Which SLI board?
Anyone know when the MSI SLI boards will be available and how much? I mean in the states availability.
jacuzz1 said:
um the Asus Ultras are just that Asus. They are not true Ultras. take a close look at the memory specifications
EDIT:
WTF? So I looked it up. Why are Asus's cards 450mhz core 800mhz memory when almost everybody else is 550mhz core 1.1memory
To Keep this post on topic- The DFI would be my choice, simply based on my past experiece with the NFII Ultra B and the reviews on the 875 series of boards. However, there is a larger issue here. These boards and the chipsets are still in their infancy. With this kind of investment, I would seriously wait for the enhanced stepping and board revisions. AKA NF7S 2.0. Also, the 6800s will not remain at these insane prices forever and the drivers need updating as well to dynamically generate profiles. I say save now and give it 3-4 months before buying...there will be a much better picture by then.
my $.02
I already bought the cards :( so waiting is out of the question. I can purchase a newer revision board no problem later on if it's better than whatever I get. I'm just stuck between the DFI and the Asus. Although the A8N is doing poorly right now, I've always had great luck with them, which is what is keeping them around in my decision right now.
I think your ASUS 6800 Ultras are real 6800 Ultras, at least if they are like the AGP version of the card. My dad has an AGP ASUS 6800 Ultra, and if I remember right the GPU is clocked to 425 mhz. Really, that makes the card at stock like a BFG 6800 Ultra OC. ;)
Didn't quote the guy, but without doing me much research on it, I wonder if he was confusing the 6800 non-ultras that are priced like 6800GT's. They have a card like that which is advertised more like it can compete 6800GT, but really is just a overclocked 6800 standard. They don't try to deceive people on it, but I've seen at least one magazine review, where at least due to price if nothing else they use it, and not an ASUS 6800Gt to compare to one or more 6800GT's, then almost act amazed when it doesn't do as well.
Checked up on it, just to make sure. These are 425/1.1 which makes them stock retail 6800ultras. They are retail packing from what I was told, but it doesn't look like Asus is selling them Retail which is weird. I've only found them listed online on wholesale sites.
This is the actual line item from quote.
Qty - Part Number - Description - Price - Ext. Price
2 - EN6800ULTRA 2DT 256M - GF6800UTA VIDADPT 256MB PCIE DVI 2ND VGA 2ND DVI - $799.20 - $1598.44
Actually, 400/1.1 I think is the stock speed for 6800 Ultras, the eVGA on Monarch Computer I linked to when I asked if you could cancel your ASUS cards is running at 400mhz for instance, so your ASUS cards are clocked like a BFG 6800 Ultra OC.
Evga comes 425/1100 they just dont advertise it. The one I owned did anyway
Nforce4 SLI rev. A3...at least..... and heatsinks on chipset and mosfets :D This Giga board is ready for phase changer....
What RAM are you going to put in that? Please, post pics of your memory installed. I'm drying to actually see how close it is.
Gskill LE 2x512..ram without spreader...
That doesn't seem that bad. I guess I can see if there were rather large heatspreaders on the ram. hmmm, now the gigabyte is back in the mix with the asus, dfi and gigabyte. i still want to see reviews on the dfi i guess before i make a final choice.
Yeah, I think the normal heatspreaders that most of the memory companies are putting on would be okay, they might just touch, but still fit without the memory sitting askew. I got that idea from the www.pcper.review, and his photo of his board IMO confirms that. It would be the memory I'm using, the Corsair XMS XL Pro with the LED's on top that wouldn't fit without being at an angle. Otherwise, this stuff...
http://www.corsairmicro.com/corsair/products/specs/twinx1024-3200xlpro.pdf
....wouldn't fit right.
Heres the SO SO result so far with stock hsf/air, mem at 2.5V, vcore at 1.525V and htt at 4x..
Not terrible for being on air. What BIOS are you running right now? Reason I ask is I'm on a FX-55, when I finally dump these NCQ drives (or if they come up with a BIOS that lets me use them...), I may want to play around with similar settings, I'm using a Thermalright XP-120 heatsink with a Thermaltake Smart Fan, so on Air.
EDIT: Thunks head, forgot you had the Gigabyte board for some reason when I posted. Nevermind. :eek:
Gigabyte k8nsli with phase changer....not to shabby ;) Hopefully this mobo can scale higher.
Compare it to neo2 with same configuration and more cpu power
Ok, I took the plunge. I just ordered my A8N-SLI should be here in about week. The bad thing about supporting a friend at CompUSA, I have to wait longer for everything since it's through the Business side. Oh well.
Hey good luck. Let us know how the system build goes. Are you going to try your NCQ drives on the NVIdia ports, try them on the Silicon Image ports, or buy a PCI slot (or if you can find one PCI-E slot) RAID card?
Or did you RMA those for different drives? I just cloned mine to the two Raptors I got from Newegg, and went to 1004.001 BIOS. SO far okay, but only rebooted twice...but going to act like all is well and go from there. Anyway, until if/when they get the NCQ issue settled, no NCQ for me. ;)
I'll try the Maxtor drives on the Nvidia ports, but it'll be another 2 weeks or so before I have all the parts. Alas, the problems of using the Business section. Time delays :(
lil update. i went with a 64 3200 asus sli mobo 2 bfg 6800gt 2X512mb ocz pc3700 1 74gb raptor and without any ocing on an operating sys in dire need of reformatting I got a 3d mark 05 score of 8200! big jump from the 1218 i got with a 6600gt...asus is a good board in my opinion. stable anyway.
I assume at stock clocks. If it is overclocked a bit, 10K is possible.
totally stock. just got it going last night haven't had time to play with it.
Well, made some initial tests with the MSI Diamond SLI board. Here is a contrast to the ASUS:
Better:
1. The northbridge fan is MUCH quieter.
2. Likes TCCD. I was able to get my DDR to 295 FSB, 1T
3. A little more VCore for the Winnie crowd. 1.68 set in BIOS. I was able to get my CPU to 2.7 Ghz versus the unstable 2.5 GHz on the ASUS
4. The power caps are HUGE.
5. The RAM is not right next to the DDR
6. The SB64 Live with EAX sound
7. No errors when you use no fans.
Not Better:
1. The PCI-E cards are way too close. I would not even want to run two Ultra's on this board unless you have slim water blocks. The GT HSF should be fine.
2. No PCI-E 1X slots
3. The SLI bridge clip does not distinguish primary and secondary like the ASUS SLI bridge. You have to guess.
4. The SLI/Single card selector uses a wimpy plastic tab. The ASUS selector is a little more solid.
The last few oc attempts for this Gigabyte k8nxpsli before jump ship to Neo4 Platinum SLI
Better:
Not Better:
Even with the minuses, the MSI does sound tempting to be honest. Will have to mull this one over a tiny bit perhaps.
That MSI and Gigabyte board both seem great overclockers. I'm hoping that this Asus board will fit my needs. I'm not going to be overclocking anywhere near where you guys are going so I think it will.
Don't know if you saw me mention this, but when I had a 20 pin PSU my board would lock up once in a while on the splash screen. Switching to 24 pin cured that...but now it's doing it once in a blue moon again. And my chipset fan is now starting at 2500 RPM and going up to 7500 RPM, it's not quite hitting 8000 RPM now. Yes, I ordered a replacement fan...but well...I'm going to go for the MSI and see what happens. I had wonderful luck with the MSI Neo 2 Platinum so I'll risk it. Worst case, it's as buggy I guess...err...okay, I've seen one or two posts on other forums where the MSI did sound good.
Better:
Not Better:
Ram heatsinks are OK then?
Thanks for posting.
Thanks for posting.
You mean are the RAM heatsinks really close on the MSI, or do you mean the MOSFET heatsink opposite the CPU from the memory, near the IO ports?
Tell you what, ask me in three or four days, I'll be switching to the MSI then. ;)
Heh, I'm just worried the DDR system RAM won't fit because the slots are so close. I have no idea what the other thing is, but since you've mentioned it I'll assume it's important ;)
Okay, the "other thing" is the heatsink near the I/O ports close to the CPU.
I had a MSI K8N Neo 2 Platinum, the memory was if I remember right about as close, and Corsair PC3200 XL Pro (stuff with the LED heat spreaders) fit tight, but did fit and the memory didn't sit at an angle, it was straight up and down, so it's okay probably. Not like the Gigabyte SLI board apparently.
I have no issues with the RAM at all. Plenty of room. It is the same setup as the Neo2.
And, this board is impressing me. I am now able to run 300 FSB, 9x multi, for 2.7 GHz. And, for all you wondering, that is at 1T, not 2T. :D
I picked up a PC Power & Cooling 510 SLI to make sure that wouldn't be a problem. I just hope I don't regret going with the Asus over the DFI or MSI
The A8N has improved with the latest bios update. Lots of stability fixes. But I'd personally wait for the DFI offering. :)
