- Oct 7, 2000
yes a few of the really high end boards do, asus mostly.Aren't there motherboards these days that can flash a bios from a special USB port without a CPU even installed? I vaguely remember seeing this.
My MSI Titanium does as well. A lot of motherboards these days do actually utilize the "special file on a USB drive" trick, but there are two issues... First, it's not really mentioned clearly unless you really dig for info, sometimes requiring a special keyboard key combo while powering up, sometimes not. Second, most of the time you still need a CPU and RAM installed, which correct me if I'm wrong but if a CPU isn't supported then it sounds like you're not getting into the BIOS (hence the loaner program).yes a few of the really high end boards do, asus mostly.
Pretty sure both ASUS and MSI's top end boards feature the No CPU, No RAM ability for updating the BIOS through that special USB port, so that's a start. (Not 100% if ASUS does, but I know at least my X370 Titanium does)
I personally enjoyed the longevity of AM2, AM2+, AM3, and AM3+. There weren't really any features from newer Intel platforms it I was actually missing that I cared about at the time - at least nothing that I would want to upgrade a CPU AND Mobo for, anyway. I'm hoping AM4 is more of the same. The only time AMD has ever really disappointed me with socket longevity was Socket 939. Wikipedia says it lasted 2 years before being replaced by AM2, but it felt like blink-and-you'll-miss-it at the time...
It's not like Intel has never had a prolonged socket life, either... Slot 1, Socket 370 and BX chipset lasted a LONG time.
These are the people who normally don't have much knowledge on a PC build. In a perfect world, every motherboard on sale should have their BIOS/UEFI updated to the latest version. Blame the PC seller for not doing their best in business and not tracking these due to lack of mandatory law/regulation.a lot of people have been attacking AMD over the BIOS update issue
When i bought my Kaby Lake 7700k CPU I had to decide on a Z170 board that may come with an updated bios for Kaby Lake support or a Z270 board.
Since the Z170 boards were on sale and way cheaper than the exact same board in Z270, i decided to take my chance and bought a Z170 board.
While waiting for them to arrive I just ordered me a pre-programmed bios chip with the latest bios from ebay for like $14 "just in case"
Turns out my z170 board didnt have the latest bios for Kaby Lake support, so i swapped in the new bios chip and i was off and running....(problem solved in like 2min)
fucking noobs. this is how its always been. do you really want new boards and chipsets for every single change in a cpu?! oh wait, intel...
Would people like this go out, buy a new CPU and do the switch by themselves?These are the people who normally don't have much knowledge on a PC build.
Yes, after finding out the socket is the same and thinking that they can save money on motherboard without reading more details.Would people like this go out, buy a new CPU and do the switch by themselves?
Always wondered why is it that after all these years of problem with bios flashing with cpu upgrade and everything,that flashing bios via Usb without cpu in like some of the top end board is not mandatory in the design at this point.Would solve all that Rma/Loan Cpu/Going to the store/Asking friend with similar cpu assle.
Why cant they just put the bios on the cpu?
AMD could require BIOS updates for all CPU's released on a socket, as part of the license to motherboard vendors to produce boards.
On the one hand this could solve the problem, but on the other, it might result in fewer motherboards being released.
Easy solution *if* your mobo has a pullable BIOS chip. Some mobos have soldered-on BIOS chips so unless you can deal with that it's not an ideal solution.While waiting for them to arrive I just ordered me a pre-programmed bios chip with the latest bios from ebay for like $14 "just in case"
Sure, but if new CPUs are released without a corresponding new motherboard release, then anyone getting on board the platform for the first time is going to have a headache.This is such a non issue.
The value added point here is that someone could buy the launch setup, say with a 1700x or whatever, and then a year later add in the 2700x with a bios updated.
If you want to buy the bleeding edge CPU with a year old motherboard, do your due diligence and verify the bios is updated, or make sure you have a means to update. This was the same story in the Socket A days, where the same socket was used for several cpu familes.
Last time I looked (about a year back, when Z170 and Z270 boards were both about, vanishingly few supported CPU-less BIOS flashing. The top end Asus ROG boards did, but they were the exception rather than the rule. Shame, as it would avoid people having to buy or borrow a cheap-as-possible compatible CPU purely to flash the BIOS of a new board.
Yeah, I guess it's like a lot of these "premium" features in that it'll trickle down the product stack over time. I do wish they'd make it more widely available though - when I bought my Z170i Pro Gaming board at the start of last year, I could have paired it with a 7700K but went with a 6700K instead as I couldn't be sure that the board would work with a 7700K out of the box. And as it turned it, despite there being a compatible BIOS available to download, my board didn't ship with it.There are still many models that don't support that feature, but I'm seeing it in lower and lower price points all the time.
But most people don't buy a new processor every year, they tend to hold onto a processor and motherboard for more than a year; sometimes even more than that. By the time you get around to actually wanting to buy a new processor you're probably going to want to buy a new motherboard as well. Yes, backward compatibility is nice but it can also be a double-edged sword.fucking noobs. this is how its always been. do you really want new boards and chipsets for every single change in a cpu?! oh wait, intel...
it isThis seems more like the third party manufactures issue than AMD.
where did I say that or give a timeframe? i didn't. the new 470 is backwards compatible, the 370 and lower are forward compatible.But most people don't buy a new processor every year, they tend to hold onto a processor and motherboard for more than a year; sometimes even more than that. By the time you get around to actually wanting to buy a new processor you're probably going to want to buy a new motherboard as well. Yes, backward compatibility is nice but it can also be a double-edged sword.
Don't forget that Microsoft wants you to activate that Windows againBut most people don't buy a new processor every year, they tend to hold onto a processor and motherboard for more than a year; sometimes even more than that. By the time you get around to actually wanting to buy a new processor you're probably going to want to buy a new motherboard as well. Yes, backward compatibility is nice but it can also be a double-edged sword.
What, you didn't love being stuck with PCI-E 2.0 and USB 2.0?I wish amd wouldn’t support platforms as long. Look at the am3 platform. How long was that around? By the end of its life it was way behind intel on features. As much as it sucks buying a new mb for a cpu at least you’re getting the latest features.
