12900K Tamed On Cinebench With NH U12A chromax Black Air Cooler with small overclock 80°C Max
Clovis559
Upped the clocks by adding 0.05v to cpu voltage.
52 5 P-core
51 3 P-core
40 E-core
41 Ring
CPU 1.165v
SA 1.20v running DDR4 Dual Rank 3866Mhz - Need SA 1.35 for DDR4 Dual Rank 4000Mhz
Noctua - NH U12A chromax Black Air Cooler hitting 82°C Batch # on mine V136J515
You think you could help a brotha out? your scores are just under my scores, except I'm running 5.4 P-core and 4.4 e-core... and your voltages are way lower then mine but I feel tarded because no matter what setting I pick, it doesn't take it for voltage.
I'm on a Maximus Hero. Would really appreciate any input!
Clovis559
It's weird in the past on Cine R20, rerunning it would fluxuate in score a little bit. On the settings I have right now, 11163 is the score no matter what. Open Hwinfo: 11163, rerun, same score. Open Intel Extreme Tuning: 11163.
Is that not odd?
Clovis559
Turn it off and on again. Resetting Cine changed the score... It seems like the score should be higher than this for 5.4P 4.3E
gerardfraser
I would not be concerned about Cinebench scores but that is all fine. IT is weird if you always had the same score in Cinebench.
If you look at post #25 all my BIOS settings are there.
I use adaptive voltage + offset voltage with AC load line 25,DC load line 100 on MSI board Asus would be 0.025/0.1. + I also use AVX offset ,when the temperature hits lets say 75°C I have the CPU downclock to default settings.
SO can you be more clear on what you want to do,you can not run 5400Mhz all core without water cooling loop. I suggest you use
Turbo ratio 55,55,55,54,54,53,52,52- try any combo you want
AC load 0.025
DC Load 0.1
Set VF 6 offset point -0.025
Set VF 11 offset Point 0.075
Intel C-state to enabled
Clovis559
It is water cooled and on a chiller. Is the +offset adding voltage or removing? I was using the intel tune utility because to go back to bios was taking so long.
I can take a screenshot of those settings if it helps
I wonder if my ram is holding me back also. I made the jump to DDR5, hoping at some time I could get nicer DDR5. I run 5200 CL32.
I just wanted to have fun tweaking it as a goal.
gerardfraser
Well your all set with chiller and should be able to run whatever your CPU can handle.Your Ram is not holding you back.
I can give you settings all day long. I suggest you go over to this thread and read fort the ASUS motherboard,I gave you all the settings you need for very high overclocks for benchmarking to PC gaming to editing all day long,I really can not test for you.
ASUS MAXIMUS Z690 EXTREME & i9-12900K GUIDE - Load Lines, VF Curves, Adaptive Voltage, By Core & OCTVB​
https://www.overclock.net/threads/a...urves-adaptive-voltage-by-core-octvb.1794957/
gerardfraser
Your welcome,it does seem like he has some good points but also take it with a grain of salt.I do not think he is a ASUS engineer or anything. Good luck dude
CENS
Hi Gerard, I am interested in that chip, I texted you on ocn forums after you replied to my question about a good chip. Let me know.
Clovis559
That tripped me out because my real name is Gerard, I was like what is the OCN network? Took me a second...
o_O SMALL WORLD Wooooo
gerardfraser
Man I am sorry,I feel like a douchbag. I did not see your message on OCN,just thought you were not interested.Anyway like I said I am not attached to the CPU.I found your message on OCN and this was the result below.Switched to 360 AIO
As per request Cinebench20 run two runs with reset in between so you can see the numbers. I did not try to find the lowest voltage ,I just ran these settings a week ago and it worked.Would not be prime95 stable but have not tested prime95
Adaptive voltage + offset at -165
LLC mode 2
AC load 25
DC load 100
51 P-core
40 E-core
LOL that is weird
CENS
No worries man, thank you for getting back to me and putting in the effort for me! I'm convinced. I texted you over on OCN in the direct messages if you don't mind for next steps. Here I didn't figure out how to DM... maybe I don't have enough posts (just signed up for this)
gerardfraser
Sent you all the information over OCN and my email and phone number. We can talk over there no problem
sblantipodi
AC load 0.025
DC Load 0.1
Cstate make my OC unstable and don't understood why.
https://hardforum.com/threads/my-12900k-overclocks-well-if-cstates-are-disabled-why.2016122/
gerardfraser
sblantipodi
Anything is possible.I have had C-states enabled on two 12900K without problems for a month because I was using adaptive voltage. Good thing C-states do not have to be on,I would do whatever works for you.Good you also figured out you instability
ctstate makes my OC unstable when I switch from idle to AVX256 full load like Prime95.
sblantipodi
Those are all my settings.
[2021/12/28 16:26:19]
Ai Overclock Tuner [Manual]
BCLK Frequency [100.0000]
PCIE Frequency [100.0000]
Intel(R) Adaptive Boost Technology [Auto]
ASUS MultiCore Enhancement [Auto – Lets BIOS Optimize]
SVID Behavior [Auto]
BCLK Frequency : DRAM Frequency Ratio [100:100]
Memory Controller : DRAM Frequency Ratio [1:2]
DRAM Frequency [DDR5-4800MHz]
Performance Core Ratio [Sync All Cores]
ALL-Core Ratio Limit [51]
Performance Core0 Specific Ratio Limit [Auto]
Performance Core0 specific Adaptive Voltage [Auto]
Performance Core1 Specific Ratio Limit [Auto]
Performance Core1 specific Adaptive Voltage [Auto]
Performance Core2 Specific Ratio Limit [Auto]
Performance Core2 specific Adaptive Voltage [Auto]
Performance Core3 Specific Ratio Limit [Auto]
Performance Core3 specific Adaptive Voltage [Auto]
*Performance Core4 Specific Ratio Limit [Auto]
Performance Core4 specific Adaptive Voltage [Auto]
*Performance Core5 Specific Ratio Limit [Auto]
Performance Core5 specific Adaptive Voltage [Auto]
Performance Core6 Specific Ratio Limit [Auto]
Performance Core6 specific Adaptive Voltage [Auto]
Performance Core7 Specific Ratio Limit [Auto]
Performance Core7 specific Adaptive Voltage [Auto]
Efficient Core Ratio [Sync All Cores]
ALL-Core Ratio Limit [40]
Efficient Core Group0 Specific Ratio Limit [Auto]
Efficient Core Group0 specific Adaptive Voltage [Auto]
Efficient Core Group1 Specific Ratio Limit [Auto]
Efficient Core Group1 specific Adaptive Voltage [Auto]
CPU SVID Support [Auto]
AVX2 [Enabled]
AVX512 [Disabled]
AVX2 Ratio Offset to per-core Ratio Limit [User Specify]
AVX2 Ratio Offset [5]
AVX512 Ratio Offset to per-core Ratio Limit [Auto]
AVX2 Voltage Guardband Scale Factor [Auto]
AVX512 Voltage Guardband Scale Factor [Auto]
Maximus Tweak [Auto]
DRAM CAS# Latency [36]
DRAM RAS# to CAS# Delay [36]
DRAM RAS# PRE Time [36]
DRAM RAS# ACT Time [76]
DRAM Command Rate [2N]
DRAM RAS# to RAS# Delay L [Auto]
DRAM RAS# to RAS# Delay S [Auto]
DRAM REF Cycle Time [Auto]
DRAM REF Cycle Time 2 [Auto]
DRAM REF Cycle Time Same Bank [Auto]
DRAM Refresh Interval [Auto]
DRAM WRITE Recovery Time [Auto]
DRAM READ to PRE Time [Auto]
DRAM FOUR ACT WIN Time [Auto]
DRAM WRITE to READ Delay [Auto]
DRAM WRITE to READ Delay L [Auto]
DRAM WRITE to READ Delay S [Auto]
DRAM CKE Minimum Pulse Width [Auto]
DRAM Write Latency [Auto]
Ctl0 dqvrefup [Auto]
Ctl0 dqvrefdn [Auto]
Ctl0 dqodtvrefup [Auto]
Ctl0 dqodtvrefdn [Auto]
Ctl1 cmdvrefup [Auto]
Ctl1 ctlvrefup [Auto]
Ctl1 clkvrefup [Auto]
Ctl1 ckecsvrefup [Auto]
Ctl2 cmdvrefdn [Auto]
Ctl2 ctlvrefdn [Auto]
Ctl2 clkvrefdn [Auto]
ODT_READ_DURATION [Auto]
ODT_READ_DELAY [Auto]
ODT_WRITE_DURATION [Auto]
ODT_WRITE_DELAY [Auto]
DQ RTT WR [Auto]
DQ RTT NOM RD [Auto]
DQ RTT NOM WR [Auto]
DQ RTT PARK [Auto]
DQ RTT PARK DQS [Auto]
GroupA CA ODT [Auto]
GroupA CS ODT [Auto]
GroupA CK ODT [Auto]
GroupB CA ODT [Auto]
GroupB CS ODT [Auto]
GroupB CK ODT [Auto]
Pull-up Output Driver Impedance [Auto]
Pull-Down Output Driver Impedance [Auto]
DQ RTT WR [Auto]
DQ RTT PARK [Auto]
DQ RTT WR [Auto]
DQ RTT PARK [Auto]
DQ RTT WR [Auto]
DQ RTT PARK [Auto]
Round Trip Latency Init Value MC0 CHA [Auto]
Round Trip Latency Max Value MC0 CHA [Auto]
Round Trip Latency Offset Value Mode Sign MC0 CHA [-]
Round Trip Latency Offset Value MC0 CHA [Auto]
Round Trip Latency Init Value MC0 CHB [Auto]
Round Trip Latency Max Value MC0 CHB [Auto]
Round Trip Latency Offset Value Mode Sign MC0 CHB [-]
Round Trip Latency Offset Value MC0 CHB [Auto]
Round Trip Latency Init Value MC1 CHA [Auto]
Round Trip Latency Max Value MC1 CHA [Auto]
Round Trip Latency Offset Value Mode Sign MC1 CHA [-]
Round Trip Latency Offset Value MC1 CHA [Auto]
Round Trip Latency Init Value MC1 CHB [Auto]
Round Trip Latency Max Value MC1 CHB [Auto]
Round Trip Latency Offset Value Mode Sign MC1 CHB [-]
Round Trip Latency Offset Value MC1 CHB [Auto]
Round Trip Latency MC0 CHA R0 [Auto]
Round Trip Latency MC0 CHA R1 [Auto]
Round Trip Latency MC0 CHA R2 [Auto]
Round Trip Latency MC0 CHA R3 [Auto]
Round Trip Latency MC0 CHA R4 [Auto]
Round Trip Latency MC0 CHA R5 [Auto]
Round Trip Latency MC0 CHA R6 [Auto]
Round Trip Latency MC0 CHA R7 [Auto]
Round Trip Latency MC0 CHB R0 [Auto]
Round Trip Latency MC0 CHB R1 [Auto]
Round Trip Latency MC0 CHB R2 [Auto]
Round Trip Latency MC0 CHB R3 [Auto]
Round Trip Latency MC0 CHB R4 [Auto]
Round Trip Latency MC0 CHB R5 [Auto]
Round Trip Latency MC0 CHB R6 [Auto]
Round Trip Latency MC0 CHB R7 [Auto]
Round Trip Latency MC1 CHA R0 [Auto]
Round Trip Latency MC1 CHA R1 [Auto]
Round Trip Latency MC1 CHA R2 [Auto]
Round Trip Latency MC1 CHA R3 [Auto]
Round Trip Latency MC1 CHA R4 [Auto]
Round Trip Latency MC1 CHA R5 [Auto]
Round Trip Latency MC1 CHA R6 [Auto]
Round Trip Latency MC1 CHA R7 [Auto]
Round Trip Latency MC1 CHB R0 [Auto]
Round Trip Latency MC1 CHB R1 [Auto]
Round Trip Latency MC1 CHB R2 [Auto]
Round Trip Latency MC1 CHB R3 [Auto]
Round Trip Latency MC1 CHB R4 [Auto]
Round Trip Latency MC1 CHB R5 [Auto]
Round Trip Latency MC1 CHB R6 [Auto]
Round Trip Latency MC1 CHB R7 [Auto]
Early Command Training [Auto]
SenseAmp Offset Training [Auto]
Early ReadMPR Timing Centering 2D [Auto]
Read MPR Training [Auto]
Receive Enable Training [Auto]
Jedec Write Leveling [Auto]
Early Write Time Centering 2D [Auto]
Early Read Time Centering 2D [Auto]
Write Timing Centering 1D [Auto]
Write Voltage Centering 1D [Auto]
Read Timing Centering 1D [Auto]
Read Timing Centering with JR [Auto]
Dimm ODT Training* [Auto]
Max RTT_WR [ODT Off]
DIMM RON Training* [Auto]
Write Drive Strength/Equalization 2D* [Auto]
Write Slew Rate Training* [Auto]
Read ODT Training* [Auto]
Comp Optimization Training [Auto]
Read Equalization Training* [Auto]
Read Amplifier Training* [Auto]
Write Timing Centering 2D [Auto]
Read Timing Centering 2D [Auto]
Command Voltage Centering [Auto]
Early Command Voltage Centering [Auto]
Write Voltage Centering 2D [Auto]
Read Voltage Centering 2D [Auto]
Late Command Training [Auto]
Round Trip Latency [Auto]
Turn Around Timing Training [Auto]
CMD CTL CLK Slew Rate [Auto]
CMD/CTL DS & E 2D [Auto]
Read Voltage Centering 1D [Auto]
TxDqTCO Comp Training* [Auto]
ClkTCO Comp Training* [Auto]
TxDqsTCO Comp Training* [Auto]
VccDLL Bypass Training [Auto]
CMD/CTL Drive Strength Up/Dn 2D [Auto]
DIMM CA ODT Training [Auto]
PanicVttDnLp Training* [Auto]
Read Vref Decap Training* [Auto]
Vddq Training [Auto]
Duty Cycle Correction Training [Auto]
Rank Margin Tool Per Bit [Auto]
DIMM DFE Training [Auto]
Tx Dqs Dcc Training [Auto]
Rank Margin Tool [Auto]
Memory Test [Auto]
DIMM SPD Alias Test [Auto]
Receive Enable Centering 1D [Auto]
Retrain Margin Check [Auto]
Write Drive Strength Up/Dn independently [Auto]
Margin Check Limit [Disabled]
tRDRD_sg_Training [Auto]
tRDRD_sg_Runtime [Auto]
tRDRD_dg_Training [Auto]
tRDRD_dg_Runtime [Auto]
tRDWR_sg [Auto]
tRDWR_dg [Auto]
tWRWR_sg [Auto]
tWRWR_dg [Auto]
tWRRD_sg [Auto]
tWRRD_dg [Auto]
tRDRD_dr [Auto]
tRDRD_dd [Auto]
tRDWR_dr [Auto]
tRDWR_dd [Auto]
tWRWR_dr [Auto]
tWRWR_dd [Auto]
tWRRD_dr [Auto]
tWRRD_dd [Auto]
tRPRE [Auto]
tWPRE [Auto]
tWRPRE [Auto]
tPRPDEN [Auto]
tRDPDEN [Auto]
tWRPDEN [Auto]
tCPDED [Auto]
tREFIX9 [Auto]
Ref Interval [Auto]
tXPDLL [Auto]
tXP [Auto]
tPPD [Auto]
tCCD_L_tDLLK [Auto]
MRC Fast Boot [Enabled]
MCH Full Check [Auto]
Mem Over Clock Fail Count [Auto]
Training Profile [Auto]
RxDfe [Auto]
Mrc Training Loop Count [Auto]
DRAM CLK Period [Auto]
Dll_bwsel [Auto]
Controller 0, Channel 0 Control [Enabled]
Controller 0, Channel 1 Control [Enabled]
Controller 1, Channel 0 Control [Enabled]
Controller 1, Channel 1 Control [Enabled]
MC_Vref0 [Auto]
MC_Vref1 [Auto]
MC_Vref2 [Auto]
Dynamic Memory Boost [Disabled]
Realtime Memory Frequency [Disabled]
SA GV [Disabled]
Voltage Monitor [Die Sense]
VRM Initialization Check [Disabled]
CPU Input Voltage Load-line Calibration [Auto]
CPU Load-line Calibration [Level 3]
Synch ACDC Loadline with VRM Loadline [Disabled]
CPU Current Capability [Auto]
CPU Current Reporting [Auto]
Core Voltage Suspension [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [Auto]
CPU Power Phase Control [Auto]
CPU Power Thermal Control [125]
CPU Core/Cache Boot Voltage [Auto]
CPU Input Boot Voltage [Auto]
PLL Termination Boot Voltage [Auto]
CPU Standby Boot Voltage [Auto]
Memory Controller Boot Voltage [Auto]
CPU Core Auto Voltage Cap [Auto]
CPU Input Auto Voltage Cap [Auto]
Memory Controller Auto Voltage Cap [Auto]
Maximum CPU Core Temperature [Auto]
Package Temperature Threshold [90]
Regulate Frequency by above Threshold [Auto]
IVR Transmitter VDDQ ICCMAX [Auto]
Unlimited ICCMAX [Auto]
CPU Core/Cache Current Limit Max. [Auto]
Long Duration Package Power Limit [Auto]
Package Power Time Window [Auto]
Short Duration Package Power Limit [Auto]
IA AC Load Line [0.25]
IA DC Load Line [1.10]
IA CEP Enable [Auto]
SA CEP Enable [Auto]
IA SoC Iccmax Reactive Protector [Auto]
Inverse Temperature Dependency Throttle [Auto]
IA VR Voltage Limit [1500]
TVB Voltage Optimizations [Enabled]
Enhanced TVB [Enabled]
Overclocking TVB [+2Boost Profile]
Offset Mode Sign 1 [+]
V/F Point 1 Offset [Auto]
Offset Mode Sign 2 [+]
V/F Point 2 Offset [Auto]
Offset Mode Sign 3 [+]
V/F Point 3 Offset [Auto]
Offset Mode Sign 4 [+]
V/F Point 4 Offset [Auto]
Offset Mode Sign 5 [+]
V/F Point 5 Offset [Auto]
Offset Mode Sign 6 [+]
V/F Point 6 Offset [Auto]
Offset Mode Sign 7 [+]
V/F Point 7 Offset [Auto]
Offset Mode Sign 8 [+]
V/F Point 8 Offset [Auto]
Offset Mode Sign 9 [+]
V/F Point 9 Offset [Auto]
Offset Mode Sign 10 [+]
V/F Point 10 Offset [Auto]
Offset Mode Sign 11 [+]
V/F Point 11 Offset [Auto]
Initial BCLK Frequency [Auto]
Runtime BCLK OC [Auto]
BCLK Amplitude [Auto]
BCLK Slew Rate [Auto]
BCLK Spread Spectrum [Auto]
Initial PCIE Frequency [Auto]
PCIE/DMI Amplitude [Auto]
PCIE/DMI Slew Rate [Auto]
PCIE/DMI Spread Spectrum [Auto]
Cold Boot PCIE Frequency [Auto]
Realtime Memory Timing [Enabled]
SPD Write Disable [FALSE]
PVD Ratio Threshold [Auto]
Banding Ratio [Auto]
SA PLL Frequency Override [Auto]
BCLK TSC HW Fixup [Enabled]
Core Ratio Extension Mode [Disabled]
FLL OC mode [Auto]
Core PLL Voltage [Auto]
GT PLL Voltage [Auto]
Ring PLL Voltage [Auto]
System Agent PLL Voltage [Auto]
Memory Controller PLL Voltage [Auto]
CPU 1.8V Small Rail [Auto]
PLL Termination Voltage [Auto]
CPU Standby Voltage [Auto]
PCH 1.05V Voltage [Auto]
PCH 0.82V Voltage [Auto]
CPU Input Voltage Reset Voltage [Auto]
Eventual CPU Input Voltage [Auto]
Eventual Memory Controller Voltage [Auto]
Cooler Efficiency Customize [Keep Training]
Cooler Re-evaluation Algorithm [Normal]
Optimism Scale [100]
Ring Down Bin [Auto]
Min. CPU Cache Ratio [Auto]
Max. CPU Cache Ratio [36]
BCLK Aware Adaptive Voltage [Enabled]
CPU Core/Cache Voltage [Adaptive Mode]
Offset Mode Sign [+]
Additional Turbo Mode CPU Core Voltage [1.36000]
Offset Voltage [Auto]
CPU L2 Voltage [Auto]
CPU System Agent Voltage [Manual Mode]
- CPU System Agent Voltage Override [1.20000]
High DRAM Voltage Mode [Auto]
DRAM VDD Voltage [1.35000]
DRAM VDDQ Voltage [1.35000]
IVR Transmitter VDDQ Voltage [Auto]
Memory Controller Voltage [1.25000]
PMIC Voltages [Sync All PMICs]
SPD HUB VLDO (1.8V) [Auto]
SPD HUB VDDIO (1.0V) [Auto]
DRAM VPP Voltage [Auto]
DRAM VDD Switching Frequency [Auto]
DRAM VDDQ Switching Frequency [Auto]
DRAM VPP Switching Frequency [Auto]
DRAM Current Capability [Auto]
PCI Express Native Power Management [Enabled]
Native ASPM [Auto]
DMI Link ASPM Control [Disabled]
ASPM [Auto]
L1 Substates [Disabled]
DMI ASPM [Disabled]
DMI Gen3 ASPM [Disabled]
PEG - ASPM [Disabled]
PCI Express Clock Gating [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetch [Enabled]
Intel (VMX) Virtualization Technology [Enabled]
Per P-Core Control [Disabled]
Per E-Core Control [Disabled]
Active Performance Cores [All]
Active Efficient Cores [All]
Hyper-Threading [Enabled]
Hyper-Threading of Core 0 [Enabled]
Hyper-Threading of Core 1 [Enabled]
Hyper-Threading of Core 2 [Enabled]
Hyper-Threading of Core 3 [Enabled]
Hyper-Threading of Core 4 [Enabled]
Hyper-Threading of Core 5 [Enabled]
Hyper-Threading of Core 6 [Enabled]
Hyper-Threading of Core 7 [Enabled]
Total Memory Encryption [Disabled]
Legacy Game Compatibility Mode [Disabled]
Boot performance mode [Auto]
Intel(R) SpeedStep(tm) [Enabled]
Intel(R) Speed Shift Technology [Enabled]
Intel(R) Turbo Boost Max Technology 3.0 [Enabled]
Turbo Mode [Enabled]
Acoustic Noise Mitigation [Disabled]
CPU C-states [Disabled]
Thermal Monitor [Enabled]
Dual Tau Boost [Disabled]
VT-d [Enabled]
Control Iommu Pre-boot Behavior [Enable IOMMU during boot]
Memory Remap [Enabled]
Primary Display [Auto]
iGPU Multi-Monitor [Disabled]
Enable VMD controller [Enabled]
Map PCIE Storage under VMD [Disabled]
Map SATA Controller under VMD [Disabled]
M.2_2 Link Speed [Auto]
PCIEX16(G5)_1 Link Speed [Gen5]
M.2_1 Link Speed [Gen5]
PCIEX1(G3) Link Speed [Auto]
M.2_3 Link Speed [Auto]
DIMM.2_1 Link Speed [Gen4]
DIMM.2_2 Link Speed [Gen4]
SATA Controller(s) [Enabled]
Aggressive LPM Support [Disabled]
SMART Self Test [None]
SATA6G_1 [Enabled]
SATA6G_1 Hot Plug [Disabled]
SATA6G_2 [Enabled]
SATA6G_2 Hot Plug [Disabled]
SATA6G_3 [Enabled]
SATA6G_3 Hot Plug [Disabled]
SATA6G_4 [Enabled]
SATA6G_4 Hot Plug [Disabled]
PTT [Enable]
PCIE Tunneling over USB4 [Enabled]
Discrete Thunderbolt(TM) Support [Enabled]
Wake From Thunderbolt(TM) Devices [None]
DTBT Go2Sx Command [Enabled]
Windows 10 Thunderbolt support [Enable + RTD3]
DTBT Controller 0 [Enabled]
TBT Host Router [Two port]
Extra Bus Reserved [106]
Reserved Memory [737]
Memory Alignment [26]
Reserved PMemory [1184]
PMemory Alignment [28]
Reserved I/O [0]
Security Device Support [Enable]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
Physical Presence Spec Version [1.3]
TPM 2.0 UEFI Spec Version [TCG_2]
Disable Block Sid [Disabled]
Re-Size BAR Support [Disabled]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
U32G2X2_1 [Enabled]
U32G2X2_C3 [Enabled]
U32G2_C5 [Enabled]
U32G2_67 [Enabled]
U32G2_8 [Enabled]
U32G1_E1 [Enabled]
U32G1_E2 [Enabled]
U32G1_E3 [Enabled]
U32G1_E4 [Enabled]
U32G2_E1 [Enabled]
U32G2_EP2 [Enabled]
U32G2_E3 [Enabled]
U32G2_E4 [Enabled]
TBT4_E1 [Enabled]
TBT4_E2 [Enabled]
Network Stack [Disabled]
Device [Samsung SSD 850 EVO 1TB]
Restore AC Power Loss [Power Off]
Max Power Saving [Disabled]
ErP Ready [Disabled]
Power On By PCI-E [Enabled]
Power On By RTC [Disabled]
USB Audio [Enabled]
Intel LAN [Enabled]
MARVELL 10G LAN [Enabled]
USB power delivery in Soft Off state (S5) [Enabled]
Connectivity mode (Wi-Fi & Bluetooth) [Enabled]
When system is in working state [All On]
Q-Code LED Function [POST Code Only]
When system is in sleep, hibernate or soft off states [Stealth Mode]
When system is in working state [On]
When system is in sleep, hibernate or soft off states [Off]
M.2_3 Configuration [Auto]
CPU PCIE Configuration Mode [Auto]
U32G2_C5 Type C Power Mode [Auto]
GNA Device [Disabled]
ASMedia Storage Controller [Enabled]
Windows Hot-plug Notification [Disabled]
ASPM Support [Disabled]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
Chipset Temperature [Monitor]
T_Sensor Temperature [Monitor]
DIMM.2 Sensor 1 Temperature [Monitor]
DIMM.2 Sensor 2 Temperature [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
WB Temperature [Monitor]
DIMM A1 Temperature [Monitor]
DIMM A2 Temperature [Monitor]
DIMM B1 Temperature [Monitor]
DIMM B2 Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Radiator Fan 1 Speed [Monitor]
Radiator Fan 2 Speed [Monitor]
Water Pump+ 1 Speed [Monitor]
Water Pump+ 2 Speed [Monitor]
Flow Rate [Monitor]
WB Flow Rate [Monitor]
CPU Core Voltage [Monitor]
12V Voltage [Monitor]
5V Voltage [Monitor]
3.3V Voltage [Monitor]
Memory Controller Voltage [Monitor]
CPU Core Current [Monitor]
AI Cooling [Disabled]
HYDRANODE Fan Association [Enabled]
CPU Fan Q-Fan Control [Auto Detect]
CPU Fan Profile [Standard]
CPU Fan Step Up [Level 0]
CPU Fan Step Down [Level 0]
CPU Fan Speed Low Limit [200 RPM]
Chassis Fan 1 Q-Fan Control [Auto Detect]
Chassis Fan 1 Profile [Standard]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [Level 0]
Chassis Fan 1 Step Down [Level 0]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 2 Q-Fan Control [Auto Detect]
Chassis Fan 2 Profile [Standard]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [Level 0]
Chassis Fan 2 Step Down [Level 0]
Chassis Fan 2 Speed Low Limit [200 RPM]
Radiator Fan 1 Q-Fan Control [Auto Detect]
Radiator Fan 1 Profile [Standard]
Radiator Fan 1 Q-Fan Source [CPU]
Radiator Fan 1 Step Up [Level 0]
Radiator Fan 1 Step Down [Level 0]
Radiator Fan 1 Speed Low Limit [200 RPM]
Radiator Fan 2 Q-Fan Control [Auto Detect]
Radiator Fan 2 Profile [Standard]
Radiator Fan 2 Q-Fan Source [CPU]
Radiator Fan 2 Step Up [Level 0]
Radiator Fan 2 Step Down [Level 0]
Radiator Fan 2 Speed Low Limit [200 RPM]
Water Pump+ 1 Q-Fan Control [Auto Detect]
Water Pump+ 1 Profile [Full Speed]
Water Pump+ 2 Q-Fan Control [Auto Detect]
Water Pump+ 2 Profile [Full Speed]
CPU Temperature LED Switch [Enabled]
Launch CSM [Disabled]
OS Type [Windows UEFI mode]
Secure Boot Mode [Standard]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Auto]
POST Delay Time [2 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
AMI Native NVMe Driver Support [Enabled]
Setup Mode [Advanced Mode]
Boot Sector (MBR/GPT) Recovery Policy [Local User Control]
Next Boot Recovery Action [Skip]
BIOS Image Rollback Support [Enabled]
Publish HII Resources [Disabled]
Flexkey [Reset]
Setup Animator [Disabled]
Load from Profile [1]
Profile Name [OC_4800_C36]
Save to Profile [1]
DIMM Slot Number [DIMM_A1]
Download & Install ARMOURY CRATE app [Enabled]
Download & Install MyASUS service & app [Disabled]
Basically the voltages that worry me are
CPU Core/Cache Voltage [Adaptive Mode] - > Additional Turbo Mode CPU Core Voltage [1.36000]
DRAM VDDQ TX Voltage [1.35000]
Using 4x16GB Corsair Dominator 5600MHz C36 tested at 1.25V.
Do you see something that can damage my CPU/RAM in the long term?
gerardfraser
It is a CPU that will last for 10 years maxed out.Your worried about nothing.You have a warranty,your good.
gerardfraser
maxed out for sure, but at what voltages? :D
Well you want a number 1.45 manual CPU voltage and after 3year-4years you may need 1.47v for same clocks.12th gen Intel would be real toasty at 1.45 manual voltage but if you have cooling so what.I have Intel computer 3770K overclock for 10+years with high manual voltage and it is still fine and works great.Plus I know you must have a warranty that is good for three years.
Also it is only a CPU piece of metal and I am not sure what you would be missing if you had to run high voltage over lower voltage for a couple years,maybe 100Mhz if it degraded.Nothing to worry about,if you or anyone is worried about CPU voltage .Lower CPU Clocks to 4000Mhz with under 1.0v,problem solved and no worries.
All I can say my 12900K will be running 5400Mhz until new AMD Ryzen is released and then I will be yeeting the CPU/Motherboard.
Have you watched this video yet on CPU voltage over a long period of time ,where the voltage was said by just about every nut out there that the AMD CPU would die.
sblantipodi
Why sell a 12900K for a Ryzen now?
Even Zen4 would not be a big upgrade imho.
gerardfraser
Well it is a CPU and means nothing to me as a hobby. I change gear every few months from SSD to CPU to GPU ETC and buy multiples of each one.
EG: Some CPU's I owned in the last couple years and I may have missed some AMD/Intel CPU's below,so bring on the next best.AMD I am looking at you. Also to be clear not one of the CPU's gave me a better PC gaming experience from AMD 2600X to Intel 12900K @ 5600Mhz all core. They all gave around same FPS for my PC Gaming.
Ryzen 2600X 4350Mhz run with Cinbench ,AIDA64 Memory test 3466Mhz May 2019​
3600X Hitting 4500Mhz Cinebench 20 july 2019​
The Golf Club 2020 AMD 3600XT PBO Boost 4700Mhz Sept 2020​
Bioshock Remastered Amd 3800X Boost 4650 Mhz jan 2020​
RTX 3080 3800XT The Dark Pictures Anthology - Little Hope nov 2020​
Shadow of the Tomb Raider AMD 5800X 5150Mhz dec 2020​
Cyberpunk 2077 4K HDR Intel 10850K Boost 5200Mhz dec 2020​
Shadow of the Tomb Raider 12900K 5600Mhz Crazy Voltage nov 2021​
