RESTfulADI
- Feb 20, 2005
Prot past tactical mastery is useless unless you are tanking.
I hope you're taking Defiance more for the expertise than the threat generation, since as a DPS Warrior, the last thing you want to generate more of is threat. Also, reducing your target's ability to dodge or parry seems a little counter-productive, as you should be looking for any excuse to whack them with Overpower.I accidentally leveled to 60 last night from the NPC's in AV lol. I only have a few marks to go until I get the raptor mount, so I'll only get pwned by the level 69's for a few games.
What is a good build for 60-70? Before I did BGs I was primarily Fury, now Im currently 35/13/3. I have a Shammy friend to quest with most of the time, and I was planning on doing a fair amount of dungeons on the way up too.
I was thinking at least some prot would be good. Maybe something like 6/31/14 to start, and then work back up through arms. That gets me the extra defense, more threat and last stand.
I really haven't seen a good Fury Warrior since before The Burning Crusade came out. All the DPS Warriors I see nowadays are running around with big 2 handers and specced something like 33/28/0 or 34/27/0.
FYI once you ding 71 in wrath all of your ratings and arena points are wiped.
Once you ding 71 all your purps will be replaced by Northrend greens
I didn't start replacing naxx and aq40 gear until at 68ish and I think I even took a piece or two (wraith blade, some t3) to Kara for the first couple runs. If they do green gear that same way again you won't be replacing T6/S3 stuff with greens til at least 75+.Once you ding 71 all your purps will be replaced by Northrend greens
False. If you have good gear from BC you won't replace it with the first green that comes along. The same outcry was heard when BC was about to come out and it was proven false.
I've replaced my two trinkets from 70-71, from the Bloodlust Brooch (badge one) and the Hourglass, to a green quest reward haste trinket and a stacking crit trinket (like the darkmoon card one)
Negative. Unless wotlk is a complete departure from tbc. There are several items from pre-bc that are still used in tbc. Rejuv gem and neltharion's tear for example.
That damn tear slipped through my fingers at least twice. And shadow flame never ever dropped. Damn you Nef.Negative. Unless wotlk is a complete departure from tbc. There are several items from pre-bc that are still used in tbc. Rejuv gem and neltharion's tear for example.
