vapb400 said:did MSI change the spacing between the two boards from the orignal SLI board they had?
Topher said:I'd say hold out for the DFI... that's what I'm doing. Everyone says the kinks will get worked out on things but I tend to not trust that anymore- look at the FX series, everyone said it'd get better with drivers
Arvig said:SHHHSH...I'm still trying to be optimistic.
Eh, figure I've got a week or three before the DFI comes out, I'll give this board at least that long.
oh yeah and if you haven't heard yet... the nforce 4 ultra and nforce 4 sli are like the exact same thing except for one small thing.. all you have to do is bridge two contacts on the 4 ultra and you've got yourself an SLIArvig said:SHHHSH...I'm still trying to be optimistic.
James Earl Ray said:Ah yes, the song of the truly desperate. LOL
Topher said:oh yeah and if you haven't heard yet... the nforce 4 ultra and nforce 4 sli are like the exact same thing except for one small thing.. all you have to do is bridge two contacts on the 4 ultra and you've got yourself an SLI
James Earl Ray said:DFI should be the first choice, MSI second. I wouldnt even consider the ASUS.
Arvig said:This from the guy who did the voice of Darth Vader...no wait...I might be confused.
Yes, I'm going off topic, but if I remember right, some orginization was giving a plaque for charity work to James Earl Jones...and yes, they did goof up and enscribe it to "James Earl Ray".
James Earl Ray said:Are you sure they "Goofed"?
Sir-Fragalot said:I have to say I am dissapointed in Asus this time around. Usually their quality is second to none. Especially not DFI or MSI.
I would consider an MSI board but DFI is out of the question.
hmm didn't know that... didn't see any mention of that when I read about it but depending on the price difference and what difference the true sli has over it, it may still be better to just get the ultraJames Earl Ray said:Not exactly. The Ultra-D uses what they call DXG(Dual Xpress Graphics) its not true SLI.
We all know that dfi, msi, giga, asus and chaintech mobos will be all available at retail channels by the end of the month and which ones will be a winnerJames Earl Ray said:We shall see.
centvalny said:We all know that dfi, msi, giga, asus and chaintech mobos will be all available at retail channels by the end of the month and which ones will be a winner
We will see Gigabyte sli in action soon I hope it will kick the hell out of my neo2Arvig said:You can already get a couple Gigabyte boards including a SLI, and although it sells out quickly, the Chaintech NForce 4 Ultra has been in stock for almost as long as the ASUS now. But yeah, next month will be interesting to see which boards have complaints, which ones have praise...and which ones have no comments and seem to be ignored for the most part.
centvalny said:We will see Gigabyte sli in action soon I hope it will kick the hell out of my neo2
Edit: If not then DFI is the next in line....Gigabyte with a lot of features that arent neccessary for benching. I have to disable most of it in bios
LittleMe said:I'm still concerned about the gigabyte board. The ram banks seem way to close, too close that it looks like they are out of standard. I don't want my ramsinks to be touching each other. Seems like their thinking is heat them all up to the same temp so when one gets too hot, it'll take the others with it. Maybe they are in cahoots with memory manufactures. all joking aside, the gigabyte board is out of question for me. The DFI board is looking better and better every day asus jerks these people around.
James Earl Ray said:The MSI board has been revised since the reference sample. I wonder if that is a good thing?
LittleMe said:What cards are those?
HeavyH20 said:Well, it is coming straight from HongKong. So, it is called the Diamond, not the Platinum. No difference, but for marketing purposes, Platinum is the US name.
There will be two versions of the MSI nForce4 SLI board shipping worldwide; in the US it will be called the MSI K8N Neo4 Platinum/SLI but in the rest of the world it will be called the MSI K8N Diamond. There will be some slight changes in the specs between the two but nothing major.
bananaman said:I have the MSI Platinum SLi - i'll be damned if i know what it is called in the US, but i am finding the board pretty nice . It is the one down from the diamond, it only had one ethernet connection, and "only" 4 SATA via the NF4 chipset.
havent updated the bios to the latest yet and am running it at 10x265, 180/200 divider on the RAM, 2.85v on ram, 1.58Vcore, couple of notched up on NF4 (cant remeber what exactly as at work . This is my first MSI board and i am impressed so far, i wish there was a bit more Vcore, but pretty nice really. A factor for me was the onboard sound which is Soundblasted live, and is far superior to the ALC850 i had to endure (still missing soundstorm )
NANA
LittleMe said:So, I'm reading all the problems with the A8N-SLI, which has me a little concerned. It's probably going to be 2 - 3 weeks before I order whatever board I'm going to get. Should I go ahead and just get the A8N-SLI and hope all gets fixed or should I go with the Gigabyte board or hold out for the MSI or DFI boards? I've gone with a 3500+ A64, 2x512MB sticks of OCZ PC-3200 Platinum Edition Rev2 and 2xAsus v9999's (GeForce 6800 Ultra's). Yea, I actually found a place with 2 6800 pci-e ultras in stock so I jumped on it.
