How exactly do you want to "re-join" the base and outer panel?
I wouldn't consider doing it myself as not a modder. Just what immediately came to mind when I saw picture.
Your list includes two 2.5" drives, a slim ODD drive, and an H60. They won't all fit in the SG05 without some sort of mod.
What about the H60 vs the drive tray? In stock form, there's only enough room for a fan. To fit a rad, you'll need to either mod or remove the tray.
Hey guys, am I missing anything here?
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=165749&action=wish_lists
It's been a long wait, but I'll be ordering that next week.
Sit the HDD under the H60 and hang the SSD off the frame. The most amount of modding required is some double-sided tape and drilling two small holes.
Just note that there's a screw mount under the rad. You can see it just to the left of the 8 pin mobo power cable (yellow and black). I found that it was hard to place the HDD there with the mount in place. The HDD sits perfectly either side of the mount but it blocks the sata and power cables. Does anyone know what that screw mount is for?
Edit: before you spend $29 on a Noctua I respectfully suggest to try the stock H60 fan first. Try also the stock case fan. Both are good quality fans. Only if you decide you can't bear the noise, have a listen to fans in this test - http://martinsliquidlab.org/2013/05/07/fan-testing-round-12/
How much space are there here?
Go to order my parts today just to find out that there aren't any 670 minis in stock. Have to wait again. Bastards.![]()
Bugger mate...
Maybe they might do a Gtx770 mini version.
If they do a 770 mini, they'd best do it off the bat, not on the ass end of the cycle right before the next series is announced. I'm sure there'll be some more in stock within the next few days.
So I picked up a Sugo SG05-Lite, Silverstone's 450 watt PSU, and this mobo:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130664
Coupled with a 100wat A8-5600K CPU.
With the stock cooler, my temps are nuts - idling at 50c, ramping up gets up to 70c very quickly and of course the fan quickly becomes loud.
So, what's the consensus on the best cooler you can get that fits an FM2 motherboard and won't block the PCIE slot? There doesn't seem to be much selection out there. I'm looking at this one, but it looks like it could block the PCI:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103177
Well that's what I'd like to know as well.Do the NT06-Pro. or AXP-100 block the PCIe slot on that board?
Maybe give them a call or email to see if they are getting more in stock just to be sure?
As you can see the CPU socket is pretty close to the PCIE, that NT06 would be tight. Ram slots I'm not too worried about, I at least thought ahead and got low profile sticks.
BTW I did improve things slightly - did more reading, my first instinct was to mount the PSU with the fan intake on top, but for the SG05 that should be the reverse. Flipped it, that brought down temps 5C or so, so no longer in danger of shutting down, but the fan still goes up to ~4000rpm under load so want to cut that out.
Could you please give us more precise information on this Tony? This interests me because I would like to build a FT03 Mini system and I can't find any GTX 700 cards that will fit without modding...The GTX 770s' we have in house are 10" long instead of 10.5" on the Titan and GTX 780.
The EVGA is 10.5" long not 10". The Galaxy is indeed 10" but axial, non rear exhaust cooling solutins are not recommended in a FT03 by Silverstone.These 770s are 10" long, so they might just fit.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130921
http://www.newegg.com/Product/Product.aspx?Item=N82E16814162135
I see people using the H60 here. Will the H80i also work? Is it better?
My friend is saying i should get a alienware since im in university, but i want to build a SG05/SG06 system instead. The only things puzzling me are cpu cooling and whether some 770 gtx will fit.
Where are you going to stash your drives?
