mrgstiffler
- Dec 20, 2000
Does it cease to work if you put your task bar on the left side of the screen?
I need to manually click its button or the hot key to bring it up. Typing in the start menu does absolutely nothing.
This build breaks support for Creative X-Fi cards.. Will eagerly wait for Creative to release a beta driver 6 months after Windows 10 is released
Avast free is also now incompatible and will be removed and not able to be installed..
I got the Creative driver from Windows update but had no sound through the speakers. Finally determined there was sound through the headphone jack. Went back to Device Manager, did the "update this driver" thing for the Creative card and chose to use files on the computer. It did some updating and reconfiguring then the speakers began to work. Read on one of the tech preview forums that Update might install the drivers wrong or in the wrong place so try and get them to update again. The files are somewhere in the computer but just didn't install properly the first time. Haven't bothered to try the ton of other Creative software but glad to get sound working through speakers.
Everything seems to be working as advertised now. Creative drivers are always beastly and was expecting the worst but guess MS was smart enough to figure a way to get them to work. Now waiting on a graphics driver for the new build of 10.
Not installing a lot of stuff on the preview and almost nobody has drivers for it. They mostly have to be pushed out by MS through updates for the time being. Tried Nvidia 8.1 graphics drivers and they were much worse than the ones offered through Update.
why does this button go over the 1px border on the right side
also slowly losing my sanity to search being seperate from start
Oh, for anyone who wants to go back to the start menu as used in the previous builds:
Open regedit and Navigate to HKEY_CURRENT_USER>Software>Microsoft>Windows>CurrentVersion>Explorer>Advanced
Create a new DWORD (32-bit) value, call it "EnableXamlStartMenu"
Restart Explorer​ (or just logout/login or reboot) and enjoy the old Start menu.
Now the old start menu is back and I can use the quick search again!![]()
Nice. For the time being it'll work, wouldn't count on this hack surviving through to the RTM though. Same way in Windows 8 dev preview you could reghack the start menu back, then they removed the ability in later builds after it had become extremely popular.
I'd call this an unfinished alpha, the only purpose is for people to actually submit feedback. There will be tons of issues I'm sure just like the last build. e.g. I tried to upgrade from 9879 and the update failed and rolled back to 9879.
anyone else hate the new windows updates? they removed the old windows update from control panel, now you have use idiot metro app, that doesn't even let you pick what updates to install.
Hmm so you actually cannot get aero in windows 10...
a fisher price childrens playground.
You can tell Explorer to start in "Quick Access" or "This PC" from Folder OptionsHow can I prevent file explorer opening in that dumb quick access section?
Hmm so you actually cannot get aero in windows 10... I am happy with the way win7 on aero looks... Win10 looks like a downgrade aesthetically... at least it is free and should perform better than win7.
I really hope that they do something about the visuals of this before it is released... I assume that this is a preview so hopefully it will look a lot better when released! Reminds me of a cross between windows 7 on non aero mode and a fisher price childrens playground.
Really, what's so hard about giving the OPTION of the classic Win7 start menu, and then people can still benefit from the Win10 changes under the hood. desktop users are going to ignore metro apps and the metro store again either way, just like they did in Win8. Might as well let them be comfortable and use the OS on their terms, not Microsoft marketing's.
Right Click -> Sort By -> AscendingNot sure if this was asked already. Just installed this on a test box w/3 hard drives. Windows Explorer shows the drives in reverse order (ie. E: then D: then C: ). Never seen that before. Any way to get it to show the drives in proper letter order?
EDIT: mmm, seems it's listing them in alphabetical order by drive label. Don't like that at all.
Damn I liked 9889 betterTypical M$ one step forward ...two steps back.
Thank you! I can stop kicking the walls now.Right Click -> Sort By -> Ascending
Curious, everybody that installed 10 preview, did you put in the default 16 digit code because I was not prompted for it and it's activated and working fine.
What Nvidia drivers do you guys have installed and did you get them from Windows Update or Nvidia.com?
I'm running 344.75 but I've seen reviews of the latest Tech Preview that say they got newer drivers from Windows Update. Not sure why I'm not seeing them.
whats the point of submitting feedback when they don't listen.
everyone wanted start menu back, and what did they do? create this bastardized menu that mostly is un-usable, just bring back the old start menu that everyone wants.
