- Apr 7, 2006
Dephcon
You could BSEL mod those for some more power.
Dephcon
*edit*
Just to add, I did get my hands on a pair of HS22s w/ 2xE5540 (2.533GHz) temporarily. Should be able to hang on to them for a few weeks. Took me a while to figure out that having hyper-threading enabled in ESX was preventing the VMs from ramping up the CPU. I hope to get some sweet frame times with them.
Well this is exciting. The frame times for my 3 new boxen are in.
HS21 (2x5405@2GHz) - 48:56
HS22#1 (2x5540@2.533GHz) - 30:24
HS22#2 (2x5540@2.533GHz) - 30:40
Now that all the stats are in for all my boxen HFM.NET is telling me 106k PPD!![]()
what's the environment those HS22s are running?Well this is exciting. The frame times for my 3 new boxen are in.
Is it windows OS, one VM, with Hyperthreading off?
VMware ESXi 4.0 with that slackware linux -bigadv VM that's floating around. Hyper-threading is off, it didn't work at all with it on.
Add more CPU volts. And stability test with IBT instead of Prime, its usage pattern is much closer to the SMP client than Prime is.
That's awesome!Well this is exciting. The frame times for my 3 new boxen are in.
I wish that were true, but I'm not convinced that would be the case. I think something else is going on.it's also slow because HT is off
Were he using native Linux client with all 16 cores on, he'd be making times in the mid 20's or so
I'm not looking forward to learning Linux again tonight/tomorrow
Yep, agreed. To get around the 20 minutes mark you need more horsepower. Probably something with 16 actual cores pushing the 3GHz threshold.I wish that were true, but I'm not convinced that would be the case. I think something else is going on.
With dual 5530 2.4ghz, HT on, running native Ubuntu 9.04 with 12GB RAM, this guy is only getting 33 mins per frame.
http://foldingforum.org/viewtopic.php?f=55&t=10733&start=60#p109354
I might of gotten myself stable by using -smp 7 instead of 8.
Lets see if I can finish this one.
Yes. Actually those with i7 machines might want to try the -7 flag instead of -8 flag. Supposedly better times from what I read.Oh you can do bigadv work units with "only" 7 cores?
Oh you can do bigadv work units with "only" 7 cores? I may try that out, if I get back to overclocking (it will probably be a while).
perhaps with insufficient RAM.Yes. Actually those with i7 machines might want to try the -7 flag instead of -8 flag. Supposedly better times from what I read.
I'm very sure it's possible but probably running HT and higher clocks. Do you remember any ballpark frequencies?I was sugessti g 25-28 TPF times, not 20 flat, that would be nuts LOL
I could have swore there were people at ff running dual 55xx xeons hitting mid-high 20s
I tried to look it up but my phone doesn't support that page that well
If some one can confirm that, I can reformat one of the HS22s and dump sles11 on it.
I'm pretty skeptical that a native Linux OS with hyper-threading will be any faster, but I'll gladly be proven wrong.
It will likely be faster but I'm not expecting a night and day difference. People here (myself included) will make an effort to extract every bit of performance they can from their rigs.If some one can confirm that, I can reformat one of the HS22s and dump sles11 on it.
Try it if you have the time. Maybe the advantage is greater than I expect, you never know. There could also be useful information gained. Not many people have these kinds of systems and it would be very interesting to note the differences between various installations and setups.If i was going to have the HS22s longer than 2 weeks I would. Its its just going to be slightly faster I'd rather not as I'm not exactly 'nix friendly.![]()
Thanks for trying it out. I was very curious how that would perform. Very interesting finding.Apollo, you were right. I got a client running on a SLES10.2 HS22 and I'm getting a TPF of 29:02
Thanks for trying it out. I was very curious how that would perform. Very interesting finding.![]()
