Server 2008R2 is 64-bit only I believe, so that means we'll finally have a 64-bit WHS.
Hopefully they've added better support for backing up the OS drive, as dydx mentioned. Also, I hope they make the server recovery process more transparent. With the current WHS, if you do a server recovery, it doesn't always recognize your existing drive pool, and it doesn't give you much feedback as to what went wrong. Some tools to diagnose, or at least help you rebuild the pool would be nice.
Interesting upgrade problem here. None of the published upgrades support going from x32 to x64. I guess we take the pool offline, cold load the OS, and then let it rebuild the pool from the tombstones? I know I'm jumping to conclusions here but this doesn't sound like a fun upgrade at all.
Doing an upgrade should not be a problem
The OS and the file system are compelety independent.
DE just uses symbolic Links which are the same on 32bit and 64 bit.
So when you do an upgrade it will just nuke the OS partition and install the new WHS, then they will have to recognize the FS symbolic links.
OK, but the backup database? The backup's themselves? The user settings? All your add-ins will probably be incompatible due to x32->x64? There are a long list of hassles associated with MSs preferred OS crash recovery for WHS (start over and rebuild the tombstones...). The only thing they got right was recovering the DE filesystem. Hope the delay getting Vail to release is the care they are taking getting all these other parts right (wanna buy a bridge?).
you trying this on your main server?Im downloading the CTP now and will install it tonight when i get home.
I will try to do an upgrade on my WHS 2003 and see what happens
you trying this on your main server?![]()
may we get some screen shots?
there aren't any drives > 2TBnitrobass - when you get it built, could you check to see if the DE pool will support large (>2TB) drives. If it does, can you tell if they are using GPT or something proprietary?
well I know you can get over 2TB with RAIDRAID
well I know you can get over 2TB with RAIDbut his post didn't say anything about RAID
If you don't want hassles or risks to your 10Tb then maybe an early leaked beta isn't the best choice? Surprised how many people are chiming in with expectations already when it's not "a new version", its a pre-release beta. That's why the beta group signs an agreement not to complain if a bug blows up all their data.
That said, the big question is whether WHS v2 added parity ability to drive extender, or whether their "redundancy" solution is still limited to simple file duplication. If the latter, then see you in 2 years for WHS v3 to ask again whether MS pulled their heads out and WHS isn't a toy anymore.
Good point pjkenned except thanks to the miracle of SAS expansion, when you take an HP SAS Expander and combine it with a low-cost 4 or 8 port RAID6 card off ebay, you've got 32 ports of RAID6 for $400-$500.
I guess it all depends on the situation and who is managing the system. If it was a non-technical friend of mine then obviously I wouldn't suggest him to mess with raid cards and rather just buy extra drives.
The reason for my gripe about DE and lack of parity is simply because so many other things are doing it (Flexraid, unRAID, FreeNAS) and it's REALLY not that big a brain bender to implement. Microsoft needs to catch the F up.
Of course, MS will argue that one of the advantages of DE is that it does not use parity and stores everything as normal files. They will argue that you can take any drive out of a DE pool and take it to any system that supports NTFS, mount it and read off all the files. They will argue that you can take a partially corrupted DE pool from a fully corrupted WHS system (lost the system and parts of the pool) and still easily recover any file data from any drivers that can still be read, making it much more resilient against failure than any implementation using parity. The will argue that for their target market the cost in extra disk drives is minimal compared to this benefit.
Not suggesting that I buy into this. Whether or not I or you agree with these things is not meaningful. The fact is that the product managers that deal with WHS believe these things with religious passion.
And because of that i'd bet a paycheck that you will never see official support for any form of parity within WHS or any other Microsoft product the DE finds its way into.
Of course, MS will argue that one of the advantages of DE is that it does not use parity and stores everything as normal files. They will argue that you can take any drive out of a DE pool and take it to any system that supports NTFS, mount it and read off all the files. They will argue that you can take a partially corrupted DE pool from a fully corrupted WHS system (lost the system and parts of the pool) and still easily recover any file data from any drives that can still be read, making it much more resilient against failure than any implementation using parity. They will argue that for their target market the cost in extra disk drives is minimal compared to this benefit.
True, but really that doesn't apply to all forms of parity protection. If it was implemented in a pseudo-RAID4 style like FlexRAID, you'd still be able to read the data from any of the (non-parity) drives in whatever other system.
Now if we could only get MS to agree.![]()
