I understand the i7 920s can hit 4ghz with some good increases in voltage, but what about the 940?
Is there a good chip or stepping that gives the best chance of being stable and moderately temperate @ 4ghz?
There's no guarantee but the D0 stepping chip along with a good heatsink like a TRUE or Megahalems gives you a better chance at hitting 4ghz. The motherboard is also a factor. And your memory better be able to keep up.
Just to underline the importance of the mobo: same CPU will overclock differently from one mobo to another
Any suggestion on what boards that are generally good for overclocking?
thanks
it's not guaranteed, but on a good batch of the Intel Core i7 920 D0 stepping, you will probably get 4.0Ghz on 1.35 Vcore.
"Back in the day" the Q6600 was all the rage for the same reason. "Guaranteed" 3GHz from 2.4, some reports beyond that etc. etc. Mine goes to 3.2GHz but only at insane volts, something like 1.45v (currently kept cool enough that I'm not worrying).
i7 920 here, I can run 4ghz stable with no voltage increase. It's a D0, not sure which batch number atm.
What is stock voltage?
i7 975 D0 can hit 4ghz easily with low voltage.
What is stock voltage? I'm running at 1.305v and perhaps it could run lower. That was my starting point and it worked so I left it.
The closest you will come to a guaranteed 4ghz is the 3.8ghz p4 netburst![]()
