MrGuvernment
- Aug 3, 2004
For one, stop assuming i was using XP proir to Windows 7, I wasnt, i loved Vista, but i had my "bitches" about it,not saving folder views, but then i am sure you would just argue i should accept the new OS cause it is better....
Wow, defensive aren’t you, super bar is the only issue i have with 7, something i was very used to and enjoy, i have gotten used to the new super bar, but that doesn’t mean i like it.
Exactly, it is more clicks, sure it only adds some seconds, but the point it, it takes more to do the same thing.
has nothing to do about being hard, it is simply something i dont like and to me is a step backwards, i know plenty of people who dont use the quicklaunch, never did, i used it alot, and i liked it.
Again, how is having to click something , which previously only took 1 click, which can now take 2 or 3 more, intuitive? your seem overly defensive about this matter....
exactly 1 click , done
Again, you keep going on with this bitching and adapting, get over yourself and your great ability to move on to a new OS, as said, quick launch is the only issue I have with windows 7, it is my pet peeve, but isn’t stopping me from using it, so drop your superior attitude, this has NOTHING to do with being lazy, or unorganized, it is about having to click multiple times now to do the same thing that coudl be done before with 1 click.
I don’t want to create a new toolbar to launch a folder, i want to launch one single file with 1 single click, not going into my documents, which is very organized by type and name and open the file, maybe you don’t have that many documents, but at work i have about 15+ txt files i open daily alone with diff info in them, then various excel files, word docs and so on which i use daily, it is nice to click /open done, not click, find, with say notepad, by the end of the day when i right click on the notepad icon i can have 20-30+ note pad files now listed there, which i only opened once and may not again for some time, so now i need to search through those ones to find the ones i use, waste of time.
no, the new taskbar does not have ALL of the functionality of the old,. i cant open a document with 1 click
For you it may be better sure, but wait until you get 50 .psd files there... have fun searching through them all to find the one you want.
Now, what they should do is the option for:
"Store and display recently opened items in the start menu and the taskbar"
should of separated it, cause if i turn that off, the super bar now only has links to open programs , and no documents, all it would take is one simple option.
I love your attitude though about how we are all lazy and can’t figure things out, i had this task bar figured out the first day i had the beta's installed and didn’t like it, i have tried everything i could find to make it work how I like it, but doesn’t seem possible, so me being "so dam lazy" according to you, since you are the all mighty know it all, I adapted to the new one, but i still don’t like it. I haven’t used XP since Vista came out either fyi, i don’t like XP, it is old and dated and needs to die.
Really, get over your self righteous attitude of being so above everyone cause you’re not lazy and figured things out, most people likely had windows 7 figured long before you even had it installed, and i am sure others don’t like the superbar. I am sure there are plenty of things you have bitched and complained about that are related to computers that others didnt, doesnt mean they should claim you are things your not when you dont even know the person.
I will come on here and bitch and praise all i want about whatever i want, you dont like it, dont read it.
So.. install Vista, hell, install XP or 2000. Leave the advancements of modern OS'es to the rest of us that can learn how to adapt to a more useful system.
More clicks to do the same thing he wanted to do sounds suspiciously like a step backwards, not an advancement.
Different usage habits have different optimal UIs, it's not rocket science, and there is no "one-best-way" that is the same for everyone.
Get a grip?...
Moving your wrist more then 1cm either way is apparently to hard for you and I'm out of touch?
Fight with me all you want but I embraced the innovations of Windows 7 (as did many, many other enthusiasts/power users on this site) and have adapted to where they are MUCH more intuitive and fluid.
Like I said.. Install XP be done with it.
advancements to those that can adapt? are you shitting me?
does Microsoft, who is constantly trying to dumb things down for 'every-day users' or 'parents', do you think they know best on how you should run/setup your workstation?
get a grip, man. there are plenty of software apps out there who on their continuing quest to 'find a reason to get you to upgrade to a new build', fuked something up...hence, why many people continue to use older revisions of software.
quick launch works great for me...i have all of the programs i open quite frequently (and hdd partition shortcuts), right there. a single click. done. even opening the start menu and moving my mouse 1/2 way across the screen and finding my app is a pain.
taking my hand off the mouse to type to find an app is a waste, as well (except for non-common used apps)
More clicks? Um, wtf are you talking about? One click, bam, program launches. Why keep an actual text document on the bar? How 'bout organizing your documents? That's what "My Documents" is for. If you really want, right click the taskbar and select "new toolbar". You can put any folder and it's contents on the taskbar, and you can launch individual files from the taskbar if you want to.
You may have known this if you were spending less time bitching and more time actually getting to know the taskbar/OS.
Now, with that said, stfu and enjoy W7 - which is leagues better than the fossil that is XP.
CLIFFS: If you're really THAT lazy and need to open individual documents from your taskbar, right click the damn thing, select "new toolbar" and select whatever folder you want, containing whatever documents you want. Launch them straight from the taskbar. Bam, quit yer bitchin'.
Why do people complain when someone wants to change something to their liking? It's a matter of preference and everyone CAN DO whatever works best for them. I like the quick launch bar because I think it's better than the new one. That is all there is to it. And yes, I will continue to use new operating systems for their other features- namely the way they control hardware.
The new taskbar is basically the same as the old one. The reason some of us are saying you should "deal with it" is because the new taskbar has ALL of the functionality of the old one, plus new features that you all DON'T have to use.
Seriously, read my last post. It's as simple as "right click, new toolbar". Bam, done, end of story.
Don't let the fact that some of you are too damn lazy to figure this shit out be the reason that you're stuck with an obsolete OS.
EDIT: Wow, I just found out that you can pin inividual files to whatever program you have pinned on the taskbar. I dragged a .psd to the Photoshop icon and pinned it...now I just right click the icon (of left click/slide up) and choose which file I want to open. Fucking WAY better than anything the old quicklaunch had to offer.
