XVS Modular 700W ATX Power Supply
Not really. It's a Wintech made unit and it's a bit on the mediocre side. Only 40A on the +12V rail which makes it roughly equal to a quality ~500W PSU in terms of power output. Might be rated at 25C IIRC. If that's the case, then the PSU is not capable of actually outputting 500W, let alone 700W once the PSU reaches 40C.
Unless you're running two in SLI, this PSU will easily power your GTX.
Just one.
Specs :
Gigbayte P35-DS3L
E7200 ( stock volts )
2GB Corsiar XMS2 memory
Western Digital 320GB hard drive
9800gtx
LiteOn DVD burner
and 4 case fans.
jlqrb, don't use it. If you care about your hardware, you won't skimp on THE most important part of your rig. Any new PSU for $11 is most likely garbage. Corsair, Enermax, Seasonic, OCZ, Antec, and PC Power& Cooling FTW!
