Your voltage for FX-55
I'll give it a shot. I'll have to loosen the memory timings though b/c I've already pushed it as far as it will go at 2-3-2-6 1T
For sure, give 'er a go......you never know, even if you half to loosen the timing a tad.....compare the results....and if you're benching higher at your current clock with tighter timings and at 3GHz with loose ram then by all means stay where you are.....but it's worth trying out.
I think I'm going to give up on 3 Ghz for now. I can't even run 2.95 stable for very long and 2.93 would start having problems after a long day when the room starts to get warm. Maybe I'll get phase changers or peltiers in a few month. Right now, I went down to 2.85Ghz (13x219) @ 1.6V running very stable. I think I can run it at 1.55V too but I haven't had time to thoroughly test it yet. I get much lower temps this way and don't get more crashes.
Good call on backing it off for now.....
If you're looking at temp issues holding you back you could simply Pelt the CPU for a lot less then a PS setup would cost, and that way you should be able to gain back those 150MHz....and 3gig should be quite doable for you and your FX. ;)
2.85g on air is speedy for gaming. Push it slowly...
Rob94hawk said:
What the hell is a TDX?
Sorry, I forgot I might be talking to some people that still might have never heard of the thing.......strange as that is. ;) :p
Had mine running up to the limit of this board with no overclocking gain... grr...
I sent it back, going to order another soon, but the limit of the motherboard for this round will be the limit of the cpu
Try it with neo2
ScHpAnKy said:
done, achieved even less
suxors.....makin' me wanna stay with my P4 almost....everything is so simple, and the platform has been out forEVER, lots more time for manufacturers to get things right. ;) :p
The neo2 was a good board, but it's vcore cieling was way too low for my liking, hopefully abit or dfi comes into the arena for some action like their supposed to and develop AGP 939 boards that are decent, and nForce 3 Ultra :D
Then we would surely see some healthy overclocks :)
Can't remember what I saw out of Abit......pretty sure it was teh same as DFI though.....NF4 s939........
No NF3 s939 on the way from DFI, don't hold your breath. ;)
My opinion anyway is that I dont think The problem is the Boards. Looking at it, it looks as though you are using the FX53. As it is a really great processor they dont like to overclock very well. The best I ever got out of my FX53 was 2.7 and leaning more towards 2.6 24/7 happiness. Ive used the Asus A8V the Abit AV8 and the MSI Neo2 platinum and the neo is the hands down winner between all three. In fact I switched to the FX55 and on H2o and should easily hit 3 to 3.1 ghz on water on the MSI Neo2. Also found that the Neo2 loves GSkill pc4400le mem. Not sure what mem you have tried. But thats my expereince. But what I cant wait for is Hopefully in about 2 to 3 more weeks at most I will have my Phase change cooler as that its being built and the 3.5 should be pretty easy.
The Cpt
The Cpt
Good luck with your endeavors....but I highly doubt you're gonna hit 3.0 - 3.1 on water....unless you're gonna chill it.
Ive seen several people hit 3 to 3.1with an FX55 on H2o and run 24/7 Infact James Earl Ray was doing it before he went Phase change now he runs 3.4. But I guess we will see.
Some people DO do it.....and you still might, but it does require an above average chip......and the odds can always be against you. ;)
Hope you do though. :)
Well boys and girls Just got the monster running and decided to try for a right out of the gates 3ghz clock and here you go!!!
So whadya think Corn? good chip or average?
I still have more to do but its a start. ;)
The Cpt.
Time to see how it does @ PI and some other benchies
will keep ya posted
Capt, try without clockgen. Oc it from bios (you can add vcore with msi core center) and 1.41mod bios imo. is the best for tccd. Good luck and nice fx55 oc you have ;)
Thanks!!!
Actually I did oc it from the Bios. Only ran the Clockgen as a display for comparison from what I did in bios. I have the latest Bios version 1.4 published from MSI. Probably Not the 1.41 mod bios. Running mem timmings of 2.5-3-3-7 @ 2.65v Gskill pc4400le.Where can I get the 1.41 mod bios? Any other tips or tricks you have on squeezing more out of it.
The Cpt
Captin Insano said:
Thanks!!!
The Cpt
Capt, heres 7025v141mod.ziphttp://www.lejabeach.com/MSIK8N/k8nneo2.html If you wanna flash it from windows, down load msi Live Update fromhttp://www.msi.com.tw/program/support/software/swr/spt_swr_detail.php?UID=607&kind=1 Good luck....
Wow, nice chip you got your hands on their bro.....can't wait to see that thing under a phase change system. :D :cool:
Ok so I found the Bios Zip for the 7025v141mod.zip and I allready have Live Update installed from the drivers disc as well as updated it online. But I didnt know that you could flash a Moded or Beta bios with that utillity. I do have the Official V141 but not the Mod v141. Any real big differences. I assume the mod ones are ment for overclocking benifits. So if I wanna use the in windows tool to flash the Mod bios can it be done and how do I get MSI Live update to do it. I could always do a floppy but would like to learn how to do it the otherway for non official bios if thats possible.Thanks
This will helphttp://www.xtremesystems.org/forums/showthread.php?t=44481
Captin Insano said:
Thanks man your so damn awesome!!!
LMK. I'm tryin 1.37mod now. Will go back to 1.41 though. I can benched at 3.39Ghz(295x11.5) on aquamark3 and 3.5Ghz on 3Dmark '01 with Vapo and Gskill LE. With phase changer yours will reach the same, imo ;) Good luck.....
3.5 is killer.....I wanna see what that nets you in '01.....I see 40k dropping pretty soon around here. :D
Man I cant wait till my Phasechnge is ready. prolly be a month or so... Unfortunatly can only spend so much at a time. something about I havent gotten my millon dollar check yet... Not sure what the confusion is there. Once I have the money I can get Bitchbreaker the last of the parts. and then YEEEHAH!!!!!
But Im happy right now. better then what i was before with the FX53 ;) could only hit 2.7ghz
Your Phase Change unit is allmost done :) all i have to do now is braze up the evap (waiting on more silver brazing rods :-/) and then ill put 300 PSI of dry nitrogen it it,leak test it then discharge it,oil it up and give it a r-22 gas charge with 5% r-290.
Nice stuff, I might have to give you a shout if/when I get back into benching. ;)
IF????? wtf??? whats wrong ??? did your stuff die??? Im not gona do any benching for a while eather..after CPT Insano's unit is finished ill test it on my pressy but thats about it.
No, didn't die.....but I don't game anymore, and I was becoming quite bored with competitive benchmarking...mainly because I'm so limited in the cash department...and there was little I could do at this point. The XT-PE is sold, and the 3.4E and mobo are going to be quite soon. I'm throwing togethor a s462 rig with a 2500+ mobile and a DFI Lanparty nf2Ultra for my parents rig, and just picked up a 1700+ with an nf7-s for myself.....with some of the cash I had from selling the card.
Another reason behind all of this is since I started working this job (local petstore) my interest in reptiles, spiders, and others has started to really grow, and I sold the XT-PE mainly to redo a couple of my reptile tanks.
In the summer I'm going to be building a shuttle setup for myself and will hopefully have an LCD by then, but I can't see myself getting back into benchmarking until I've got a considerably better job.....as things have just been to tight as I've been trying to "keep up" with my rig at this point in my life.
I'm still going to be just as active on the forums, as I'll have to make sure I maintain my current level of knowledge on everything that's out there...and continue to as time goes on...so no worries there. ;)
DUDE!! your like my boy..i cant beleave that your selling your stuff :( Ill OC for the both of us..hows that sound??? :cool:
(Sniff) (Sobb) MAN that makes me sad. But I also understand. What kind of Herps ya do. Was big into those for years. Had lots of snakes, Iguanas and chameleons ages ago for a long time. I hope you will keep active here in the forums and thanks for all the Advice youve given me!!!! And Im with My boy BitchBreaker. I will OC/ bench for the both of us to!!!!!
