People, people. Did any of you decide to actually read the licence? I did, and here's my take. First, I quote what ZD conveniently omitted (probably because it was contrary to their story):
Note that it refers to software that have been updated using the Windows Anytime Upgrade Software, which (if you have been keeping track of Vista news) you would recall is the software that allows you to upgrade, say, Vista Home Basic to Premium or Ultimate without a reinstall, simply using a credit card and some MS server.
What it's saying here is that if you have updated to a new version, you have one transfer of it. After that you may not transfer that newly added OS upgrade to any newer systems. I'm sure you can still move your copy of Home Basic around as you have the hard copy, but the virtual add-on is at that point untransferable (and when you do transfer the Home Basic to a new PC, you obviously lose the Ultimate you have on the old PC because the Basic licence moved.
The 'software other than' section (which is section a) simply refers to versions of Windows that have not undergone a 'Anytime Upgrade'. That would be your standard Vista Home Basic you have the box for. Note that it says you can transfer it, but places no limits upon said transfering.
Based on this, it seems likely to me that you can still transfer your original, boxed licence around as you please. MS is still ripping people off, but only those who have upgraded using the Anytime Upgrade software.
15. REASSIGN TO ANOTHER DEVICE.
a. Software Other than Windows Anytime Upgrade. The first user of the software may
reassign the license to another device one time. If you reassign the license, that other device
becomes the “licensed device.”
b. Windows Anytime Upgrade Software. The first user of the software may reassign the
license to another device one time, but only if the license terms of the software you upgraded
from allows reassignment.
