BigDaddy85
- May 13, 2005
http://www.zalmanusa.com/mboard/mbo...nity&idx_num=30&order_c=idx_num&order_da=desc
when will it release to us?
honkee said:i dunno but hopefully it cools beter than those 7700's
I hope so too. If it does, I may consider one of these to replace my 7700, but only after enough (real) people try them. (No more reading reviews that take place in a wind tunnel.honkee said:i dunno but hopefully it cools beter than those 7700's
So far the best thing about the 7700 is how it looks.ScHpAnKy said:QFT, lackluster performance from an overpriced cooler!
Laplacian said:I hope so too. If it does, I may consider one of these to replace my 7700, but only after enough (real) people try them. (No more reading reviews that take place in a wind tunnel.)
Where were you guys when I was buying my 7700?I didn't hear anything but glowing praise about them only to find out for myself that they're about 5% better than the stock HSF.
www.hexus.com said:Drawing an impressive 1400Watts of power, Zalman include a full instruction booklet on how to daisy chain 5 300W PSUs together to power the fan
not really needed if you position it correctly in your case, because the rear exhaust fan will be very close to the other sideDiablo2K said:That cooler would be really cool if they put 2 fans on it, one on each side, all the air goes out from the center so they wouldn't be fighting each other and the only downside I can think of is the added weight and it would cool alot better.
$75chusoblu said:How much do you suppose a thinger like this would cost?
It's compatible with Socket 478 / 775 / 754 / 939 / 940.Glow said:754 and 939 use same model or is there 2 different versions? I hope theres a review soon
EnderW said:It's compatible with Socket 478 / 775 / 754 / 939 / 940.
Although, there will be different models, including a Fatal1ty one.
I'll take your chip if u want to upgrade to a 3200-4400+cornelious0_0 said:Man, I'd REALLY like to see this thing available.....I was gonna be buying a new air cooler for my Venice in my sig (sig overclock done with a 7700-ALCU) and I wanna wait for this thing. My first choice ATM for my last high-end air cooler is an XP-90C with a 92mm Panaflo H1A.....before tax/shipping that's still $80 - $90 CDN for me...so if the 9500 is in that same price range, I KINDA wanna hold off to see how it does...cus I'd hate to drop that much cash and then see that the cooler I would have wanted was even a few degrees nicer.
EnderW said:
Dillusion said:And since the fan is placed like that, the rear 120mm exhaust fan in my Lian li will be RIGHT behind it pulling hot air out, thats sick.
Just a preorder.cornelious0_0 said:Mmm.....me likes.....any retail links yet?![]()
EnderW said:
BigDaddy85 said:one simple question, REVIEW?![]()
BigDaddy85 said:suppose if that new zalman heatsink beat all watercool champion like koolance, danger den, or w/e it is. o well hope this happen lol.![]()
