Anyone using it? Post your results here. I might give it a whirl, just got a new 8800GTS 512. I'm still using the last official driver from Dec 07.
You wanna see if they are any better?
Take five minutes and install them yourself.
It'll be 5 mins well spent, they're much better Just remember to remove the old ones with the freely available 'Driver Sweeper'.
There's a good thread about them here: http://forums.guru3d.com/showthread.php?t=257650
+1 fps out of 19 in crysis..
I've been playing COD4 for an hour and game seems smoother than the 169.21s.[/IMG]
Dude nice OC on your card there. Do you have aftermarket cooling? My stock GPU is 678 MHz, I bumped it to 701 or something, mem to 1000.
3DMark is garbage. What about games, did you see your FPS drop?I lost about 1k on 3Dmark with 174.74 installed, so I went back to 169.44 which has been the best for my system so far.
8800 GT SLI w/Vista32
Does anyone know of standardized game benchmarks you can d/l to compare drivers other than 3dmark/crysis?
The driver has been fine for me, I'm running two 8800GTS cards. No BSODs either, or any other lock-ups or anything.
STALKER is a buggy POS.
well have you tried them in stalker that is the only game i have that gets the bsod in it all others(about 15 current gen titles) play fine with no locks or crashes.
Also are you using the 320 or 512 models
thier point was is that you cant determine all performance solely on 3dmark. new drivers are optimized for games not 3dmark....
Both 174.74 and 174.85 give me the CTD, Screen flicker then crash, and NVLDDMKM.SYS BSoD's. 169.44's did NOT cause these issues.I heard the 174.85 beta is doing well with compatibilities out there. Would anyone like to share?
