i'm pulling an all nighter![]()
Don't accidently push the publish button early
Sine October 1983 to be exactThe C't magazine has been around since 1996 and I would regard it as the computer magazine with the most consistently well-researched articles. Unfortunately, they do not have an English language version. Regardless, if the article scanned above is indeed a fake, it was been rather well done, since the layout is copied exactly from the magazine.
Havent been this giddy for a review since the 9700/9500 came out.
http://www.xtremesystems.org/forums/showpost.php?p=2186824&postcount=978Image comparisons between 2900XT and 8800GTX:
Deep Feeze 2900XT: http://img215.imageshack.us/img215/6213/1dfpg7.jpg
Deep Feeze 8800 GTX: http://img297.imageshack.us/img297/3573/gtx1xv2.jpg
Canyon Flight 2900XT: http://img213.imageshack.us/img213/7387/2cfgq1.jpg
Canron Flight 8800 GTX: http://img120.imageshack.us/img120/1743/gtx2br1.jpg
Agreed, In the first set of pics the boxes on the HD have more detail. The telephone wire to the left have a bit more detail to them as well on the HD. As for the second pic the pointed spear on the front of the balloon is more visible in the HD then in the G80. From what I read in that forum those pics were setup by 2 different persons. And, the G80 pics have less compression.Look closely at the tip of the blimp in canyon flight.
The 2900XT does AA slightly better than the 8800 GTX.
that dude is freakin ugly without those hd2900xt
Compare the file sizes, somethings not right.
For Deep Freeze, the jpg marked for ATI is 109.97kB and the one for the nvidia card is 358.45kB.
For Canyon Flight, the jpg that is marked as ATI is 123.17kB and the nvidia one is 628.75kB.
If these jpgs were really taken by the same person, why would they use so much less compression quality for the ATI ones, like 3 to 5 times less? If they were meant to compare image quality, they would have used PNG 24 bit, something lossless. If you ask me it looks like either those shots are not meant to be compared to each other, or somebody's trying to sabotage the impressions for one of those two cards. If you know what I mean.
Damn vr-zone is getting hammered right now.
The high points I've managed to hit is that...
1. Its slightly hotter than a 8800.
2. AF is possibly slightly worse than 8800, but on max AA seems to be slightly better on the 2900xt.
3. The 65nm tech must be NIIICE because the 2600 cards are only rated around 45w if this is correct. That means that next gen GPUs on 65nm may get back down to reasonable wattages.
Still trying to load a bit more though.
Idle, you can see core at around 54C while loaded it goes to 71C without any overclocking. And this is one setup lying naked, imagine it in a case! Definitely one of the hottest cards around. The temperature-controlled fan on the card has little time in slow-spin operation, spinning up not long from start of operation, and perpetually all the time when 3D is ran. Not too much of a worry since it's not loud, but the noise is definitely audible.
3D Mark 06 SM3.0 Test "Canyon Flight" was ran to record the power consumption. The whole setup was the same except for Video Cards. Setup Specs on the next page.
PowerColor HD X2900XT Idle: 245 watts Load: 365 watts
ASUS EN8800GTS 640MB 513/792MHz Idle: 240 watts Load: 300 watts
Vrzone graph said:Quake 4 ultra quality 1600x1200 16xaf:
ATI 2900XT: 98fps
eVGA SC 8800GTS 320: 109fps
Vrzone graph said:2142 battlefield 1600x1200 16xAF 4xAA:
ATI 2900XT: 32fps
eVGA SC 8800GTS 320: 70fps
Again, like what we've seen in our Lost coast tests, when Anti-Aliasing was turned on, the X2900XT faced performance issues, due to current driver implementation for sure as you can see it losing out to even the X1950XTX.
I would post more examples, but it continues on like this basically...VRzone review said:At normal view screen size you can already tell the difference. Look at the gun, that's closest to your character, you can see it starkly sharper on the 8800 compared to the 2900. Notice especially the words and buttons on the gun. Words are sharper and so are the finer details on the buttons on the card below. Even the dirt track further away from the character looks sharper rendered on the 8800.
(PICTURES HERE WITH NOTICEABLE DIFFERENCE)
I'm going to reserve judgement until [H] completes their review, but I think this is ridiculous. If you've got a properly ventilated case, temperatures should be lower with the case closed than open. 71C? It's like they ignored the 6800 series when they're talking about it being so hot...
For the first I saw on the artic landscape picture is the GTX seems a bit dark on the shady side of the boxes. I wonder if there is any settings to adjust for that or if it is an authoring issue? *shrug* But the overhead lines and other thin objects are WAY better on the XT. On the other hand there are a couple of places where the XT is softened enough that it is close to being "smudged".
The second set of picts don't show up for me.![]()
I've uploaded them where you can swap between the pics easily, to make comparisons:
Canyon Flight:
http://users.gaelic.ie/handspun/daniel/xt.htm
Deep Freeze:
http://users.gaelic.ie/handspun/daniel/xt2.htm
Oh, on the corrugation of the roof? Yeah, it looks smoother but more also flatter and sort of smudgy, like with the XT on the right-side edge of the mid-field building which is smoother there than the GTX but also has a bit flatter feeling. That was the smudginess I was talking about but I incorrectly identified all of it to the XT (I was trying to look at the pics as "brand-blind" as possible and got mixed up there, oops...but in Deep Freeze you can see some rougher edges on the XT's building on the lower right of the shot.
I forsee that being a big issue if reviews aren't really clear about what version of the driver they are using given the huge performance differences between them as well as currently unknown IQ differences.My biggest problem right now is that ATi apparently released a new driver update very recently which increased performance something like 11-42% (It's in the VR-Zone article towards the end), but I'm not sure who is testing with what drivers and whether that will paint a skewed picture. I wonder if IQ changed at all as well with those new drivers..or whether there is more performance to come from future revisions.
So, Brent.....is this review going to drop at 12:00am GMT or do we have to wait it out until 6:00am CDT? Might as well post it earlier since the servers are going to get hammered today! And I've got nothing better to do tonight than stay up awaiting official reviews![]()
Thank goodness for Starbucks
Yep, so I guess my eyes weren't deceiving me after all. What you described is exactly what I noticed also. It's not a huge difference, but it is noticeable on close inspection.Deep Freeze
The telephone wires (the one to the left) are sharper and fuller on the HD. On the GTX there are gaps in the wire and is blurry. There is another telephone wire far left, middle of the pic that also shows sharper fuller lines on the HD. On the GTX there is pixelated gaps.
The roof top edges on the lower right side of the photo is sharper on the HD. The GTX is blurry.
Cayon Flight
The pole on the front of the balloon is more visible in the HD then in GTX. It sticks out a pit further and is obvious to see. Other then that, both photos are the same.
From looking at these pics, it's obvious that HD has better IQ here.
