Windows 10 AU + WSE 2012 Connector problems
Quartz-1
This workstation is running W10 AU and my server is running WSE 2012 (NOT R2) and now the Connector software is reporting a version mismatch.
I'm seeing lots of errors in the System event log about WSE services not starting, and errors in the Application event log as below in the spoiler:
Log Name: Application
Source: Application Error
Date: 06/10/2016 15:08:29
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: QPC.AlbertDen.local
Description:
Faulting application name: WseClientSvc.exe, version: 6.2.9805.10, time stamp: 0x578eac4d
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0x80131623
Fault offset: 0x00007ffca88e1015
Faulting process ID: 0x27d4
Faulting application start time: 0x01d21fdb1cec164d
Faulting application path: C:\Program Files\Windows Server\Bin\WseClientSvc.exe
Faulting module path: unknown
Report ID: d1ec2c58-177e-4498-a80e-27ab8fe96103
Faulting package full name:
Faulting package-relative application ID:
Source: .NET Runtime
Date: 06/10/2016 15:08:36
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Application: LANConfigSvc.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException
at Microsoft.WindowsServerSolutions.CoreNetworking.LANConfigSvc.LANConfig.Main(System.String[])
Source: Windows Error Reporting
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Description:
Fault bucket , type 0
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: WseClientSvc.exe
P2: 6.2.9805.10
P3: 578eac4d
P4: mscorlib
P5: 4.6.1586.0
P6: 575a1530
P7: 3805
P8: 8
P9: System.ArgumentNullException
P10:
Got any suggestions?
I have fixed this. The fix in the linked article didn't work. I had to remove both the connector and something else. Unfortunately, I forgot to make a note of it, but I recall it being related.
