Comixbooks
- Jun 7, 2008
If you own one post pics benchmarks or if you have been waiting around since Aug. 20th.
Mine should be here today
Haven't really benched but I have clocks stable at 2085MHz (+110/+700) using AB.
EVGA 2080Ti XC Ultra Gaming with EK Block
I'm very intertested to see how the downclocking goes on your card. Also if you could post temps at idle and load.
Man these cards get pricier and arrive with longer and longer delays ever generation.
Got the cards in my system. Nice boost in 3dmark.
However, I've gotten some crashing with 3dmark and Superposition too. I really hope it's a driver issue and one of my cards isn't messed up.
Interesting. We have very similar systems, but you got a much better score. I wonder if this is due to rendering non-native resolution and or a Surround bug, are you on a 4k monitor?Here is my superpostion at 4k
It may be a PSU issue. Saw some people on Reddit talking about issue with Corsair power supplies, which I have and it looks like you do too. Not sure yet, but I'm trying to see if there is anything I can do.Its defiantly the drivers....they are very crashy
Never had a crash with the Titan X Pascal in my ITX rig, but had
several today with the 2080ti :-/
Got Superposition to finish this time at 4K. I think it was some weirdness with SLI/Surround, as I got better GPU utilization (and performance) with 4K rather than 1080p.
Yes, the thermals were crazy after looking at it. When I touched the top GPU it was PIPING HOT. OMG, I think I burned my finger.Are you hitting thermal limits? 86C seems high?
I think the card was overheating, I'm not 100% sure if it was something with the PSU or not. Following the Reddit thread, I downloaded Corsair Link (I had to open the case and run a USB cable from the PSU) and I turned off OCP for all the cables in the PSU configuration. That alone seemed to help (for example Catzilla would get a little further, but still crash). So I downloaded the beta for MSI Afterburner and set an aggressive fan profile (50% at 30C up to 100% at 70C). You need the Afterburner beta, older versions can't control the fan on Turing. I noticed the fan is not nearly as loud as the Titan X (Pascal) was, even at 100% it's okay. The default fan profile is junk, though, so do set your own. Oh, and I also pushed in all the PSU power cables, there was one that was kind of loose, but I don't think that was it.Damn, I hope its not the PSU. I do have an antec 1200 "Circuit Breaker Tripper" PSU in the closet that would make sure the 2080ti is well fed.....but it won't fit in my gawd damn itx case. I was able to game the last hour or two without any issues, but will test more as time goes on.
Yea....I have been using the new precision x1 with the Scan OC. Crashing problems went away when I upped the fans. I can't get riva tuner to work with precision so will give the MSI AB beta a try.Sorry, just talking about all these problems. Forgot to post a pic of the bad boys in my system (ignore the poor cable management, no window on this machine).
Everything seems working well now. I played a bit of Dying Light, getting great performance triple 1440p high settings over 100fps. This was one game that was struggling a bit before and now is super smooth.These GPUs look pretty crazy in SLI, let us know how your experience with that goes!
I guess I cant hang out in the ballers club. lol
I think the pricing meets what might be terrible yields. They are consistently out of stock everywhere concerning the 2080 ti. The regular 2080, not so much.
Is it worth it to go from the 1080 ti to a standard midrange cooler RTX 2080 when running 1440p?
I been using AB beta since I got my card last week and haven't ran into any issues.
Same here. I tried Precision and had some issues then went back to AB and had none.
