AFAIK, the 450w version of the sg05/06 will only be available in Japan. (Read it somewhere in this forum..i think..)
It might not be damaged, but Q6700 + 5850 is pushing it probably. It probably struggled with this kind of load, which in turn help fry the board (PSU failing to regulate current under high load or something).
I must say I am a little surprised but at the same time you are playing with fire by using a notoriously power-hungry processor and a mid-high end GPU with this PSU.
N82E16811163149 SILVERSTONE Sugo SG05-B Black SECC / Plastic Mini-ITX Desktop Computer Case SFX 300W 80Plus Power Supply $119.99 -$20.00 Instant $99.99
N82E16813500043 ZOTAC H55ITX-A-E LGA 1156 Intel H55 HDMI Mini ITX Intel Motherboard $144.99
N82E16814150447 XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card $169.99
N82E16819115227 Intel Core i5-680 Clarkdale 3.6GHz LGA 1156 Dual-Core Desktop Processor Model BX80616I5680 $309.99
N82E16820227539 OCZ Gold 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Low Voltage Desktop Memory Model OCZ3G1333LV8GK $269.99 -$15.00 Instant $509.98
Subtotal: $1,234.94
Tax: $120.41
Shipping: $25.97
Grand Total: $1,381.32
This look doable? Plan to use 80GB intel g1 ssd, have a 2TB for storage.
would do minimal cpu OC, would like to get to 4.2-4.5 - probably do a h50 mod later...
Sorry if this has been answered already, but will a Thermalright AXP-140 fit in this case?
Would it work with a DFI LANParty MI P55-T36 ?Yes it does, at least if mounted on Zotac GF9300 board:
http://forums.hexus.net/small-form-factor-portables/166371-question-silverstone-sugo-sg05-owners.html#post1732453
Yes, at least the newer revision, AXP-140 RT:
http://www.thermalright.com/new_a_page/product_page/cpu/axp140/product_cpu_axp140.html
The older AXP-140 may need separate socket 1156 retention module if it´s not included in retail package:
http://www.amazon.co.uk/Thermalright-Socket-Retention-AXP-140-Bolt-Thru-Kit/dp/B0037LR6EW
Will the AXP-140 RT fit with that supplied fan?
I'm seeing conflicting reports in this thread, so can anyone definitely confirm whether or not the Sapphire Vapor-X/Toxic 5850 will fit without bending the SG05's front faceplate?
but then again, a post from this very thread with pictures even!
http://hardforum.com/showpost.php?p=1035435152&postcount=567
claim that theres no modding needed. I'm seriously confused as the rest of you ;S
Hey guys, Should I mount the motherboard on standoffs/spacers? A friend of mine says its not explicitly needed.
So where is the Silverstone ST45SF 450w PSU?
No place has it. Wasnt this suppose to be out back in January?
