Given that the average human reaction time to visual stimuli is around 250 ms, I don't think that an extra 15 ms is going to make a world of difference in practical application. The primary enemy of online FPS these days is low ticrates.I only consider <5ms input lag acceptable for fps games. Which is why i still use a gaming monitor.
It's exciting to see improvements in the OLED segment though.
Well the new Samsung Qled
I think most people's issue with the input lag is because they press a button and notice the delay in the action happening on screen. It happens to me when playing fighting games on an LCD vs a CRT. It's not an issue of reacting faster, but it throws off your timing when the button presses are delayed on the screen.
I love all of Samsungs mumbo-jumbo. Samsung, it's just an LCD TV.
Yes. The hdtv test video shows some good details on the LG 2017 OLEDs. With the input icon switched to PC you get 4:4:4 chroma support with input lag at 21ms, if you want HDR also enabled, you'll have to switch the picture mode to Game which retains the 21ms input lag.Anyone here have one of these yet? There is an owners thread on AVS now and people are starting to give first impressions.
Ziran, I don't own an OLED but I recall reading that the dimming can be disabled in the service menu.
Bad cleartype is worrisome though. Do you do any scaling? Spending long hrs every day reading lots of text is probably my primary use.
CONS:
The second thing it does which is much more annoying is slowly dim the screen if the screen total brightness has not changed over 60 seconds (i.e. you have a mostly static image displayed). This is not an issue in gaming, movies or internet viewing, but it is really annoying for productivity scenarios where you are working with text windows that do not change much (scrolling text is not enough to stop ABL since it measures total brightness). The screen dims over time and its really annoying. I have combated this by setting my desktop background to change every 60 seconds. But this only works if your productivity application does not take whole screen
It just followed me home like a lost puppy. I tried to talk myself into a KS8500, actually had one ordered this morning but they jacked the price up $100 at the last second so canceled it. If there were any in store I would probably just get one. I've wanted an OLED for so long I had to see if its actually viable for everyday PC usage. Only done the bare setup. Still not getting a signal from my U-Verse box for some reason. Finding 150% scaling in Windows seems to work very well. Cleartype is pretty garbage at 100% scale but perfectly readable at 150%. It's a beautiful set, hopefully its still a keeper after a few days.
Thanks Ziran!
I had most of that set but was using a expert dark config. Still kind of confusing on if you get the 21 input latency on just setting it to PC icon or if it has to also be in Game mode? If it doesn't have to be in Game mode to get 4:4:4 and low input lag what does it gain you using that mode in Windows? You loose the option to set some of the options when in game mode.
Most of the movies I watch are down*cough*loaded so I want to keep some decent visual quality in PC. I tried those settings in Game mode, got pretty comparable visuals in Windows except the Brightness 50 turned my solid black background grey. Going down to 40 fixed that but watching some good 1080P movies didn't look as good.
Using Picture Mode Expert (Dark Room)
OLED Light 60-100 (trying to not run it at as low as I can most of the time)
Contrast 85
Brightness 50
Color Gamut Auto
Gamma 2.2
Black Level Low
I switched out the hdmi cable on the cable box and that got me signal. I used the same kind though and noticed they are labeled source and tv so might have had the first one plugged in wrong. Never paid attention what end of an hdmi cable was plugged into which.
Microsoft Research have a video which is a great demonstration of latency:It is a common misconception to compare human reaction times to whatever the input/network/pixel response lag happens to be. For online gaming and competitive gaming, where contestants compete against each other on reaction times, all the times add up, and the contestant who has the fastest reaction time in this whole pipeline of delays, be it 1.0ms faster, is statistically better off to win, because 250.0ms is still smaller than 251.0ms. That is why minimizing all sources of delays are considered important, and the online player without that extra 15 msec of delay is statistically better off, even though he might not be able to visually discern whether he has that 15 msecs of delay in effect or not. This is true even if game update rates or other network processing rates are heavily quantized to e.g. multiples of 10/20/50msecs, since these are two independent edge triggered events that are not in sync. Agreed that low networking update rates are a big potential source of variance to latency, though that does not preclude seeking to optimize other sources of lag.
If you leave the icon as default "HDMI" you are going to get 4:2:2. To get 4:4:4 you have to switch the input icon/type to "PC"
Setting the game(user) mode disables most of the processing options but gives you the lowest input lag. Some of these options are nice for movie playing (removing judder etc). So you can either switch between game and others or you can use the TVs internal player to play movies (yes it handles .mkv just fine). I set up my Synology NAS as a video station and the TV can access that directly over the network. The internal player also handles HDR and 10/12 bit content correctly (which Windows players tend to not support properly).
wow the picture quality is stunning (I'm coming from a Panasonic VT30 plasma)...black levels are literally pitch black and perfect...colors pop off the screen...this is the best picture quality hands down (
I can attest to that too. Best image quality for computer use. No contest. Best monitor, since the death of CRTs.How funny that your words sound like me earlier these year when I used for the first time my 65" B6 OLED TV. Up to today I think the same and I enjoy it every single day!
Man, since the day I bought it I've been running it at oled light 35 and below. I use it for browsing day and night - never seen the ABL not a single time.Loving this thread so far. I bought and returned a 2016 B6 because the ABL (Automatic backlight) would fluctuate too much. The picture quality blew my mind. I plan on getting a C7 assuming that web browsing will be a more stable experience. Even in games like Dragon Age inquisition I found the ABL would bounce around too much.
I've heard if you set the OLED light to 34 then ABL won't change, can anyone confirm this?
Also, for those of you running the OLED at 100, do you see a lot of ABL fluctuation in games, browsing, etc? This will be my primary computer display. I hate LCDs.
They need to hurry up and get HDMI variable refresh monitors out. This won't be worth using as a gaming monitor until it has variable refresh. There's no going back from it.
Yeah, man, variable refresh rates is what you wish for everytime you game with SLI enabled. With one card - there is just no lag.They need to hurry up and get HDMI variable refresh monitors out. This won't be worth using as a gaming monitor until it has variable refresh. There's no going back from it.
Gaming in 1080p on a 55" is not the best idea.
