Windows 10 Enterprise LTSB Edition is a winner for power users
Discussion in 'Operating Systems' started by DPI, Nov 6, 2015.
  1. heatlesssun
    heatlesssun [H]ard as it Gets
    44,263
    Nov 5, 2005
    Those are still there as they don't have anything to with store apps. The Alarms and Clock and Calendar apps I think are actually useful, one thing Windows never had as a built in timer app which Alarms and Clock provides.
  2. craigdt
    craigdt Gawd
    1,002
    Oct 27, 2016
    Is there any downside to using LTSB as a ln everyday rug for gaming/mining/plex/streaming etc?
    I basically want Windows 10 without the bs, but don't want it to bite me in the future
  3. Mazzspeed
    Mazzspeed [H]ard|Gawd
    1,414
    Dec 27, 2017
    Yes there is, it's only available under Windows 10 Enterprise, so short of piracy it's not really a realistic option for almost all users.
  4. AltTabbins
    AltTabbins [H]ard as it Gets
    18,388
    Jul 29, 2005
    Dx12 support and no windows store for microsoft games like gears of war. Also as mentioned, you need an license agreement not available to the public. Pirating an operating system is probably the 2nd stupidest thing to pirate with the first being just downloading a keylogger.
  5. craigdt
    craigdt Gawd
    1,002
    Oct 27, 2016
    You are saying LTSB doesn't support dx12?
  6. AltTabbins
    18,388
    Jul 29, 2005
    It doesn’t. Last I heard a few months ago.
  7. jyi786
    jyi786 [H]ardness Supreme
    5,535
    Jun 13, 2002
    Don't know where you heard that, but LTSB definitely does support DX12. I just got finished playing a round of Deus Ex: Mankind Divided on DX12.
    Just for kicks I also installed 3DMark TimeSpy, which is a DX12 benchmark, and that runs just fine as well.
  8. AltTabbins
    18,388
    Jul 29, 2005
    Heh, I guess I read wrong. My bad.
  9. B00nie
    B00nie [H]ardness Supreme
    7,812
    Nov 1, 2012
    DX12 is a gimmick anyway.
    qb4ever likes this.
  10. jyi786
    5,535
    Jun 13, 2002
    Without me trying to derail the thread, it might be overall. But when I switched back and forth between it and DX11, it sure feels like it was overall much smoother. Less hitches and jank.
  11. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    8,389
    Jun 13, 2003
    Relative to Vulkan, which is really what every engine should be pushing for, it is a bit of a gimmick, but on its own it's solid and comparable as a technology. It's just limited to Windows 10 and that makes cross-platform stuff harder.
  12. Morlock
    Morlock Limp Gawd
    458
    Jun 8, 2012
    Because...?
  13. Nenu
    Nenu [H]ardened
    18,457
    Apr 28, 2007
    dur
    They tend to come preloaded with unknown extras.
  14. Morlock
    Morlock Limp Gawd
    458
    Jun 8, 2012
    Bah, not worried about that.
    I mean for one thing, you can just go with an activator, way easier to screen something that small for problems.
  15. jyi786
    5,535
    Jun 13, 2002
    Back on topic.
    I tried to convince myself that LTSB wasn't the way to go. So I made a complete image of my perfectly working LTSB install and used MSMG to create a "slimmed-down" version of the Windows 10 Pro Creator's Update ISO. Removed all the bloat, formatted my drive, and did a clean install.
    And WOW. What an unbridled disaster it is. On the surface, it can be just as functional, if not more functional, than LTSB. But it's freaking bugs galore. I'm talking simple OS level stuff like DPI broken/wonky, Windows Explorer thumbnails broken (black corruption around rendered folder icons), screen jits/resets (without any errors), etc. Mind you, each one of these issues have had no real fix from Microsoft after a long time of them being reported. And it's certainly not drivers, given the fact that it's all the same as before. The only change being the OS.
    After 2 hours of trying to put up with it, I wiped and restored my system image, and back to bliss. Everything just works in LTSB.
  16. jlbenedict
    jlbenedict [H]ard|Gawd
    1,277
    May 22, 2005
    The Creators Update has been reported by many to be just straight up garbage.. I don't care what the defenders in [H] will say.... [H] is a small sample size, compared to all the other complaints out there..
  17. jyi786
    5,535
    Jun 13, 2002
    I'd be willing to give MS the benefit of the doubt...but I just couldn't. It was that freaking bad, and I'm not exaggerating. Simple things like corruption in Explorer thumbnails right out the gate of a clean install??? Sorry, not on my rig.
  18. chrcoluk
    chrcoluk [H]ard|Gawd
    1,208
    Jul 7, 2008
    There was a guy selling the licenses on the itialian ebay, I brought one and it activated fine. It seemed suspicous because he was providing his own hosted iso file, which obviously had me wondering if it had some kind of activation hack, but I activated it on a legit microsoft iso.
    However he is now gone from ebay.
    Aside from potential legal issues, it is a feature frozen version of windows 10, the full enterprise lets you choose the branch to use, these LTSB versions, you are locked to the LTSB branch. This is good or bad depending on what you want, the updates should work like windows 8.1 where its bug fixes and security patches only, so there should be none of those large feature updates which reinstall the OS. No MS store or cortana by default, can set telemetry to basic, can disable automatic updates and automatic reboots, however its still hard to pick and choose updates, you have to use that external tool microsoft made for that.
    The latest LTSB is from 2016, so the latest security enhancements are missing from it, that gamer ultimate mode is missing and I think some updates related to HDR displays. But of course it has newer features than windows 8.1.
  19. AltTabbins
    18,388
    Jul 29, 2005
    Windows 8.1 is a great option that a lot of people forget about. It got a lot of flack in its time but in retrospect, after using windows 10 for a while, 8.1 really wasn’t that bad. It’s probably the closest thing to 10 LTSB.
    jyi786 likes this.
  20. IdiotInCharge
    8,389
    Jun 13, 2003
    If you run a start menu replacement, you'd never know in daily usage- took me years to see the W10 interface because my Start8 install ported over upon upgrade and continued to function seamlessly :D
  21. Chas
    Chas [H]ardness Supreme
    6,289
    Oct 31, 2005
    I'm content sitting on the 2015 LTSB for now. Pretty much everything works-ish. Few hassles.
    So I'm content to forego the 2016 LTSB and wait for the next one to emerge.
  22. jyi786
    5,535
    Jun 13, 2002
    This is the truth. I have had my copy in a VM for the last 4 years, and it's had zero issues.
    2016 LTSB is what I'm on now. With the Classic Shell Start Menu replacement, it's literally perfect.
  23. B00nie
    7,812
    Nov 1, 2012
    This is because Microsoft has knowingly embedded key system parts to spy/ad components with the intention of breaking the system if someone tries to remove them.
  24. Hagrid
    Hagrid [H]ardness Supreme
    7,993
    Nov 23, 2006
    How much of this is still left in enterprise? If some business's have to be hippa compliant, would that not break it?
    Mazzspeed likes this.
  25. DPI
    DPI Nitpick Police
    10,999
    Apr 20, 2013
    You're 100% wrong. You cannot "fully uninstall Cortana, Edge, the Store" and everything else I listed post-installation, with powershell or GPEDIT. I've tested it in FCU Pro, both with powershell and GPEDIT. Cannot be done, and you're welcome to prove me wrong with the exact steps. Be specific or FOH.
    Again, I am talking about uninstalling cortana, edge, xbox, the windows 10 appstore and all the other preinstalled crapware so that no files remain, and no processes are lurking and transmitting to Microsoft.
    Regardless, trying to get rid of all that garbage post-install is like trying to un-spill paint - by all means, knock yourself out if your time is worthless. Far better to rip it all out of by the roots pre-installation from the ISO.
  26. jyi786
    5,535
    Jun 13, 2002
    Yep, this has been my experience. You cannot completely uninstall it after the fact. Only way to do it is via MSMG post deploy, or however you want to modify the ISO to rip all that trash out. Doesn't matter since it's buggy to all hell anyway.
  27. DPI
    DPI Nitpick Police
    10,999
    Apr 20, 2013
    Enterprise cannot be made emission-free at any telemetry setting, and Microsoft has refused to disclose a list of the datapoints transmitted at the "lowest" [0] Security data collection setting.
  28. FlawleZ
    FlawleZ Gawd
    741
    Oct 20, 2010
    The only sure way to block the telemetry is via Firewall. I'm tempted to install wireshark and just observe the behaviors in different situations, but I know this would be very time consuming to be thorough.
    x509 likes this.
  29. jlbenedict
    1,277
    May 22, 2005
    "Evaluation" for Windows 10 Enterprise LTSC 2019 is out
    chaikovski2002 and IdiotInCharge like this.
  30. jlbenedict
    1,277
    May 22, 2005
    "Located" a copy of the real deal :)
    Classic Shell still works also.. best of both worlds.
  31. IdiotInCharge
    8,389
    Jun 13, 2003
    I'd like to run this on my desktop at some point...
  32. trick0502
    trick0502 [H]ardness Supreme
    5,160
    Apr 17, 2006
    what is the real advantage?
  33. IdiotInCharge
    8,389
    Jun 13, 2003
    Have you read the thread from the beginning?
    [asking honestly]
  34. Frobozz
    Frobozz [H]ard|Gawd
    1,808
    Feb 15, 2002
    I've gotten a little lost on what's really real and what's pre-release... Do I need to talk to our enterprise media meister at work to fetch an ISO for 2019 and poke the KMS server, or is it still baking?
  35. bigdogchris
    bigdogchris [H]ard as it Gets
    17,751
    Feb 19, 2008
    It's been on the volume licensing site since the 2nd.
    Frobozz likes this.
  36. InorganicMatter
    InorganicMatter I Don't Know How to Make Threads
    15,249
    Oct 19, 2004
    Are you certain the "real deal" is posted? Your screenshot shows it's based on version 1809, which is the release that was pulled from mainstream Windows 10...
  37. IdiotInCharge
    8,389
    Jun 13, 2003
    The LTSB and now LTSC releases are pulled from mainstream Windows 10. I'd certainly like to be able to run the 1809 LTSC on my desktop!
  38. jlbenedict
    1,277
    May 22, 2005
    I downloaded it before it was pulled. Not sure if the "fix" is re-released as of yet..
    Installed in a VM for now... haven't had a chance to put it on my desktop as of the moment..
  39. Executioner
    Executioner Limp Gawd
    292
    Apr 22, 2015
    What is the difference between the LTSB and LTSC?
  40. IdiotInCharge
    8,389
    Jun 13, 2003
    LTSC is the new LTSB. From 'Branch' to 'Channel'. Same basic idea.
    So the last version was Windows 10 LTSB 1607, and the new (current) version is Windows 10 LTSC 1809.
