Windows 11 25H2 announced
Well I went ahead and installed it. When I checked the version, I had 26100.4946 so I had to install the preview update to get it to the correction version 26100.5074.
I normally don't install preview updates, so I'm guessing that this version will be released next month? The install took about 2 minutes, then a reboot. Now this old Dell N7110 is running 25H2.
I have a bunch of my systems still on win10...
I suppose it is time to update. Some need a full wipe...any idea if the new version will work with the unattended file you can make Here?
not sure, dont know it. but if you can integrate command lines you can add a bypass.
The "final" version that OEMs install on their machines = now available as an ISO. The changes are minimal if not outright non-existent. I think the only proposed item that made the cut was the mobile device start menu link. I don't use that, so I can't even test it out.
It's a day later and I'm still not seeing any changes on the surface, BUT I will anecdotally say that my PC feels snappier. When I open up Microsoft's PC Manager, it's showing fewer resources being used (doing the same tasks with the same apps open) as well. Roughly 10% less. It might be a coincidence since there were updates to Photoshop, Nvidia drivers, Chrome, .NET, Office, etc. all rolling out around the same time. But, hey, I'm not going to argue with it.
The enablement package for 25H2 is now available. Windows11.0-KB5054156-x64.msu
More info and additional download links:
https://www.elevenforum.com/t/kb505...e-preview-build-26200-5074-25h2-aug-29.39323/
Installing the enablement package takes only seconds and will convert your 24H2 (26100) install to 25H2 (26200).
I would strongly recommend upgrading your 24H2 install to 26100.5074 before you install the enablement package. This is the version currently offered in Windows Update as a "preview" update when you have "Get the latest updates as soon as they're available" toggled. From my testing, the enablement package will still convert older versions of 24H2 into a "25H2" equivalent, however you will not be offered the latest cumulative update afterward, since you would essentially be running a version of 25H2 that never existed. You would potentially be stranded on that oddball version until, forever? Microsoft has specifically mentioned that 26200.5074 will receive monthly updates going forward. If you do use the enablement package on an older version of 24H2 accidentally, you can always fix it by doing an in-place upgrade to 26200.5074.
Installed the enablement package on my up to date Win 11 IoT on a Surface Pro 3. We'll see where it goes from here.
The first 24H2 version that isn't a preview version (26100.6584) and can be safely updated to 25H2 via the enablement package was released this week (the September cumulative update).
25H2 (26200.6584) is still considered a release preview, but given how similar it is to the non-preview 24H2 (26100.6584) version, I feel pretty safe updating all of my systems to 25H2 at this point.
which channel, beta? im in dev and im up to 26220.5790. or you just talking downloads?
The "release preview channel" is where 25H2 (26200.6584) is at now. But anyone can update to 25H2 without being part of the insider program by just installing the enablement package.
Right now they have the Beta channel (26120) testing 24H2 and the Dev channel (26220) testing 25H2. But those builds have additional insider restrictions and will expire, etc. Release Preview builds will eventually update to normal versions via windows update.
oh, right, used to us talking the previews/beta/etc whoops.
  • Windows11.0-KB5054156-x64.zip
installed 25H2 today, some kind of update also came for Windows 10
Windows 11 and 10 updates always come at the same or similar times, I have both so I can keep track.
It's still available under Linux:
Sorry if I replied to this already BUTTTT
Srsly that was one of my first games and definitly my first digital pin ball game.
Do we all remember Asteroid ( Or was it something else? Whatever, the one were you start 2D space ship in the middle and your defending Earth or something vs Comets and Asteriods.. ) , Spectre 3D, Wolfenstein 3D, Lemmings, Patriot Command and Spin Doctor??
Just to name a few.
I'm not upgrading to 25h2 anytime soon. At work I can supress the upgrade notification through AD for our older machines and Intune for our newer machines. How can you permanently suppress the 25h2 upgrade notification on a home machine? Is it even possible?
Steve Gibson's app "In Control" will stop upgrades until you release control , It works without installing
https://www.grc.com/incontrol.htm
HTH
Given that 24H2 and 25H2 are actually the same under the hood, it's pretty silly not to upgrade. This is not like the upgrade from 23H2 to 24H2, which was fairly significant.
If they are the same under the hood, "oobe\bypassnro" itself makes it worth not upgrading.
I can only assume that you are talking about the recent change Microsoft made to some of the insider Dev and Beta builds where they removed that specific bypass method?
https://www.windowslatest.com/2025/...icrosoft-account-internet-during-oobe-tested/
This change is rolling out with Build 26120.6772 and 26220.6772. These two builds are available to testers in the Beta and Dev channels, respectively.
If that's your only reason to not upgrade to 25H2, then I've got bad news for you, because according to those build numbers the change is coming to BOTH 25H2 and 24H2. (26120 is the Beta for 24H2, 26220 is a Dev build, but the channel is being used basically as a Beta for 25H2).
But the good news is that the change is not implemented in the current version of 24H2 or 25H2. It has only been seen in the insider builds. Even after it's implemented (if it's implemented at all), you could still just install using an older ISO and then update, or just use the Domain Join method which is easier anyway, and certainly not going away any time soon.
And to add.. the BypassNRO "feature" is just the script that has been removed. The registry key can still be set manually, or whatever deployment method you want to use. (if you choose to do something other than domain join.. which essentially results in the same outcome)
yup, if anyone needs it just search the forum for it, youll find several posts...
I searched and only found this:
reg add HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\OOBE /v BypassNRO /t REG_DWORD /d 1 /f
shutdown /r /t 0
this will allow the "i dont have internet" option to appear and you can create a local account again.
oh and do it offline, as per usual.
shutdown /r /t 0
yes, those are the instructions i posted.
Question: on Windows 11 home, if I press the Shift-F10 keys, will I get the CMD window where I can enter in those commands or has the Shift-F10 been disabled?
Shift+F10 should still work. For Windows 11 Home, I would do this all with your network connection disconnected. I believe in the latest release, there were some shenanigans where even doing the bypass, it would revert to still trying to get you to setup using a MS account.
LOL: yeah right. If it's so dangerous, the EU does not have to engage in using a MS account. I wish someone would sue MS on this issue for privacy.
Just use your computer with ALOT of security, passwords, encryption and various 2fa etc.
Then we can share our poems, cat pics and food receipts in peace!!
If you're interested in trying out the new Start Menu, you can do it with the current builds.
https://www.neowin.net/guides/windo...improved-start-menu-here-is-how-to-enable-it/
If you want to revert to the normal version, you can run the same commands, but use the word "disable" instead. I tested it out for the hell of it.
The categories thing seems better on paper than reality because you can't edit anything. You're just kinda hoping your system chooses correctly. With mine, it was 1/2 right and 1/2 way off. I'm pretty OCD with categorization and install directory names, too. It also tosses full folders into the category listings so you're still having to complete 2 steps to reach certain apps. Unless they plan to allow you to control those categories, those are a miss.
I hoped that it would finally let you scope out the size of the start menu, but nope to that, too.
Going with the app list view was probably best for people who are used to the current menus. I found that to be mostly fine and easier than having to hit the "All" button like we do now.
The best thing about it? Recommended IS finally gone! I've long hated that waste of space and at least on my setup it was completely missing.
Anyway, since this is all stuff that is still being worked on, maybe some of my complaints will be addressed before they roll it out for real. If not, at least recommended is gone and the list view isn't so bad. Categories feels like a massive waste if they don't allow tweaking, though.
i guess its better if you had a prob with it. this is the "new" option menu. i rarely use it, not much need to when you can click it and type two letters to pull up what you want or pin everything i use often...
I don't necessarily dislike the current Start Menu for the most part. I despise the forced "recommended" section and I wish the way it handled the normal program shortcut folders was better. The new one actually does both of those things, so I guess there's that. I think my hope was that we'd be able to resize and restructure it. That doesn't seem to be the case.
Question: Why is 24H2 or 25H2 not automatic? All my other updates are... still got this one sitting waiting to install because what I have works and don't want it possibly borked...
Also... I'm thinking to just re-install, anyone got a 'how to' link for usb install already incorporating 25H2?
because its a major os update, it will wait for you to do it unless you have the "get me up to date asap" box ticked.
ok... the media creation tool from ms will give you 25h2.
