- May 21, 2008
Good call sir, good call, please post ASAP as I will watch this really closely
Posted via [H] Mobile Device
I had briefly tried openSUSE over a year ago. I found it to be resource heavy and it kind of lagged on my systems in a VM. Maybe my hardware wasn't fully supported. Don't know about its performance in a native installation.I'm downloading SUSE 11.2, which has kernel version 2.6.31 so I'll see if it improves performance on my smp units and if it does I'll move my bigadv servers over to it.
Can't wait to see the results. More interested in the kernel performance differences though (if any).Actually to spice it up more, I'm going to do a shootout.
openSUSE 11.2 vs CentOS 5.4
I've got two 4core HS21s with identical TFP so it should be a good comparison.
To tell you the truth, I find this trend a bit upsetting. I never would have expected a DC app to require vast amounts of main memory to run. Since the project began, it has never required huge amounts of RAM even under a VM. Historically, I have always been rather conservative with my RAM installations. Not low, but not generous either. Now, most of my systems have been rendered inadequate if not obsolete.I'm also looking at getting another 6gb. That's just crazy to actualy be using all of that space.
To be fair, -bigadv units were never designed for consumer systems. They were always meant to be the huge projects that Stanford crunched when they managed to get some supercomputer time. It's just a fluke that now some consumer machines (i7) are actually powerful enough to crunch them in a reasonable amount of time.To tell you the truth, I find this trend a bit upsetting. I never would have expected a DC app to require vast amounts of main memory to run. Since the project began, it has never required huge amounts of RAM even under a VM. Historically, I have always been rather conservative with my RAM installations. Not low, but not generous either. Now, most of my systems have been rendered inadequate if not obsolete.
That's because bigadv isn't designed for consumer-level hardware, it's designed for people who fold with dedicated servers, VM machines, and the like, who have multiple-socket, multiple-thread processors and upwards of 16GB of RAM to run them on. It's just a fortunate coincidence that i7's just meet the criteria for the -bigadv work units in processing power, if not in system memory, usually. That's why they're trialling the bonuses with these units, and why the bonuses are so big; just like how SMP is supposed to reward people for contributing extra resources (CPU cores, mainly) to the project, the bigadv work units just go up another level for people running server-level hardware which is overpowered for the normal SMP work units but who are not being rewarded proportionately for the cost of hardware, power, etc.To tell you the truth, I find this trend a bit upsetting. I never would have expected a DC app to require vast amounts of main memory to run. Since the project began, it has never required huge amounts of RAM even under a VM. Historically, I have always been rather conservative with my RAM installations. Not low, but not generous either. Now, most of my systems have been rendered inadequate if not obsolete.
CentOS treating you good? That's what I plan to use
For those of you running the EVGA vm how are you monitoring it?
I set it up in HFM.net but im having timeshift issues.
This is the second box ive tried and I get timeshift issues on this VM.
I think timeshift is just something you have to deal with.
So you not monitoring yours?
What's that 9600GSO clocked at?Sure I am. On HFM.net the status box is just blue instead of green
/shurgs
Blue? What does blue mean?
Mine shows up as Red.....Hung![]()
click the box that says your running in a VM?
And you're getting 4300PPD on a 353-pointer? That's better than my overclocked 9600GSOs.Stock..... it is in the sff box in the neighbors house. The box has a bit of issue with heat as it is.... didn't want to make it worse.
You only need to use that if the client is still showing as hung. If it is, let me know and I can help you set up the offset value.Do you have anything in the offset value?
Yea i got that, this is making me look dumb.
Setting up another HS22 now.
