- Jul 21, 2005
So I've been attempting to run an Asus P6T7 Supercomputer motherboard but am running into an issue. Here is my setup:
MOBO- Asus P6T7 Supercomputer
CPU: Intel W3570 Xeon (LGA 1333)
RAM: 12GB Corsair Dominator TR3X6G1866C9DF (6x2GB DDR3 1866 (PC3 15000) 1.65V)
RAID: Area 1280ML PCI-E 8x
HDDs: (2) 450GB SAS; (6) 1TB SATAII; (24) 1TB SATAII
GPU: NVIDIA GTS 240 (dell oem)
OS: Windows Server 2008 R2
POWER: Corsair 1000W HX1000
The problem I'm having is anytime I define a raid set on the Areca card, my OS won't boot. I can install Server 2008 on either the SAS raid or the SATA raid, and this problem exists. If the card is physically in but no array is created and initialized, it will boot the OS. But once i create an array, I get a black screen in replacement of the OS booting.
I've even been able to interrupt the blackscreen freeze and get the "Safe Mode" options - which tells me it's seeing the OS partition but is just refusing to move any further... but I'm at a loss. I'm fairly sure this is some type of compatibility issue between the motherboard and the RAID card - as the ASUS bios is pretty primitive and doesn't give me confidence that it's properly handling the boot devices.
Any thoughts?
Any thoughts?
