From what little I've read, intels x-25's seem to be great drives but why?
I reallly want something with more speed than size as I have more drives for storage I just want this for windows and varioius work applications and a few games.
What are some of the key features to look out for?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167005 would this be one of the second gens you're talking about, the x-25m?
So there's an x-25, x-25m, and x-25e. But why are the E's sooo much more expensive, I realize they're EXTREME, but really what makes them better?
E's use SLC tech. M's use MLC flash. Search wikipedia if you want more info. E's have faster write speed. But the New x-25M @ng Gen have faster random I/O. From what I've read and heard the intel drives have the best real world impact(ie game and app launching, os loading). Wait for the 2nd gen intel drives to get back on newegg for 225. Best drive out there right now IMO. The OCZ Vertex has faster write speeds but intel blows it out the water in Random I/O.
Yes but the question is is the increased random I/O noticeable in daily use? Doubtful. However the extra 40gb is..
Any idea if the fix is out yet?
Yeah, thanks was doing some more research on real world benches and I think the intel g2 is the way to go.
Do you see what you just said there? "Real world benches" That does not make any sense.
It is my understanding that when the drives are available the fix will be done. I guess they more or less got recalled so they could be fixed.It's not yet avaliable and neither are the drives.
Intels 2nd gen 80GB X25-M gets my recommendation
It is my understanding that random IO IS typical daily use, while sustained writes are not as common. I think the performance advantage with the X25-M G2 would be noticeable, but I could be wrong. It might all just be e-peen and synthetic benchmarks.
Can anyone that has gone from an Indilinx drive like a Vertex to an X25-M G2 chime in?
I won't speak ill of the X25 Gen 2's, because they really are great drives.
HOWEVER, unless you are running a seriously hotshit system, the difference between an X25, X25 Gen2 and a Patriot TorqX M28 is not going to be at all visible in day to day operations. Benchmarks and whatnot are frankly, pointless. Do you honestly, really care if you wait another half second to load a level? No, not really.
At this point in the SSD game, think less performance, more value. What does your money get you, when you remove performance from the equation? Not that performance isn't an important aspect, but honestly, SSDs are outpacing everything else, and differences are measured in milliseconds.
Just something you should all consider.
So to paraprhase you, buy the the cheapest $$$/GB?
Actually, no!
I buy the one that gives me the best total value for my dollar, rather than cheapest per gigabyte. I certainly could get more gigs for less dollars than a Patriot TorqX M28. However, the TorqX M28 has a 10 year warranty, which is a tremendous value.
If you were to present me two Indi based SSDs, same performance. TorqX is $340 @ 128GB, but I can get the other one for $300 @ 160GB, but has a 2 year warranty, I would go for the TorqX. Why? Because that extra $40 means I don't have to spend $100-$400 after 24 months for a new drive, should it fail. It's cheap insurance.
By the same token, if you gave me two drives with a 3 year warranty - one is 80GB and $275, the other is 128GB and $290. The 80GB has slightly better performance by a hair. I'd go for the 128GB, because it's the better value proposition.
Makes more sense now?
So to paraprhase you, value in SSD is a combination of Warranty, $/BG, then speed. In decreasing importance.
BTW, I am NOT making fun of you (well a bit), I am actually learning quite a bit from what you are saying.
As long ass you're sticking with current gen SSDs - NO JMicron anything. I'm not a big fan of the new Samsung drives either, but that's just because of the lack of support for them. Stick with Intel or Indilinx.
I would like some of what you are smoking. The Samsungs are very well supported, and easily the finest drives out there from a support standpoint.
Ended up getting a X25-M SSDSA2MH080G1 80GB SATA II MLC
I'm sure i'll be happy with it's performance and i've got 5tb worth of space on another machine if I need storage.
Thanks for the input.
Hi, does anyone know for why Everest doesn't show any temperature value for SSD drives ?
It does for every HDD I connect to the system, but none for SSDs.
