12900K Tamed On Cinebench With NH U12A chromax Black Air Cooler with small overclock 80°C Max
gerardfraser
12900K Tamed On Cinebench With Noctua - NH U12A chromax Black Air Cooler with small overclock.Works great.
Max CPU Package Temperature - 80°C
To the people who respond,I get higher score than that,well I say do it on a air cooler.
Multi-28287
Single-2011
BIOS setting
CPU Voltage Override
CPU Voltage 1.16v
SA Voltage Override
SA Voltage 1.20v set high for Ram Gear 1
P-Core set by core usage
P-Core 0-51
P-Core 1-51
P-Core 2-51
P-Core 3-51
P-Core 4-52
P-Core 5-51
P-Core 6-52
P-Core 7-51
E-Core Default
chameleoneel
Multi-28287
Single-2011
BIOS setting
CPU Voltage 1.16v
SA Voltage Override
P-Core 0-51
P-Core 1-51
P-Core 2-51
P-Core 3-51
P-Core 4-52
P-Core 5-51
P-Core 6-52
P-Core 7-51
E-Core Default
How did you determine that core 4 and 6 are your best cores? (there's a few ways to do it. Curious what your method was).
auntjemima
[H]ard DCOTM x2
Multi-28287
Single-2011
BIOS setting
CPU Voltage 1.16v
SA Voltage Override
P-Core 0-51
P-Core 1-51
P-Core 2-51
P-Core 3-51
P-Core 4-52
P-Core 5-51
P-Core 6-52
P-Core 7-51
E-Core Default
I water cool because it's "cool". I guess. That said, those Noctua heatsinks are no joke. My son's i7 sits in the 30 range when gaming. I don't think water cooling does much more these days when the Air coolers are the size of small cars.
gerardfraser
Yes it is true some Air coolers are massive .I do have two different 3600MM AIO just waiting on brackets for the 1700 kit. I actually would never do full watercooling loop,I change my CPU's way to often.
Sorry to disappoint but I am just using the two preferred cores on MSI motherboard. I have been actual testing cores but really not wanting to go full nuts because of the air cooler and it takes forever to do. I figure for me takes around a month+ to test everything for me.
I have used all the different cores and they work fine. Tested up to 3 cores @ 52, 5 cores @51 was ok in testing @ CPU 1.16v but I would think it would fail after a time in long PC gaming session.
4@52 and 4@51 was not stable @ CPU 1.16 v
Currently testing @CPU 1.16v 30 minute Cinebench test pass with 88°C for run.
5100Mhz P-Core
4000Mhz E-Core
4100Mhz Ring
Anyway a more real answer would be on MSI MEG motherboards to use CPU Force 2 to estimate if you have a Good/Bad CPU for overclocking. Similar to SP on ASUS Motherboards.
CPU Force 2:
  • Lower the score, lower Vcore for stability. Better overclocking capability
  • Score cannot be compared between different segments. For example, an i9-12900k scored 95 is not better than a 98 i7-12700K
  • CPU force can identify the physique of the CPU (overclocking potential)
Link to explain how it works
gerardfraser
Upped the clocks by adding 0.05v to cpu voltage.
52 5 P-core
51 3 P-core
40 E-core
41 Ring
CPU 1.165v
SA 1.20v running DDR4 Dual Rank 3866Mhz - Need SA 1.35 for DDR4 Dual Rank 4000Mhz
Noctua - NH U12A chromax Black Air Cooler hitting 82°C Batch # on mine V136J515
Spicedaddy
1.300V on a NH-D15S
1-2 cores @ 5.5GHz, 3-4 cores @ 5.2GHz, 5-8 cores @ 5.1GHz
Asus Z690 Hero (used the BIOS to identify the 2 best cores)
gerardfraser
in what kind of setup, airflow case or open bench? other specs? last temp?
Well first post has all the info,also a full cinebench run single,multi with HWinfo64 on the whole time.
♦ CPU - Intel 12900k ,Temp NH-U12A chromax.Black
♦ GPU - Nvidia RTX 3080
♦ RAM - G.Skill 32 GB DDR4
♦ Mobo - MSI Pro z60-A (BIOS 7D25v10)
♦ SSD - ADATA XPG GAMMIX S70 Blade Read:7400MB/s; Write: 5500MB/s
♦ DSP - LG B9 65" 4K UHD HDR OLED G-Sync Over HDMI
♦ PSU - EVGA GQ 1000W
♦ CASE -Phanteks Eclispe 500A
For your viewing pleasure SOTTR 5500Mhz on the air cooler and the CPU does 5700Mhz all cores but only in PC gaming with offset limits
gerardfraser
1.300V on a NH-D15S
Doh you made me jelly on that 2133,so I just did one at 5500Mhz on the NH-U12A chromax.Black
pendragon1
Extremely [H]
well it didnt have any of that ^^ which is why i asked. seems decent for in a case on air. what was you temp for that 5.5/5.9 runs?
gerardfraser
The first post has all that,it in the video description.That all I am saying.
I did not look at the temperature,so around 80°C I guess since I have the CPU set to downclock at that temperature on CPU loads.Made a thread about it here for MSI motherboard
https://hardforum.com/threads/12900...e-voltage-and-avx-offset-air-cooling.2015400/
Also did CPU-z someone asked for a couple hours ago same settings.Did not look at temps
Intel Core i9 12900K @ 5386.82 MHz - CPU-Z VALIDATOR (x86.fr)
Proof you don't need to buy a $700 mobo to get excellent results.
sblantipodi
but is this true? I have seen tests where the 12900k goes up to 100°C with a 360mm AIO, non OC with the 241W TDP and 10 minutes of cinebench.
gerardfraser
Yes of course it going to hit 100+°C with 360AIO if you run default settings,the CPU voltage run around 1.22v-1.28v.That voltage without any adaptive voltage or straight up full watercooling/phase change is needed.
Over at overclock the 12900K people are using adaptive voltage for the high overclocks on ASUS Boards and on air you can also use the same technique to tame the 12900K.
I am not trying to trick anyone and I even done a guide on adaptive voltage on MSI motherboard,which I will spam again here.
Well here are actual voltage with AIO vs Air on default settings.Only a nut would run default settings on these 12900K CPU's.DO NOT RUN DEFAULT SETTINGS
Reactions: Elios
sblantipodi
Well here are actual voltage with AIO vs Air on default settings.Only a nut would run default settings on these 12900K CPU's.DO NOT RUN DEFAULT SETTINGS View attachment 413582
this is an example of bad design. a processor that throttles in Winter with no OC is simply an example of bad design.
I think that I will sell my 12900K if this is true, I can't try it since there is no DDR5 in Europe yet.
gerardfraser
Well it is a monster and to cool it you need a monster. I can run my 12900K at 5700Mhz and still have single threaded performance and and play PC games but I could not run Cinebench at 5700Mhz my PC would explode.
All I can tell you the above test are at default settings and they are my results. I would never run default settings on any CPU especially an Intel one.
Teenyman45
This is so true.Time to install 360AIO today to see if there is any actual difference from the air cooler
A large air cooler from Noctua, or something of similar performance, is going to equal a premium 240 aio and quite a few 360 aios with less maintenance worry about pump failure but more weight and stress placed on your motherboard.
I've found water cooling is a lot more beneficial when dealing with a custom loop. That my loop uses enough radiators and nearly a gallon of water means that even when the pump is stopped for some reason there is enough of a thermal mass and heat exchange to safely run the computer (gpu and cpu) as long it's not actively, full-out gaming.
gerardfraser
then you need to do it like the pros, soft tube and QDCs
Nah I only PC game 4K and the CPU actually does not matter. I just like buying them and playing with them. At 10 different CPU's in the last 2 years.This 12900K will be gone as soon as AMD drops a CPU.
btw, what's your ambient temp..?
Just normal house .Heat/Air Condition set to 22°C 365 days of the year.
DooKey
What do you use your PC for? It will be just fine while gaming.
gerardfraser
My PC Gaming setting with Offset adaptive voltage and AC line/DC line and LLC. Knocked of some voltage to help CPU temperatures.
Keep single threaded performance for high CPU clocks set.
Heavy workloads set to 75°C to drop CPU clock to default settings on 12900K.You can change the 75°C to higher number to keep full default performance on a Cinebench load.
You still have to test your own personal settings.
My BIOS Settings
https://postimg.cc/HrMcJCq3
https://postimg.cc/06q6DBxv
https://postimg.cc/06dzf02w
https://postimg.cc/tZBY0R6R
https://postimg.cc/KkGRs3Rs
https://postimg.cc/8fvNPTVx
sblantipodi
My BIOS Settings
basically you have downvolted the CPU?
is it stable?
what I have seen is that 12900K goes up to 100°C even at stock clocks so do you tame that processor under 100°C even at stock clocks?
if yes how?
Spicedaddy
You're running 5.7GHz 2 cores and 5.4GHz all cores? Nice!
Must be a better CPU than mine, I wish you had an Asus board to compare SP. (mine is SP 88, seems good but not great lol)
sblantipodi
what are you settings on the asus board and what the results? thank you
Spicedaddy
Manual voltage = 1.300V
Load Line Calibration = 4
1-2 cores ratio = 55
3-4 cores ratio = 52
5-8 cores ratio = 51
Used the AI Features page to check what 2 cores required the least voltage. (the "best" cores...)
Set max ratio per core to 52 for the 6 other cores. The 2 "best" cores leave on Auto.
Fun to play with, but it's back to stock as this is going to be my work computer.
gerardfraser
is it stable?
if yes how?
Well I would not run stock settings.
First post in this thread has all the settings and a video with hwinfo64 running with an air cooler.
kaneO
Multi-28287
Single-2011
BIOS setting
CPU Voltage 1.16v
SA Voltage Override
P-Core 0-51
P-Core 1-51
P-Core 2-51
P-Core 3-51
P-Core 4-52
P-Core 5-51
P-Core 6-52
P-Core 7-51
E-Core Default
Nice!!
pippenainteasy
That's pretty impressive because a U12A would struggle to cool a 11700K much less a 11900K without resorting to maxing out fan speed.
gerardfraser
there no mention of his fan speed, id assume they are maxed, even with the under volting
Well I do not know one person in real life that does not know how to set a fan curve in the BIOS.You should not run any CPU on any Multi core/AVX load without a fan curve set up proper.So with that said,the fan RPM is shown in this screen shot.
10 Minute Cinebench test and does not mean anything
CPU Override manual 1.20v
LLC Mode 2
52 P-core
40 E-core
41- Ring
Multi score- was 29228,just took screen while running
DDR4 Dual Rank 32GB Gear 1 3866 SA-1.20v
Msi Pro z-690-A
pendragon1
Extremely [H]
LLC Mode 2
52 P-core
40 E-core
41- Ring
Msi Pro z-690-A
no shit, i didnt say anything about that.
that pic shows rpm, whats that equate in %? and what is pump 3200 rpm? i thought you were on air?
ps: paste your pics here so we dont have to go to some other site.
gerardfraser
get lost
lol just get out of the thread
pendragon1
Extremely [H]
get lost
lol are you upset by a "no shit"? why not just answer the questions? the pic thing is trying to make your/our life easier btw. [H] will host your pics.
can you post a pic of your setup? im asking all this as your experience with these chips seems to be quite different from most.
sblantipodi
but what is the default vcore voltage on a 12900K?
is 1.2V considered a downvolt or a overvolt?
Niner21
Ordered a NH-U12A to pair with my 12700K, so I'm happy to see these results.
gerardfraser
Every 12900K CPU is different.You want to fine the default voltage at a particular clock here is how to do it on a cheap Motherboard.You got expensive Motherboard it will show V/F Curve
  • All P-cores at 49X - 49 is default
  • Disable the E-cores
  • Set the Ring ratio to 8X
  • Reboot
  • Check CPU voltage - approximately close to real voltage but not 100%
For anyone interested
CPU adaptive voltage + offset
LLC Mode 2
51 P-core
40 E-core
Auto- Ring
Multi score- was 28112,just took screen while running
DDR4 Dual Rank 32GB 4000Mhz SA-1.15v
Enermax LIQMAX III 360 ARGB
Msi Pro z-690-A
