From your link:
It says nothing about ClawHammer in particular and it was always the plan to release SledgeHammer first. That said, 4-6 months late is a fair estimate from the last delay. K8 was released in April 2003.
Why bring up Zacate? I've made no mention of it in this thread and I praised the low power Ontario in the Fusion thread a few posts down. The C-50 CPU is not as fast as the N550 when Ontario is scaled down to 1GHz/8W, but it's close enough. Ontario's GPU of course is a lot faster than the slow GMA 3150. I mentioned both things in that thread. If you meant my comment about Llano, it really uses a version of the K10.5 core, believe it or not. That was announced long ago and was done to mitigate risk. That puts Llano X2/X4 in Core 2 Duo/Quad territory at best, with the possibility of higher clock speeds to make up for clock for clock performance deficits. Again, really consider how late these products are and you'll start to see the problems AMD is facing.
I brought up Zacate because they only let them be benchmarked (engineering samples) a few months prior to release. You claim AMD is afraid to release Bulldozer benchmarks because they are terrible. Well there is still 4 months left until Bulldozer is supposed to be released. Zacate benchmarks weren't terrible (in fact I thought they were pretty stellar) and we only got to see them few months before release.
Llano is a weird hybrid CPU. That it uses K10.5 derived core it's a bit odd, but not late. K10.5 and whatever modifications AMD implements by the end of the year will probably be very competitive with mobile Core i3 segment. And you know that the GPU portion of Llano will smoke whatever Intel has in the TDP envelope and the price range.
By the time Llano comes out AMD will have 3 completely different architectures in pipeline: Bobcat. K10.5 and Bulldozer.
I think you are branding Bulldozer as a failure before you have any evidence to think that it will be a failure. There is more evidence to think that it will be a success. Zacate is the indication that they are on the right track. They delivered a netbook part that can game and have 10 hours battery life. They basically delivered an APU that matches Atom D525 + Ion2 performance at much less TDP and cost. I wouldn't say Zacate is late in terms of performance and I don't think Bulldozer will be either. They hit all the goals they aimed to hit with Zacate but they only showed us the benchmarks right before the release. The same is most likely the case with Bulldozer.
