James Earl Ray
- Sep 7, 2004
My mod is very simple. Viperjohn is lightyears ahead of me. Worth every dollar of it.
James Earl Ray said:710 is gonna be pretty fantastic. I cant wait to see a screen shot. Viperjohn is the guy. The highest I can get is 680. Oh, I got your 7K right here: 3DMark 05 - 7034
2Fresh said:Yes, your your on an FX-53 buddyI hope to hit close to 7500, that would rock!
Aaaaaand to the guy who doubts 7k...VIper was on a damn xp2500 and hit 6780 something. 7K is going to be No sweat..........Fell like betting a couple hunred on it, say $300 I score above 7k?
^eMpTy^ said:2Fresh, when are you getting your card back? I want pics and benches dammit...![]()
joecuddles said:If my card (x800 Pro -> XT) crashes / artifacts at 590, John wouldn't be able to help, would he?![]()
Mister.Auto said:ViperJohn can soup up your card even further with v-mods and adding his cooling setup. Should be able to get around 700 like 2fresh, but it will cost you a fee. Man my 9700pro feels so ancient next to these psycho modded x800s
joecuddles said:Yeah but will it still artifact? Will upping voltage and such get rid of artifcating? I wouldn't think it would.... and would therefore be pointless, so am I wrong?
SocketA said:So how does he/you volt mod the card? Is it with just a simple pencil or what?
Chickenmon said:Probly banned for being a lying douche bag.. Just my guess
See above to prevent condensation. Hopefully (Viper) already included with the price you paid for.2Fresh said:hehehe no worries there. He was running only running an xp 2500 and scored 7k on 3Dark05, and did not even have he settings up that high, wOOt!!! Me on an A64 @ atleast 2.8-2.9 should kicksome serious ass.
I am only going to be running an 80w tec, Viper said that would be plenty.
I guess there are a few mods I wont be able to take pics of...something about him working with ATi and I am not suppsed to show them. But I wil show what i can. =) All the stuff you will need for tec..![]()
1. Spray card (around GPU-front and back of the card) with Conformal coating
2. Apply Luberex dielectric grease around GPU core and AGP/PCI-E socket.
3. Put seal string around GPU socket front and back and cover it with Neoprane.
2
CleanSlate said:How does foam prevent condensation? I've enver used water cooling stuff before, do you just cover the water block entirely with foam except for the bottom of course?
~Adam
nst6563 said:the foam will act as an insulator, and a barrier to the components. So if the foam gets cold enough to generate condensation, the components won't get wet...just the outer layer of foam. It will also help keep the cold confined to the card so it won't escape to the surrounding air as easily.
Much the same principal as using foam around hot water pipes to keep the heat in...it improves efficiency...but in this case it not only keeps the cold confined to the card but prevents any condensation from touching the components as well.
It is necessary if you plan to use TEC on your GPU b/c sometimes the temp.of water will be below ambient temp.and condensation will follow. For regular water cooling it is not necessary. Check this:......http://wwww.vr-zone.com/?i=230&s=4.... A lot of work to protect your expensive video card.....CleanSlate said:How does foam prevent condensation? I've enver used water cooling stuff before, do you just cover the water block entirely with foam except for the bottom of course?
~Adam
