I think the PSU is already in there by the front intake. That build is froot loops!
I have the same cooler and almost had insane thoughts of stuffing it into a FT03 mini lol
Just earlier today I saw a build with dual 120mm rads mounted to the front intake on an SG05. Had the CPU and GPU fed into them. Real nice.
Yep, that'd be the one. I'm glad I didn't see it back when I was waffling about getting one of those Accelero hybrids. I think I made up my mind to go the ATX PSU route at this point in time.
Does the EVGA 760 /w ACX cooler fit fine in the SG05?
I think there is an sfx 550W psu rumored from silverstone,
it would be enough for 780ti and some overclocking headroom.
maybe an alternative so you could fit dual rads etc?
i.e. since you are not going dual GPU option you may be able to get away with an SFX PSU
Yes, the card is 9.5" and should fit without even needing to cut the front steel. You may need to remove the front fan and stick the nose of the card out while you orient it inside the case.
I'm really up in the air about which direction to go with my build right now, but the endgame goal is to have the highest performing card in a single PCIE slot so I can run a 120Hz/144Hz monitor close to it's capability. This might mean a 780 Ti K|NGP|N, GTX 790, something Maxwell, or even jumping ship to Kaveri for Mantle support (but this would mean I can't use G-Sync)
Not really sure what to do, so I'm just planning and saving my pennies.
Can now confirm the MSI 760 Twin Frozr fits
Had to remove everything and install it from the top, even cpu heatsink and ram.
But case is fully loaded, optical drive, 3.5" hard drive and 2.5" ssd.
Is it better to have the PSU facing down or up in these cases?
Is it possible to fit an h55 in the front and use a full size graphics card?
Yes, but you'll have to orient the radiator vertically, which means you won't be able to use an ODD and have to find optional places to mount your drives.Is it possible to fit an h55 in the front and use a full size graphics card?
Full size, how long exactly? Inside of frame is 262mm long (10.3"), you can win a few more millimetres by dremelling a cut out.
