2080ti 2080 Ownership Club
Discussion in 'nVidia Flavor' started by Comixbooks, Oct 5, 2018.
  1. vxspiritxv
    vxspiritxv [H]ard|Gawd
    1,452
    Feb 10, 2001
    https://www.3dmark.com/3dm/29129917?
    No overclocking, g-sync on (because that's how I play my games)
    100hz 3440x1440 display
    Dell T7810 - 2 * E5-2673v3 (go find these on ark lol)
    cybereality likes this.
  2. NKD
    NKD [H]ardness Supreme
    7,314
    Aug 26, 2007
    Meh. I was just joking and it was sort of like a sign of respect while joking. There are plenty of other threads to bitch about price. This is about ballers club. lol
  3. Dayaks
    Dayaks [H]ardness Supreme
    6,467
    Feb 22, 2012
    Seems like the cool kids are doing Galax 380W bios flashes. I am going to try just the shunt mod to start.
    Bios flash is pretty safe. Don’t shunt mod unless you understand what is happening. You don’t want to do the PCIe slot.
    Also seems like FE cards can’t be BIOs flashed. If true those guys would have to shunt mod.
  4. cybereality
    cybereality 2[H]4U
    3,759
    Mar 22, 2008
    Okay, these cards are beasts! Running Far Cry 5, High settings, 7680x1440 res, and getting around 90fps outdoors or over 100fps indoors. Amazing!
    Also tried some older games and getting 141fps locked (due to my frame cap) with no dips. F.E.A.R. 2, Half Life 2 Ep1.
    Porter_, Montu, Comixbooks and 2 others like this.
  5. iamjanco
    iamjanco Limp Gawd
    438
    Jul 8, 2016
    Hi guys--I usually hang out in the news part of the forum here, but figured I'd drop in and say hi.
    Anyway, I was going to go with the FTW3, but by the time I paid for it, the sales tax, and a block, I would have been at $1660--, so I took advantage of another opportunity that was ~$140 on top of that. Made things a bit simpler that way.
    I guess it's okay for me to join the "club" now (tentative shipping date Oct. 19th):
    Porter_ and Maddness like this.
  6. Montu
    Montu [H]ard DCOTM x4
    7,785
    Apr 25, 2001
    Here's my system with the RTX 2080 Ti FE installed. Love this card.
    Welcome to the club!
    Maddness likes this.
  7. NKD
    7,314
    Aug 26, 2007
    Jesus 1800! LOL! Aren't these things power capped?
  8. Dayaks
    6,467
    Feb 22, 2012
    I was hoping it’s not USD. The power caps can be fixed.... but yes everything I’ve seen they are at least slightly power capped. (0.5% to 5%). Not super bad.
    I just wonder if it gets worse when RTX is enabled. Unless RTX reduced the CUDA usage....
    I know the GALAX has a 380W and is the highest so far. That’s a good bit if power.
  9. iamjanco
    iamjanco Limp Gawd
    438
    Jul 8, 2016
    Thanks for the welcome, guys.
    It's my understanding 2080s are typically power capped, but Galax gets around it using 16+3 phases, higher end components (e.g. Jap caps and mosfets), and a heavy duty pcb (unsure of the number of layers there and the thickness of the copper in them). They're also supposed to ship with two versions of the bios: the 380 as already mentioned here, and a 525 version for those willing to pour. Power feeds are done by way of 3x8 12 volt inputs.
    No official word on the actual boost clock yet, but Galax claims to be working on something higher than 1680 as noted here and there on the enthusiast sites.
    Oh, and yep, that was $1800 US smackeroos. Don't get me wrong, I'm not rich, but I do like my toys.
    On a different note, was investigating the possibilities for others as far as hardware flashing goes for the FEs, but that's pretty much come to a halt for now as there's just no Turing bios editor available yet. Even if there were, noone knows for sure yet how the lockdown in FEs really works. There's plenty of talk about the bios being encrypted, but there's also the notion that NVidia might have added something extra to those cards to ensure a bypass doesn't work. If anyone here has come across anything along those lines, it'd be nice to hear about it.
    I do know that some with various brands of AIB reference cards have been able to flash their bios; while others haven't been that lucky yet.
    Dayaks likes this.
  10. Gideon
    Gideon [H]ard|Gawd
    1,882
    Apr 13, 2006
    So it draws power like a 290X. Would be nice to see if RTX features draw even more power or cause the clocks to drop, one would figure it has to use more power or something has to give for it to keep the same power level.
  11. Dayaks
    6,467
    Feb 22, 2012
    It draws a lot but you get performance in return. Anything draws a lot when you OC it. My Titan Maxwell drew 400W OC’d.
    But yeah the die is more than 50% larger than a 1080ti/Titan Xp (and 300% more transistors than a 290x). It’s going to pull some watts if you’re using all of it.
  12. sk3tch
    sk3tch [H]ard|Gawd
    1,448
    Sep 5, 2008
    Received my 2080 Ti FE on Friday - pics and benches:
    Intel i7-5960X CPU @ 4GHz (Corsair H110 280mm Liquid CPU cooler with 2x Noctua NF-A14 iPPC-3000), G.SKILL Ripjaws 4 series 32GB 2800MHz DDR4, NVIDIA GeForce RTX 2080 Ti FE (No OC), Samsung 950 Pro SSD (512GB), Samsung 850 Pro SSD (1TB), and a 4TB Western Digital Black WD4003FZEX 7200RPM HDD on an MSI X99S XPOWER AC motherboard inside of a Cooler Master CM Storm Trooper full tower – powered by a Corsair AX1500i power supply (1500W; fully modular) with braided cables.
    I play on an Alienware 34 - 3440x1440/120Hz - looks like I may delay my CPU upgrade again...we'll see when the i9 9900K drops.
    Time Spy 1.0 - 12,473
    https://www.3dmark.com/spy/4620669
    Time Spy Extreme 1.0 - 5,797
    https://www.3dmark.com/3dm/29160641
    Fire Strike Ultra 1.1 - 7,895
    https://www.3dmark.com/3dm/29160902
    Fire Strike Extreme 1.1 - 14,581
    https://www.3dmark.com/3dm/29161113
    Couldn't bear to let go of my MSI GeForce 1080 Ti Lightning Z - so the secondary rig got a PSU upgrade from the garage (Seasonic X-1250 Gold) to accomodate it (5820K @ 4.2GHz, 64GB DDR4):
    http://sk3tch.com/images/hardocp/1080ti_rig.jpg
    Johnny_Utah, Sprayingmango and Dayaks like this.
  13. Neon01
    Neon01 Gawd
    1,023
    Jan 22, 2008
    Got my Gigabyte 2080ti Gaming installed the other day, and I'm loving it. Finally, 4k60fps is here, without compromise! Been playing back through the Witcher 3 and I'm just loving the silky smooth experience with full graphical goodies. In fact, I found I didn't even have to OC it to get a very stable 60fps - even at that rate my GPU usage hovers around 90%.
    Messed around very briefly with a mild OC (+120 core, +440 mem over the slight OC the card has - which I believe is about 30 hz higher than the FE). No issues looping Heaven benchmark and did result in a good 9-10% fps boost. However I noticed some odd screen flicker in The Witcher at these settings (only during cut scenes, oddly enough), which I assume is some mild artifacting? Could this be the memory OC? I've seen folks boosting the memory clocks by +700hz, so I figured my settings would be very conservative. I haven't done a lot of trouble shooting, and having really tested other games or anything, so I'm taking it with a grain of salt for now. Probably will also try running without AB turned on to see if that's mucking anything up, and give the other OC utility a shot as well. Anyone else experience anything like this?
  14. AORUS
    AORUS Limp Gawd
    439
    Oct 31, 2017
    that's not real benchmark 4k test on the RTX that is just online results NV called Turing the most powerful GPU and you have the textures set to high on this test with 2x cards?
  15. Dayaks
    6,467
    Feb 22, 2012
    You know... owner threads are for owners not trolls.
  16. cybereality
    cybereality 2[H]4U
    3,759
    Mar 22, 2008
    This thread is for owners only. If you want to hate, there are dozens of other threads.
    GoldenTiger, Krixon and Johnny_Utah like this.
  17. AORUS
    AORUS Limp Gawd
    439
    Oct 31, 2017
    It's just a Thread not own by any member only Kyle_Bennett make the rules So now hate is when you call someone funny guy/girl? now day's when you don't know sex is but they can name call you a troll to start argument Wow
  18. AORUS
    AORUS Limp Gawd
    439
    Oct 31, 2017
    So now you are following me around? I must be so popular I might sign you book if you ask me nicely :)
  19. cybereality
    cybereality 2[H]4U
    3,759
    Mar 22, 2008
    Please, just leave.
    Stryke1983, Dayaks and Krixon like this.
  20. Dayaks
    6,467
    Feb 22, 2012
    Well I used the ignore button for the first time on [H].
    I ordered a new pump/cpu block to go with my EK 2080ti block. Super excited!!
    sk3tch, Porter_ and cybereality like this.
  21. GoldenTiger
    GoldenTiger [H]ard as it Gets
    18,166
    Dec 2, 2004
    Same here. (on ignore).
    Dayaks, Porter_ and cybereality like this.
  22. l88bastard
    l88bastard 2[H]4U
    2,477
    Oct 25, 2009
    Nice! I may WC mine.....or move my PC into the other room lol
    Really loving the Predator X27 + 2080ti 4k144 HDR Gsync cccccombo!
  23. Dayaks
    6,467
    Feb 22, 2012
    Yeah when the X35 releases it’ll be a hard combo to resist. I am afraid of the price!
    I did have my PC in my basement for a while with a pretend case upstairs (so the wife wouldn’t catch on).
    WC probably isn’t worth it unless you plan to power mod in some way... I have my loop dump into my pool in the summer so it eventually pays itself off. Some people do it for quieter operation but a USB and Dport extension cable can do that too.
  24. NukeDukem
    NukeDukem 2[H]4U
    2,231
    Feb 15, 2011
    I'm going to settle with +110/+675 offsets for my Zotac Amp Ti. The core boost fluctuates all over the place from 1965-2145MHz depending on the game and how much it's getting taxed. Overall I'm happy and it's a nice end-game card for my 1440p 165Hz monitor. (y)
    Porter_ and Dayaks like this.
  25. TahoeDust
    TahoeDust Limp Gawd
    485
    Dec 3, 2011
    I'm super jealous of the fun you guys are having. I'm impatiently waiting for my FTW3.
    Brahmzy, Maddness, iamjanco and 4 others like this.
  26. Neon01
    Neon01 Gawd
    1,023
    Jan 22, 2008
    I'm on the fence. My original intent was to WC the 2080ti. I've got a pretty good WC setup with some hefty rads and several GT fans, but since I didn't have a WC block at hand when I got my 2080ti, I decided to install it and just bypass the GPU. Honestly, the triple fans on the Gigabyte Gaming 2080ti are so quiet I can't hear them at all, even when overclocked for a solid 45 min gaming session, and I have my GT fans turned pretty far down. I'm sure any other triple fan setup would be similar. The fan speed never goes above about 70%, and its very quiet at that. As for whether I could unlock more potential with water cooling, I don't doubt it if/when custom bioses are developed to unlock voltage, but barring that I'm not sure if I'd be able to get more than a couple frames above what I have now. Given all that I'm really wondering if it's worth bothering with the WC solution this time around. Dunno, still thinking on this one.
  27. Neon01
    Neon01 Gawd
    1,023
    Jan 22, 2008
    Sooo, it is?... or it isn't? When trolling, it's better to at least be consistent.
    For most reasonable people out there, it was understood that this represents the first card where 4k60fps is possible in practical terms (with VERY few exceptions) for hardware marketed to the consumer market. Keep trying though; I'm entertained by your presence here.
  28. l88bastard
    l88bastard 2[H]4U
    2,477
    Oct 25, 2009
    Yea, but I am "pressed" for space in my ITX rig and those 2.75 coolers are a bit too wide for me (that's what she said)
    I have a HUGE mountain mod UFO case + a car size radiator sitting around.....but sorta wanted to go tiny for this rig-build-o-round. So my options are keep the stock FE cooler and wear headphones, move it to the closet, WC it, or wait and see if aftermarket triple fan two slot air coolers come out from arctic.
    iamjanco and cybereality like this.
  29. Randall Stephens
    Randall Stephens Limp Gawd
    286
    Mar 3, 2017
    Love the look of the build, but man, talk about hot air re-ingestion with that tight clearance.
    sk3tch likes this.
  30. pippenainteasy
    pippenainteasy Limp Gawd
    509
    May 20, 2016
    Does gsync take a huge hit on games or is it enabling vsync as well? Isn't 14,000 a normal score for the 2080 Ti? Seems like a 25% performance penalty? That seems pretty high.
  31. cybereality
    cybereality 2[H]4U
    3,759
    Mar 22, 2008
    No, G-Sync should not have a noticeable hit to performance. If there is a cost, it's probably very small, at least I've never encountered an issue.
  32. cybereality
    cybereality 2[H]4U
    3,759
    Mar 22, 2008
    I noticed I was getting crashing after installing Geforce Experience to try video recordings. Wasn't able to get it to record Surround, but in the process Far Cry 5 and other games were crashing. I disabled the GFE on-screen overlay, and so far things are fine.
  33. Neon01
    Neon01 Gawd
    1,023
    Jan 22, 2008
    Looks beautiful, and I can certainly understand the desire for a smaller solution...my Corsair 900D is basically a poor man's mountain mods case.
    Dunno much about how well they cool, but I'm pretty sure the Windforce (NOT the gaming model) Gigabyte 2080ti is only a 2 slot, not 2.X slot, for what it's worth. Again, not sure how it would compare to the FE since neither exhausts to the exterior, but at least you'd have more fan area.[/QUOTE]
  34. l88bastard
    l88bastard 2[H]4U
    2,477
    Oct 25, 2009
    Hot air re-ingestion was less of a factor when I had my "BLOWer" Titan X Pascal in the rig.
    Im running a 5ghz OC on the 8700k. But temps have not been an issue for the CPU or GPU....however, I do have to run the 2080ti at 100% fans to keep 2000mhz & temps under 80c
  35. cybereality
    cybereality 2[H]4U
    3,759
    Mar 22, 2008
    Okay, so these cards are serious beasts. I spent quite a lot getting two RTX 2080 Ti's, but the performance is phenomenal.
    I can finally play new games at 7680x1440 with High+ settings! Well, I had done it before, but it required Medium settings, playing older games, etc. Now there is no compromise.
    Here I played Far Cry 5, Shadow of the Tomb Raider, Watch Dogs 2, and Project Cars 2. Overall I was getting in the 80 - 90 fps range with High settings. Project Cars 2 was an outlier, around 150 fps on Ultra settings.
    For G-Sync this is just about perfect. 90 fps is the sweet spot to feel smooth and playable. I can still notice a difference with higher fps, but above 90 they're diminishing returns. So that's fine for me.
  36. xorbe
    xorbe [H]ardness Supreme
    5,968
    Sep 26, 2008
    Superposition 4K + extreme
    14.89 fps avg
    Hah.
    (edit: 5GHz 8086K, 2x16GB DDR4-3200 CL14, stock 2080 Ti FE)
  37. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,264
    Oct 5, 2004
  38. TheMadHatterXxX
    TheMadHatterXxX 2[H]4U
    2,859
    Sep 7, 2004
  39. vxspiritxv
    1,452
    Feb 10, 2001
    I actually ran it again without gsync and got slightly lower score (likely because I had a few background apps at the time). Reason I ran it again was because userbenchmark.com score was very low, due to FPS in that app being 5x what the monitor is capable of. My score is expected to be lower than most for 2 reasons. My processors max speed is 3.1ghz after turbo boost (on 2 of 12 cores) and it's dual cpu where I don't bother to lock the affinity to the cpu with the pcie lanes. I'm still getting double the FPS in everything vs 1070 I had previously so I'm very happy.
    1070 http://www.userbenchmark.com/UserRun/11153736
    2080ti http://www.userbenchmark.com/UserRun/11294991
