Well, I can get a 2500k at Microcenter for $180, so the FX-8150 would have to be around $120 before I'd even consider buying it.
People need to stop freaking out about the power draw.
I don't see anyone "freaking out." The plain fact is that AMD's new flagship CPU is a hot mess and some of us actually care about power consumption. As a result, we wouldn't willingly buy an under-performing, power hungry CPU when there are better options to be had.
And since we are telling others how they should feel and what they should think... People need to care about power consumption and purchase the best performer per watt. That will cause CPU makers to continue to see lowering power consumption as a priority. In case you hadn't noticed, energy consumption is becoming an issue in the world.
i'm sorry but what chips do the fx 8150 under perform against ? I can't find any in the hardocp tests.
Wait.....Uhmmmmm.... This is a trick question right.....???
PS, that's MC's price stickers for 8120 and 8150 respectively...
Its only 10 Watts more @ stock is it not?
on another note, I have to ask those who still support the BD and their multicore approach....
would you buy a 24-core Intel Atom for the same price as the BD ?
Surely those 24 cores should beat the 2600k and 8150 in multithread.
Yes, though he is asking, at 24cores (48 with HT), and assuming no wierd scaling issues, would the theoretical multithread performance of a 24core Atom be better than BD? Also consider, BD's IPC is less than K10...
atoms are very low clocked and very slow.
I don't see the comparison your making the fx 8150 actually keeps up in benchmarks with the i5 2500k .
Does the atom keep up with a bulldozer in anything ? I had a 1.6ghz atom and it was slower than my 1ghz athlon
that's exactly my point.
it's a theoretical question that i think relates to the arguments FX buyers are considering.
of course the atom by itself is slow as hell. But combine 24 Atoms into one cpu for some megathread task, and assume it meets 2600k multithread performance.
would you buy it ?
[...]i just think to many people are over stating the facts here , the fx 8150 performs similar to the i5 2500 in a ton of stuff.
... and it doesn't in a ton of other stuff. If the FX 8150 matched the i5 2500k in almost every way, and exceeded it in some, too, then the price would definately be worthwhile. But it doesn't, and that's the problem we have in this thread (as per the title).
Sure, since it's half the price of 2500k which is what I think they intended for it to compete with, but it sure fell short.
But you'd have to be high if you think AMD would cannibalize their Thuban sales. Actually, I have no idea what they're going to do, except shit their pants.
