update you as soon as we get more info related to the cards.
