NightReaver
- Apr 20, 2017
Well they lack hyperthreading, too.E-core is normal core
If you use Hyper Threading on P-cores then each thread isn't much faster than E-core so in that sense with HT enabled you get similar performance out of each thread if you use all of them.Well they lack hyperthreading, too.
For the most part. Some people are finding it's better to disable them in a handful of tasks. Luckily they have a 1 button toggle for them.Existence of E-cores does not cause any performance issues.
Not to some operating systemsE-core is normal core, just slower than P-cores. Still not terribly slow and actually comparable in performance to Skylake CPUs.
On my 13600KF with E-cores overclocked from 3.9GHz to 4.3GHz I got performance between Core i7 9700 and 9700K in Cinebench on E-cores alone. Games also run fine on them.
Applications do not need special support for E-cores.
Who said anything about windows?Windows 11 knows what E-cores are so here no need to tweak anything.
Not sure how all OSes and/or programs behave but surely there might be some unexpected behaviors if OS cannot figure out it should schedule threads to P-cores first. That would depend I guess on kernel/system version. It is definitely something people experienced on Alder Lake in the past.Not to some operating systems. And not to some workloads. Depends on your scheduler. Mine don’t acknowledge that they exist. And can’t tell the difference. That results in odd performance.
