XFX doesn't have a LP HD5570![]()
Sadly that card has 2 gigs ram on it on a 128bit bus with memory speed at 1000mgz {slow} memory timing are probably dog slow on a card like that too but they never really talk about that . imho less ram at a faster speed grade is the way to go.No way a card that slow can use that much texture ram not in gaming anyways.
This one costs after rebate $57.99 memory speed 2000mgz 128bit bus 1 gig ram
link
Agreed they are more or less the same if they are useing the same memeory bus bit width and ram speed
but in that review you linked to the 5570 has 2000mgz ram and the 430gt has 1800mgz ram .
link
Chop the ram bandwidth by 50% and watch your fps do about the same![]()
samuelmorris: The HD5570's a fair bit faster than the GT430 (30% by my estimation).
Haste266: the 5570 is fully compatible with PAP. another blow to the nvidia card..
????????????????????????????CHAP/PAP Authentication with Roaming
There are two main authentication protocols that are used by our Internet Service Provider members. The two protocols are CHAP and PAP.
PAP is an acronym for Password Authentication Protocol. It is a method for verifying the identity of a user attempting to log on to a Point-to Point Protocol (PPP) server.
sourcewattage data: (measured with Kill-A-Watt meter)
System at Idle with GT-430 @ 700/1400/1800 = 164 Watts
System folding 10632 with GT-430 @ 700/1400/1800 = 195 Watts
System folding 912/925 point WU's with GT-430 @ 700/1400/1800 = 187 Watts
System at Idle with GT-430 @ 730/1460/1800 = 164 Watts
System folding 10632 with GT-430 @ 730/1460/1800 = 196 Watts
System folding 912/925 point WU's with GT-430 @ 730/1460/1800 = not yet available.
* System in IDLE = 158W
* System with GPU in FULL Stress =196W
* Difference (GPU load) =38 Watt
