Winamp and Multiple Displays
adm01
Hey
I have an external monitor attached to my emachines laptop, and I would like to run winamp visualizations fullscreen on the secondary monitor, but It keeps on going fullscreen on the primary laptop LCD. Any suggestions?
if you put the whole winamp program on the second monitor dosnt it run the visuliazation on the second one? mine did when i was running ultramon.
my question is why waste a second monitor for winamp visulizations when you can use it for something useful, like pr0n or... ummm..... spreadsheets and documents ;)
hehehe well most of the time I do, but I am doing a research paper, and I need to focus on it. THe visualizations are soothing and help my intellectual processes.. I have tried moving everything including the start menu bar and everything to the second one and still no luck
Different "strokes" for different folks....... ;)
Under Milkdrop's settings in Winamp, should be able to select Display adapter 2. Thats what i've done, with a 9800Pro.
I you're runnin AVS for Winamp you can only maximize the window I'm afraid. I've tried everything I can think of to make the visulizations fullscreen with AVS but they never work.
Make the monitor that you want to display the visilation the primary monitor. Some programs will only display on the primary screen.
I know other things that can do that too..... :eek:
actually i agree, sometimes those visualizations with the right music are do wonders.
