- Oct 29, 2000
Hey all,
For those of you who use Crashplan for your backup needs, I wanted to check what kind of speeds you are seeing, to see if my own install is performing as expected.
I have a 150/150 FiOS connection. I set my in app upload limit to 125Mbit (to make sure I had a little upstream bandwidth left for other things). My uploads started at ~85Mbps, but quickly dropped off, and now are averaging between 20 and 30 Mbps depending on when I check.
This is obviously a little disappointing. Is this just the way things are with Crashplan, or is it possibly Verizon is throttling me?
Could it be a local machine performance issue?
Backups are occurring from within a Ubuntu Server guest on my ESXi server. I ahve assigned it two cores of my 12 core (24 logical) low power Xeon system. (Base clock 2.26Ghz, turbo up to 2.8)
I told the client it can use 100% of the CPU, wheter idle or not.
Once core seems maxed out at 100%, the other core is hovering at about 20%.
I have disabled deduplication in the frontend.
Any thoughts, is this expected? Would throwing more cores at it have any effect?
Thanks,
Matt
Thanks,
Matt
